Question about RCA HD52W58 52" TV
Rca hd52w58 the tv has yellowish spots on the left side of the screen, no matter what channel you are on, is there a solution to this, could there still be warranty??
    Genius:
  • 1,030 Answers
Could be burnt tubes or could be something on the optics .. sound like burnt tube.. burnt tube may be but most likey arent coverd in warrenty the tubes are about 250 to replace +labor and there are three. how big aret they quarter or size your hand? if the are small then they would be burnt tubes
Posted on Jan 18, 2008
SOURCE:
I turn on the tv and it turns on and off and the tv dont show a picture
Your lamp has burned out on the back of the set left or right side there is a door with 3-4 screws un-screw and pull out lamp tray. Buy lamp online or local and replace.
Oct 24, 2010 | RCA HD52W58 52" TV
Picture does not fit on screen anymore. ticker on most HD channels is unseen. what should i do?
go into your settings on your tv, most of the time you can adjust the picture size to your own liking good luck!
Dec 17, 2009 | RCA HD52W58 52" TV
I replaced the fl231 fuse in my rca HD52W58 and it went back out
Had the same problem , you have to resolder the flyback before replacing the fuse.
Jun 25, 2009 | RCA HD52W58 52" TV
Where is the convergance amp?
Accros the top of the chassi.conv power supply is to the left
Apr 23, 2009 | RCA HD52W58 52" TV
Anyone know why the picture would shake slightly
Does this tv have hdmi input and if so does the problem exist there?
If so I suspect the av input board could have a problem.
Mar 03, 2009 | RCA HD52W58 52" TV
Missing channels
You could have problem in SSB board the one that has tuners on it to replace ssb borad 253.00 plus labor Repair cost 445.00 use your external jacks for video see if you have the channels then. No more then 2 missing channels verses no channels and SSB cost,I would leave it alone. But if you need any of the boards to this set call 1-800-648-6657 UED
Dec 12, 2008 | RCA HD52W58 52" TV
Yellowish spot on the lower left hand corner of tv screen
Good Day, There is a device that can be used to correct your concerns. Symptoms can be correct by EE PROM CORRECTION TOOL:
LSUQ0100. Instructions included. Try calling 1-800-458-6053. It's under $100.00 and takes about 1 hour from start to finish. Good Luck, big IRISH.
Jul 07, 2008 | Panasonic PT-52LCX65 44" HDTV
Sony 42" grand wega LCD
We Cleaned the optic block as was instructed by another post. But now we have a wide ribbon of light yellowish to the right of our screen. Could it be more dust to be removed or now we can see there is more problems then we thought? Over all the screen looks much better. But a far cry from when it was new.
Apr 21, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Rca Hd52w58 electrical short
Just replace it... it is called the High Voltage Splitter. One red wire is the high voltage input from the flyback (high voltage) transformer, 3 red wires are the high voltage outputs that go to the 3 picture tubes and the red wire by itself is the focus wire going to the focus block. Does your splitter have a small PC board on the side of it? What is the exact model or chassis number of your set? With that info I can give you the RCA part number of the splitter which makes ordering it much easier.
Aug 23, 2007 | RCA HD52W58 52" TV
RCA HD52W58 52" TV Logo
57 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
