Question about Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe grinds but plugs up at door
My Saeco Vienna de Luxe grinder keeps turning for about 15 seconds, then stops and the red light comes on. I cleaned out the grinder just to be sure it wasn't plugged, and then discovered that it grinds the coffee beans but nothing comes out because the spring loaded door stays shut. WHenever I open the door with my fingers, fresh ground coffee spills out. I have two photos I can send, one with the door shut, and one with the door held open showing a wire spring that may have jumped out - I don't know what it is supposed to look like normally. I have done a system reset. Nothing appears broken. I am currrently in Africa, a long ways from any service center.
    President:
  • 1,618 Answers
Try this: clean out the chamber, then set the grinds coarser to see if it makes a difference. If it does not then the micro switch or solenoid that controls the door is broken. Check resistance on solenoid it may need to be replaced.
Posted on May 11, 2009
Saeco Vienna grinds too much coffee.
Hi
If you have the Delux or Digital there are 2 knobs in the bean hopper. Turn the small knob back 1 mark and see if that will help.
Jul 12, 2009 | Saeco Vienna De Luxe Espresso Machine
Red warning light comes on and stops
put a cup under the water spigot and turn the knob to release the pressure
Dec 09, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe not transferring grounds to brew group?
Make sure there not comming any damp into the grinder and the grinder is dry. If there was some damp in the grinder then you have to clean the grinder.
Aug 07, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso is leaking water
It can be the steam valve or the boiler that is leaking.
Aug 05, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco De Luxe Coarse Grind
You could have knocked it out of its shaft or worse, Cracked the shaft itself.
Settings could be off too, It fairly common. Recheck the chamber, and make sure the plastic casing isn't cracked and the grinder doesn't wabble at all. It should be fairly firm.
If it isn't firm, bad news, cracked shaft.
May 08, 2008 | Saeco Vienna De Luxe Espresso Machine
Coarse Grind
il y a de l'eau qui passe en dessous du plateau avec du café moulu
Clogged Saeco Vienna de Luxe
Grinder sound like it is grinding to fine. Increase the grinder size. Remember to only change grinder setting when the grinder is spinning.
Hope this helps!
Sep 11, 2007 | Saeco Vienna De Luxe Espresso Machine
Grinder Won't Stop
Your circuit board has failed and you need to have it replaced.
Feb 14, 2007 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
238 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
