How can I stop my T5000 2-way from beeping everytime i release the talk button? i work in a rather quiet workplace and would like to fix this problem if possible
Here is a link to the user guide page http://shop.giantintl.com/Manuals.asp?offset=30
On many TalkAbout radios you can shut off the beeps by holding the PLUS button while turning the radio on.
SOURCE: Motorola Talkabout T5100
I think you have to remove the courtesy beep option from radio, this is also call Roger beep.
SOURCE: Motorola Talkabout Basic
I believe you do not need to hold the monitor button when changing channels
Push the talk button till you have the channel you want then push monitor button to accept
Hope this works
SOURCE: lost my owners manuel. when releasing the talk
To
disable the ”Roger” Beep feature, turn your radio off and then back on while pressing and holding Scroll +
button.
Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T5XXX_User_Manual_E.pdf
SOURCE: When pushing the push to talk button either on the
Two thoughts, I know you've replaced the batteries, but this can be a sign of a low, bad or weak battery. You might check your charger to see that the light is coming on and staying on during charging. Also, be certain the radio is shut off during charging.
Secondly, be certain when using any audio device the radio is shut off when plugging in the audio device. And the device is designed to go with the radio you are using it with.
Troubleshooting thoughts: 1) Try a battery directly out of a working radio to see if the problem stops. If the problem persists, you have a radio or device problem. 2) Try the radio without the audio device, with a known good battery. If you still have a problem, you have a radio problem. 3) Try your audio device on a known good radio. If there is no problem, your audio accessory is okay.
Best regards.
SOURCE: Motorola T4500 two way radio. Can't
The T4500 is a stripped down version of the TalkAbout radios, it does not offer an option to turn the Roger Beep on or off. Sorry.
Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4500_User_Manual_E.pdf
Best regards.
