Philips tv 32pw9617 wont turn on red led flashes , looks like in protection mode , any help be good , thanks .
  • shooter q3 Jun 19, 2009
    Hi there , did some checking on the pcb & found the lop transistor was short , did replace this but was still having a sim fault , my guess is that the transformer is faulty .
    thankyou.
I had this on this model a year ago
Your power supply has blown
I had to courier it off to the Phillips service centre to have it replaced, they got it back to me the next day (this was in Sydney)
Hope this helps
Posted on Jun 13, 2009
Philips 32PW9617/79 wont work. flashing red light. wont turn on. heard a bang before it went off.
Yeah. that bang was most likely the bulb. They are meant to be replaced from time to time.
Google up your model and buy the best warranteed one you can find. Buy a "caged assembly" and not just a bare bulb.
Then unplug your tv and get a screwdriver. Follow your model's instructions and just snug down the electrical screws. Do not overtighten them.
Then consult your manual on how to reset the lamp timer so it knows you put a new bulb in and fires up from the first try.
Treat yourself because you've just saved yourself a trip from a repairman!!
Aug 12, 2010 | Televison & Video
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
Why wont my tv turn on? a red light just flashes
Right now, your TV is in " Protection Mode". A damaged part has occurred inside on one of the power supply boards. The red flashing light is a trouble code for a tech to trace the trouble circuit path.
If you have electronic experience with circuit boards, you can find a Service Manual for the TV on the internet for less than $20. This Service manual will have the schematics, red light codes, circuit diagram, and part number list you need to fix the board.
Oct 11, 2009 | Philips 42PF9631D 42 in. Plasma Television
Plasma tv in protect mode
One of the PCB's inside has an incorrect voltage/short or dry joint, all TV now days have a diagnostic startup mode which checks all the boards, one of yours threw up a problem so the TV put itself into Protect Mode so that it doesn't do anymore damage.
Get it checked out by an engineer.
Thanks
Oct 01, 2009 | Televison & Video
My tv 32pw9617 switches of by itself.
sounds lick you may have a dry joint in the powers or line o/p stage.
as a rare fault it could be the crt with an intermittant internal s/c. but you would notice the colour was tinted either red, green, or blue in the dark areas of the pic.
Jul 13, 2009 | Televison & Video
Blinking red led light
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
May 19, 2009 | Philips 34PW9846 34" TV
Red LED blinking after turn on the TV (Philips Plasma 42PF9631D
Mar 28, 2009 | Philips 42PF9631D 42 in. Plasma Television
Hitachi 60sdx88b
The flashing red light means that the tv is in protection mode. The tv will not turn on when the red LED is flashing. The most common problem for Hitachi are the convergence output ic's. But they useually do not cause the LED to flash. This tv does also have a problem with Q777 going bad. This will cause the LED to flash. If Q777 is bad the horizontal circuit needs to be modified. This must be done by a tech.
Nov 20, 2008 | Hitachi 60SDX88B 60" Rear Projection...
Philips 42fd9954-175
Hi, and unfortunately I am facing the same issue. My TV blinks GREEN LED for a few seconds then starts flashing RED led. The result I hear from this is that it is the SSB Panel and the estimated cost for service is $600.00 it sounds like you are STARTING with the problem. I began that way too. If you are under warranty, call Philips NOW!
May 13, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Tv will not turn on--- flashing red led
I'm sorry, I don't have a solution, but I seem to be having a similar problem. When I turn my TV on, the green light comes on like it's powered up, but then the TV turns itself back off and the red LED light flashes. I can't do anything to turn it on or anything.
Jul 11, 2007 | Philips 37FD9954 37 in. HD-Ready Plasma...
Televison & Video Logo
130 people viewed this question
Top Televison & Video Experts
Electro Med Services...
