Question about Motorola Canopy 5.2 GHz Wireless Access Point - AES Encryption (5201AP)
I want to see my canopy speed beacause my signal is very low
  • 33 Answers
I would visit the speed test site www.bandwidthplace.com and select speed test and then select server nearest you. Hope this helps
Posted on May 21, 2009
I have a 2009 gmc sierra, where is the wiper relay location.
The PCB wiper relays are soldered directly to circuit board inside the under hood fuse box.
The windshield wiper/washer switch signal circuits are inputs to the body control module (BCM) and the BCM controls wiper motor low speed operation, washer pump and high speed operation. The windshield wiper/washer switch is provided a low reference from the BCM and each of the switch signal circuits is supplied 12 volts through a resistor and monitored within the BCM. During LOW or INTERMITTENT operation the wiper switch low signal circuit is closed to the low reference circuit through a series of resistors within the switch assembly and the signal circuit voltage monitored by the BCM will depend on the switch contact location to the resistor assembly. During HIGH or WASH operation the high and wash switch signal circuits are closed directly to the low reference circuit within the switch assembly and nearly all the signal circuit voltage will be dropped across the BCM resistors. The BCM controls the wiper motor through the WIPER CONTROL PCB Relay and the WIPER SPEED PCB Relay. During any wiper motor function that uses low speed the BCM supplies the voltage to energize the WIPER CONTROL PCB Relay and battery voltage will be supplied from the WIPER CONTROL PCB Relay through the de-energized WIPER SPEED PCB Relay to the wiper motor low speed control circuit. During high speed wiper motor operation the WIPER CONTROL PCB Relay is energized as in low speed and the BCM provides a ground to energize the WIPER SPEED PCB Relay and the battery voltage is supplied to the wiper motor high speed control circuit. Wiper motor park operation is controlled by the BCM using an input from the park switch within the wiper motor assembly. The BCM supplies the park switch signal circuit 12 volts through a resistor then monitors the circuit. Whenever the wiper motor is out of the park position the park switch signal circuit is closed to ground and nearly all the signal circuit voltage will be dropped across the BCM resistor. When the wiper switch is turned to the OFF position while the wiper motor is somewhere in mid-cycle, the BCM will continue to operate the motor until the wipers reach the park position. If the ignition is turned OFF while the wipers are in mid-cycle, the wipers will stop immediately where they are and the BCM will park the wipers the next time the ignition is cycled ON.
DTC B3715 02: Front Wiper Relay Drive Circuit Short to Ground
DTC B3875 00: Wiper High Speed Relay Circuit
DTC B3922 00: Front Wiper Function Select Circuit
Have it checked for DTC'S - diagnostic trouble codes .
The body control module (BCM) controls the wiper motor based on input from the windshield wiper washer switch. The BCM monitors the wiper washer switch through three separate signal circuits and a ground circuit. The windshield wiper switch high signal circuit is used to determine high speed wiper operation, the windshield wiper switch low signal is used to determine low speed, intermittent, and mist operation through the use of a resistor ladder, and windshield washer switch signal circuit is used to determine washer operation.
The BCM controls the windshield wiper motor through two output controls, controlling two relays which determine the desired wiper speed, high or low.
Your best bet , take your vehicle to a qualified repair shop or dealer . Hooking up a factory scan tool to see what the wiper switch inputs to the BCM are correct and outputs to relays are good .
Feb 11, 2017 | GMC Cars & Trucks
How do I find out if the wipers on my 2006 H3 Hummeris on a relay?
The Wiper/Washer System consists of the following components:
• Windshield wiper/washer switch
• Body control module (BCM)
• Wiper micro relay
• Wiper 2 relay
• Wiper diode
• Windshield wiper motor
• Windshield washer pump
• Windshield washer nozzles
• Windshield washer solvent container
• Windshield wiper arm and blade assemblies
• Windshield wiper transmission
• WIP/WASH 10A fuse
• WIPER 25A fuse
Wiper/Washer System Description
The body control module (BCM) controls wiper motor low speed operation. The washer pump and high speed operation are controlled directly by the wiper/washer switch. The windshield wiper/washer switch supplies voltage on the signal circuits to the BCM for windshield wiper/washer operation. When WASH, MIST, DELAY, LOW, or HIGH is detected, the BCM energizes the wiper micro relay by suppling voltage to the relay coil. This allows battery voltage from the WIPER fuse to flow through the relay switched input then through the contacts and out the relay switched output to the wiper 2 relay switch contacts. Since the wiper 2 relay switch contacts are normally closed to the low speed circuit of the windshield wiper motor, the motor will operate at low speed.
