Question about Zephyr Savona ZSA-M90S Kitchen Hood
Noise Hi We have had the hood for 3 years. Recently, it started getting noisier and noisier when the fan is turned on. We cleaned the filter and even applied some oil to the metal to lubricate but the noise continue. Any tips what to watch for? Thanks, Raymond
  • Anonymous Mar 23, 2009
    Same problem... my Savona fan's getting noisy even though the filters get in the dishwasher regularly. I've noticed that the bottom of the fan unit has grease now in the connected joints. And with a flash light, can see the inside's greasy. Have a call in to Zephyr and awaiting their advice.
  • 37 Answers
I am reasearching the same issue. I was able to remove the fan assembly, and then remove the fan blades and view the area where the shaft comes out of the motor. I applied some motor oil to that location, and the noise reduced about 90%, but did not go away entirely. Sadly, I believe the bearings are wearing out and are now scored, so they will never be perfect. There was no easily visible location to apply grease, but the oil just worked in a little. To remove the fan, remove the filters at the bottom of the unit. Remove the exhaust cover at the top. There are 4 bolts at each corner of the exhaust... remove them (opposte corners first). Support the fan when removing the last two bolts, and lower onto the stove. You may have to snip the wire-ties that hold the wires in a bundle, but that is no big deal. Use a socket to remove the fan bolts, one on each side... they remove easily. Then pull the fan off and you can see the shaft. Apply proper machine oil to that location, and then put the fan on low to allow the oil to get worked in. Putting it back is a chore, becuase the nuts are on sliders and they are difficult to align. Plan on attempting the reinstall about 3 times. Leave about an hour for this project, maybe 2. Good luck!
Posted on Jan 03, 2009
Same problem pls let me know if you hear anything
also parts place for new motor
Posted on Jul 18, 2008
Fan is not working but makes a humming noise at lower speeds and clanking noise at highest speed. When last working there was the clanking noise when I turned off the fan. Please help.
Then turn it off immediately just to be safe that nothing will be broken, can you see the interior? Is there anything broken or loose that might cause the noize? If yes remove.
If not try to clean it with a little cloth or anything, maybe it is too dusty.
Mar 10, 2016 | Electrolux RH36WC60GS Designer Glass...
Signs my 95 chevy tahoe fuel pump is failing
For how long after does it make noise it's not uncommon for the pump to stay running 3-7 seconds after shut down however if it getting noisy you may need to change your fuel filter restrictions in the system will make it noisier
Aug 31, 2012 | Cars & Trucks
Hotpoint BD 42 Oven, main oven fan turning slowly and oven is not heating up to temperature
Hi you will to have a tester , start off by checking power at the outlet , if you have the 220 volts then we need to check the elements inside the oven, you may a have a bad element and a bad fan , after checking power get bacl to me , also need model number and serial number
Dec 01, 2011 | Ovens
When turned on the fan seems to be making a louder than usual noise
hi ihg4. As time goes on the bearings in these fan motors start to show wear and tear. This manifests itself into a noisier humidifier. One way to minimize this noie is to put the humidifier on a piece of carpeting which will deaden the sound. Joe
Thanks for choosiing Fixya!
Dec 09, 2010 | Crane Penguin 1 Gallon Humidifier
I purchased a side by side SBDT520 in Australia in December 1991. I love this fridge other than it has become much noisier over time. I am guessing this is the compressor. Amana is no longer available in...
The noise may be due to extermal factors, like condenser fan or compressor fastenerrs coming loose. Make sure the compressor and fan/condenser housing on the bottorm back side of the unit is clean and thight. If the unit is working fine. maybe all it needs is a little maintenance.
Don't forget to rate this post! Good Luck!!
Jul 26, 2010 | Amana 22.6 cu. ft. Side-By-Side...
My Kenmore upright freezer is about 6 years and has recently begun running noisier than before. Not a rattle, and not a rough sound, normal operation sound but just louder. Should I wait until it goes out,...
Check the evaporator fan inside the unit
Check the condenser fan (if equipped) under the unit
Check the compressor mounts - they are rubber and could be wearing causing the compressor to be touching something under the unit, making the noise.
Check for any loose parts like screws, hinge screws, sheet metal etc.
Dec 18, 2009 | Kenmore 20.6 cu. ft. Upright Freezer 24092
2004 Lincoln Navigator, Strange ticking noise coming from rear passenger 3 row area over wheel well some sort of computer box. only when turn ignition or vehicle running, sounds like clock ticking
This is caused by a blend door actuator on the rear a/c unit. There are 2 located on the case. Take it to a dealer and they will know what you are talking about.
Oct 15, 2009 | 2004 Lincoln Navigator
The kitchen hood fan above my grill is not blowing out enough smoke.
you should clean it carefuly after turning off and check that it getting enough current
Jan 20, 2009 | Viking VEDV900 Kitchen Hood
Hi, i have an Bosch just over a year old and it has just recently started making a noise from the back of the unit. It sounds like a fan rubbing or rattling, it stops as soon as the fridge door is opened.
hi thanks for the question .It sounds like the fan in the fridge is rubbing locate the fan and clean out the obstacle thanks the appliance doc
Sep 29, 2008 | Refrigerators
Dramatic increase in fan noise
Hi there
If you place your hand on the machine and you can actually feel the vibration , you might be looking at a faulty Colourwheel.
If not , try cleaning the fans by blowing it out. If the problem still occurs you might have to replace the fans.
Dec 05, 2007 | Optoma H56 Multimedia Projector
Zephyr Savona ZSA-M90S Kitchen Hood Logo
718 people viewed this question
Top Zephyr Kitchen Ranges Experts
Tom Chichester
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
