Question about Toshiba 52HM95 52" HDTV Projection Television
Toshiba 52HM95 HDTV has a red banner on top that won't go away...
It scrolls across the top indicating that a satellite or cable company (I have cable,) is conducting a test that gives a past date. It seems to be sponsored by KNST in Tucson, AZ. I live in AZ and my provider is COX cable, but they've never heard of this problem before. The reason I think it's related to the television itself and not the cable company is because it doesn't show up when the TV's channel info, or volume bar is on-screen, just when it disappears. I've read the manual from front to back, but can't find a solution...somebody help,
PLEASE!!!
P.S. I'm using their cable card but no antenna. Thanks anyone, in advance.
  • 3 more comments
  • javawinq May 10, 2009
    Wow, you guys are fast...thanks. There's only one other set in the house that uses straight coax, with no cable cards or boxes and it doesn't show the banner. No neighbors's sets don't show it either, which is why I think it's somehow tied to the set and/or the cable card. We subscribe to one movie tier and the expanded digital which gives us the HD programming. The Toshiba uses the built-in "TV Guide" feature so we can see the programming in grid fashion. Whenever we change the channel or adjust the volume, the banner disappears while the other info. is displayed, but promptly returns after channel/volume disappear. Needless to say, it's been very frustrating. I've tried unplugging the set and re-doing the setup, but to no avail. Any help would be appreciated, thanks again.
  • javawinq May 23, 2009
    Thanks for all the assistance, asnowman. Closed captioning was off. If it were turned on, the banner disappears. I performed a full system reset for the television via the configuration menus and the banner finally went away. Thanks again for the help.
  • John Snow
    John Snow May 11, 2010
    Have you tried to see if is associated with the Closed Captioning. Maybe the set is in "TEXT" mode. or you could try turning to CC1 and see if it competes whith the banner. Then turn CC off.
  • John Snow
    No other sets in the house or neighbors with the same problem?
    President:
  • 788 Answers
Javawing,
It is a good thing to have your set back to normal.
I was willing to try anything to resolve your set's issue.
Again, congratulations.
asnowman
If I have managed to answer your questions and have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot give this post a “FIXYA” (Two Thumbs Up) rating then please comment to this post and I will try to help you further.
I try to provide the best FixYa experience.
Posted on May 23, 2009
52hm95 blinking green light
have you checked the bulb ? has the picture been getting darker ?
Feb 24, 2014 | Toshiba 52HM95 52" HDTV Projection...
Need to fix RCA HDTV
model here is toshiba but you say RCA---you replaced the red tube?
Apr 18, 2012 | Toshiba 52HM95 52" HDTV Projection...
I have a toshiba TV, model 52HM95. The picture is flickering and vibrant colors, especially red, look odd. It's hard to describe, but it looks similar to an infrared image.
depends what source you use. if it is a hdtv source you might have defect cables or worse/wrong connection. if you use the built in tuner for tv channels might antenna signal has problem or even connector too. check different video (picture) sources like the antenna in, video in, y/c (chroma) in etc to clarify it is not the tv itself. if this can be excluded then the tv has a problem, please let it then check by your local service.
regards
Mar 12, 2011 | Toshiba 52HM95 52" HDTV Projection...
Toshiba 52HM95 whirring noise
Color wheel. Not replacable on this set. Removing light engine and having rebuilt is only solution. Part no longer available.
Nov 17, 2009 | Toshiba 52HM95 52" HDTV Projection...
Toshiba 52hm95 will not come on , red light blinks
It is the Light assembly engine. Happened to me It is $700 to fix and the wanartee on the new part is 3 mos
Aug 13, 2009 | Toshiba 52HM95 52" HDTV Projection...
PICTURE IS OUT WHEN I TURN THE TV ON THE RED & GREEN LIGHTS FALSH
Most Likely you need to replace your bulb. On Page 99 of the owners manuel is the LED indications chart. (you can download the manuel here) You are probably having indication number 3, which means the bulb is done. You can find new bulbs on Amazon and e-bay. I recommend you buy the Toshiba brand bulb and not a knock-off, I have heard that they may not last as long and do not look as good.
Jan 16, 2009 | Toshiba 52HM95 52" HDTV Projection...
No audio on one channel
I've seen simmilar problems with the toshiba cable card compatability.. however we could never solve (replacing all parts,etc). It is either the tuner of the television malfunctioning at a very specific frequency, a very specific interference, or a programming/software issue between toshiba and cable provider. The first is repairable with parts, the second two are not good. With either you'd have to keep complaining to the manufacturer and cable company, both of which will likely get you now where. They make more $ on that cable box..
Nov 29, 2008 | Toshiba 52HM95 52" HDTV Projection...
Toshiba 52hm95 DLP HDTV - no sound
What cables are you using? Some TV's and DVD players have options to set your audio source. My DVP5982 I have to set it to HDMI digital audio, check to see if you have that on your TV.
Jul 04, 2008 | Toshiba 52HM95 52" HDTV Projection...
Toshiba 52hm95
I'm not sure if you are aware of this, but the 52HM95 tv has 3 fans inside. I believe one of them runs all the time.
May 24, 2008 | Toshiba 52HM95 52" HDTV Projection...
Toshiba 52HM95 52" HDTV Projection Television Logo
98 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