Low Speed Operation
When the wiper switch is in the Low position, voltage is supplied through an internal resistor to the signal circuit. The body control module (BCM) monitors the windshield wiper switch signal 1 circuit, and energizes the wiper micro relay which will operate the windshield wiper motor. The wiper motor will operate at low speed, since the wiper 2 relay is de-energized. Low speed can also be commanded with a scan tool, by commanding Wiper Relay Cmd. ON and OFF. Refer to Scan Tool Output Controls .
High Speed Operation
In the High position, the windshield wiper/washer switch supplies voltage to both the wiper micro relay and wiper 2 relay coils. This energizes both relays and allows battery voltage from the wiper micro relay switched output to the switched input of the wiper 2 relay through its contacts and out the switched output of the wiper 2 relay to the high speed circuit of the windshield wiper motor. The windshield wiper motor will operate at high speed. During high speed wiper motor operation the wiper switch signal circuit is at the low speed signal voltage, and the body control module (BCM) supplies redundant voltage to the wiper relay via the wiper diode.
This info is out of hummer factory service manual !
Dec 10, 2016 | 2006 Hummer H3
Abs clicks between 8klph and 3klph pedal pulses
When an abs system starts pulsing at low speeds when braking it is usually because the signal from one or more wheel speed sensors has become so low or disappeared altogether the system thinks the wheel has locked.
Loss of signal at low speed is often caused by corroded abs reluctor rings where they have lost tooth definition and reduced in diameter so the air gap has become too wide to produce an output at low speed.
Apr 12, 2016 | Cars & Trucks
Kubota m59 hyd system not strong
Check your hydrolic fluid. If low, be sure there are no leaks. If your fluid is topped off and there are no leaks then your pump may be going bad.
Sep 16, 2013 | Cover My Tractor Tractor Cab-Enclosure for...
Fan continues to wobble at all speeds.
Check to make sure you don't have a wire pinched between the Triangular ball and the canopy. If you don't have anything pinched between it, make sure your electric box isn't loose. If it isn't, pull down moderately on the fan with it off and move the fan around it's full axis several times, which should seat the ball into the canopy better. Almost every Hunter with the HandsFree canopy I've installed, I've had to do this little "procedure" which the manual says nothing about.
Apr 01, 2010 | Hunter 20763 52'' The Stratford II Ceiling...
Very low signal
Given that you have a '802.11B' device, the maximum speed will be 11 Mbps.
While your wireless router is communicating at that speed to your computer, the router is communicating with your ISP at a much-lower speed, depending on how much you pay per month to your ISP for the agreed-upon level of service, e.g., "ADSL-lite" or "High-Speed".
So, unless you pay more per month to your ISP, the "bottleneck" will be between your ISP and your router, *NOT* between your router and your wireless adapter.
Now, as to the "low signal strength", that's a matter of the distance between the router and your computer, and the number and composition of the walls and ceilings in the middle.
If you move your computer closer to the router, the signal-strength should become "good" or "excellent".
Nov 06, 2009 | Microsoft MN-510 802.11b (L21-00002)...
Conver the signal of old CRT to VGA signal.
we use the old CRT monitor made by motorola with TTL video signal and different vertical &horizontal frequency signals than monitor with vga signal.at now we can not replace crt with lcd .is there any interface to convert this crt signal to vga monitor signal for replacing the crt with lcd or vga monitor ,beacause this crt is discontinued and the quality of video is weak.if you needs the crt specification i will post it for you.thanks.
Jan 30, 2009 | Computers & Internet
SIGNAL PROBLEM
the radio has had an internal breakdown, possibly a transmitter or receiver failure. The only thing to do would be to replace or repair the unit. How old is it, as it may be under Motorola warranty if its less than a year. If it's not, you could contact Motorola support, and find out if they offer "flat rate" repair.....I know they do this for all of their 2 way radios and pagers, and the cost for repair is usually around 1/4 of new pricing. If you do get in touch with Motorola support, and have the unit's serial number handy, they will be able to tell you if its still under warranty. 1 888-605-2552 is the support number for Motorola canopy. They would be able to tell you if Flat rate repairs are available, and where to send the unit.
Dec 28, 2007 | Motorola Canopy 5.2 GHz Wireless Access...
NOKIA 6270 - Airtel GPRS
your nokia 6270 is EDGE enabled phone, that means you must get speed like 100 kbps with airtel gprs[mobile office].but you are getting too low speed its beacause of network there is not EDGE enabled till date, you have to wait for that when they upgrade their network services. so with normal gprs you obviously get slow speed its about 3-4 kbps only. so the thing is you cant do anything other than waiting for service upgradation or change your network with other service provider who provides EDGE enabled network.
Aug 16, 2007 | Nokia LD-1W GPS Receiver
Motorola Canopy 5.2 GHz Wireless Access Point - AES Encryption (5201AP) Logo
525 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
