Question about HP Computers & Internet
Unable to start PC. Fans seems to start at high speed but there is no indication of hard-disk starting up or attmpts to read from CD station.
  • HP Master
  • 1,879 Answers
Indication of a hardware failure since the fan starts at high speed and no hard disk activity.
Posted on May 10, 2009
Im not able to boot from os cd the bios can see rom drive and hard drive but im not able to boot iv'e tried f12 but no joy can you help?
hi there.
If you go to the bios on start up and select cd rom drive as your primary boot and then restart. Your computer will then try to boot first from the cd rom drive and second from the hard drive. If it fails to boot from the disk then this would lead me to believe that either the disk is unreadable by the drive or that the cd rom drive itself is unable to read the disk.
Jun 30, 2011 | Dell Computers & Internet
Unable to do install of XP. during install process pc reports unable to copy various .dll's and other files from install disk. install disk is in perfect condition.
The message refers to the CD/DVD drive being unable to read from the CD itself. That could mean that either the disk is in bad condition and cannot be read (i.e. scratches, old disk, etc) OR that the drive has difficulty reading from the disk.
In the later case, it's the drive's fault and not the disk's (since you mention it's in perfect condition).
You could try cleaning up the drive but it's usually not worth it and since they're quite cheap, I would recommend getting a new DVD drive instead.
Hope that helps!
Mar 13, 2011 | AcerPower S285 (APS285UC3521) PC Desktop
When I star up my computer Toshiba a135-S4427, it boots up and then goes to a blank black screen. I am unable to get to the log in screen. It just sits there, I can hear the processors and the fans...
Seems a problem with RAM. Remove your RAM from the slot and start the PC, long beep sounds are audible, then the RAM is OK, else time to buy a new RAM/ memory.
Else Try for the Hard Disk, Check the Hard disk in your's friend's PC, remove his Hard disk and insert yours, if the same problem arises, change the Hard Disk or if nothing happens, system boots,
it seems a problem with motherboard, Get it repaired by a expert or buy a new one.this will work.
Enjoy !!! Thank you for using Fixya !!!
Nov 14, 2010 | Toshiba Satellite A135-S4427 Notebook
Unable to restore back to factory image read error
Are you using Factory CD/DVD or Made from utlity Disks or from hard drive utility option.
This seems to be a CD read error.
I found the same error code need help for posted for HP, Compaq, Gateway, ETC.
ALL new setups with the MAKE RECOVERY DISK UTILITY and NO factory disks.
Factory recovery disks are available for $60 and up from manufacturers.
Other option is Install Retail OS - get drivers from manufacturer - Install software you want to use.
Other option is expensive but reliable.
Factory option would be for your system only.
Apr 05, 2010 | Computers & Internet
Ibm thinkpad A31 Windows unable to start normally. Message on blue screen indicating "unmountable_boot_volume". Also got "Kernal_data_inpage_error" message. Does this indicate hard drive failure??
No, this is a known error within Windows. Read more information on it here: http://support.microsoft.com/kb/555302
But, if you are like me and don't like to read, just put your windows XP installation CD into the CD-ROM, boot up from the CD-ROM, DO NOT reinstall the operating system...just repair the installation and run "chkdsk /r".
Once that is done, restart the machine and it should boot up fine.
Jan 08, 2010 | IBM ThinkPad A31 Notebook
No read no write
One possible source of difficulty is there are different blanks for "slow" recorders (1x - 4x), "high speed" recorders (4x-10x), "ultra speed" recorders (12x-24x), and "ultra speed +" recorders. The disc manufacturers had to change the way the discs were made to accommodate each successive improvement, so older recorders don't work with the newer disks.
It is possible for some 4x-capable "slow" drives to use the "fast" blanks with a firmware upgrade, but there is no advantage to doing so since you're still limited to 4x recording (unless, of course, you're unable to find "slow" CD-RW blanks).
CD-RW discs for the faster drives are labeled with a "High Speed", "Ultra Speed", or "Ultra Speed +" logos. Make sure you buy the right blanks for your drive.
Jan 15, 2009 | LG (GCE-8527B) CD-RW Burner
Prism DVD-352P not loading any disks
What you are hearing is the attempt to read the disk. The unti detects that a disc is present and attempts to read it by spinning it first at CD speeds then at DVD speeds. It will attempt this a number of times before giving up and reporting "no disc". If you can get at the optics, try cleaning the lens using a cotton swab and alcohol. Next try to read a CD. If you can read a music CD and not a DVD, it indicates that the optics are starting to fail and need to be replaced.
Dan
Dec 18, 2008 | Televison & Video
My blueray cd is not reading
when putting disk in check by listening if you can hear the disk spinning at high speeds or a clickin noise, this means the laser is having trouble reading disk,try cleaning with a cd laser cleaner you can get these from comet argos pc world etc,if this does not work the laser may have burned out,one of the main faults with playstation and xbox is the fans that cool down the system also draw in dust through the vents wich inturn soil the laser lens hope this helps andy
Jun 22, 2008 | Sony Playstation 3 (PS3) Console
I can write cds and dvds and when you go to the disk drive on my computer you can see the items on the disk but when i remove the disk and then put it back in the drive does not read the disk for some...
if u trying to read another cd...
if can read..
mayb u write the cd speed to high..
if u write the cd speed to high and u cd drive speed is lower , u cannot open that...because your cd drive speed is low..
try to write cd use a lower speed,its mayb can be read..
happy trying.
good luck
Apr 17, 2008 | Computers & Internet
Computers & Internet Logo
66 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
