Question about Asrock M266 G-SALM Motherboard
Two beeps long
Why my cpu beeps long by 2 times? like this beeeep beeeep
  • 4,889 Answers
You DIMM(RAM) cards are loose. You will need to take them out and reseat them into their place so that the system will let you through. Tow beeps indicate memory testing failure so thats all you need to do.
Posted on May 10, 2009
    Champion:
  • 381 Answers
Hi..good day Mr./miss..if you want to solve that problem you need to open the CPU cover then remove easy the memory(SDR,DDR) then make a clean using a Paper/Eraser the Pin connectors..warning...!..use only eraser..Thanks
3 log beeps on power on
Gigabyte doesn't list 3 long beeps as an error code, so I'm not sure if you're actually getting 3 short beeps or maybe 1 long and 2 short or... But, for reference, Gigabyte's error code list is as follows (depending on whether you have an AWARD BIOS or an AMI):
(AWARD BIOS)
1 short beep: System normal
2 short beep: CMOS Error
1 long beep and 1 short beep: Memory error
1 long beep and 2 short beep: Graphic card error
1 long beep and 3 short beep: AGP error
1 long beep and 9 short beep: Memory Error
Continuous long beep: Memory not correctly installed
Continuous short beep: Power supply unit failed
(AMI BIOS)
1 short beep: Memory Error
2 short beep: Memory parity check error.
3 short beep: Basic memory 64K address check error
4 short beep: Real Time Clock malfunction .
5 short beep: CPU error
6 short beep: Keyboard error
7 short beep: CPU interruption error
8 short beep: Graphic card error
9 short beep: Memory error
10 short beep: CMOS error
11 short beep: CPU cache memory malfunction
It might not be a lot of help, but it's somewhere to start... and at least this way you'll know what to be listening for.
Nov 30, 2013 | Gigabyte Computers & Internet
Gives 3 beeps 2 short and one long
Dear Steve Thompson,
It will be Beeeep Beep Beep and it indicates failure of the motherboard's graphics section. Switch off power to your PC, remove the RAM stick/s, clean their contacts (and the sockets in which they sit), with a brush and replace them carefully and start over and see if it still gives you the beeps. If YES then get motherboard repaired if possible.
Most of the problems are solved simply by cleaning the RAMs contacts and replacing them.
Hope it helps.
Nov 06, 2013 | HP P5bw-la Basswood3g-ul8e Basswood3g...
Computer boots up and gives beeping noise, and monitor fails to detect computer.
Two components inside your computer is causing thins beeping sound. If the beeping like this, beeeep beeeep beeeep beeeep , then you have a problem with your memory card, clean your memory card and try to boot it again. If this doesent work, replace your memory card. If the beeping sound goes, beeeep beeeep bip bip. Then you have a problem with your video card. Try to clean it first, then reboot. If this has no effect, repace your video card... I hope this would have a positive effect on your computer. Have a nice day my friend.
Aug 20, 2011 | CyberPower C Gamer Xtreme 5212 Desktop -...
The computer makes a loud beeping sound 5 times
Mass storage device is a usb drive, flash memory etc.
If you disabled the usb device, it will no longer work, that is why you do not hear the beeping any more.
You need to get the correct device driver for your usb so it works correctly.
I hope this helps.
Good Luck.
Mar 13, 2009 | Computers & Internet
Abit nf8-v keeps beeping when turned on. no video
How is the beep sounds? Long beep and three short beep or one (-...) or all long beep?
For the first, usualy the VGA connector is not correctly seated, so the motherboard can say it has no output device and beeping.
The last is usually memory problem. Try, unplug your memory board and replug it again, make sure that it is correctly seated.
Dec 10, 2008 | Abit NF8-V Pro Motherboard
Communication error - error 388
Hi valmohr,
Please clcik on following link and follwo the document and tried to turn off the ECM on your printer, which would resolve this issue,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01345512&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Regards,  raj_p5983
Dec 03, 2008 | HP Officejet 5610 All-In-One InkJet...
E machine
power off at back of machine
replug cards
replug CPU
replug memory
repower
still beeeeep; then power off back and reset BIOS settings via jumper
still a beeeep; then go out for a drink or try another videocard
i meet more girls' videocards thanks to beeeeep.
Jun 24, 2008 | E-Machines eMachines Desktop PC
BCM BC875PLG Socket 4 ATX P4... Problem:
hmmm my sussgestion in yoyr case is that, don't attach all things at once. do the following step bye step.
Step 1). Attach SMPS, Front Panel Connectio, and an in built speaker and CPU (don't add RAM, HDD, FDD, VGA Card or any thing els)
Power on and watch:
Case 1: if you can hear a long beep, then you CPU and board is OK
Case 2: No beep means CPU or board is faulty. Try to Reconnect CPU again and do step 1.
Step 2) Now power off and add RAM only.
Power on and watch.
Case 1: if you can hear the ok beep it means till now your RAM is Ok
otherwise clean your RAM connection and add it again.
Further you can add your VGA, HDD CD-ROM/DVD, PCI Devices etc. and easily short-out your problem.
Thanks
Iqbal
Mar 12, 2008 | BCM BC875PLG Socket 4 ATX P4 800FSB DDR...
Lasko 2535
Lasko 52" tower fan, model 2535, works fine but has the annoying loud 3 second beeeep when turned on/off, waking us up at night. Have been unable to get at the circuit board to investigate due to non-std screws (regular slot head but with a bump in middle of slot, so slot is filled in in middle of screw head, if you will)
Any thoughts on killing the beeeeping?
Mar 09, 2008 | Lasko 2535 Stand (Pedestal) Fan
Asrock M266 G-SALM Motherboard Logo
43 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
