Question about Kenmore 53542 / 53544 Side by Side Refrigerator
Refrig is hot to touch
Kenmore Model number 51562101 Side by Side Refrigerator about 8 years old. Its very hot between the two doors, almost burns to the touch. I cleaned the coils under the frig the best I could but its still very hot. HELP ME I'M MELTING!
    President:
  • 1,136 Answers
Hi, Have you checked to see if there is a frost build up in the freezer? How are the temperatures in the fresh food side or the freezer side? Check and make sure the evaporator motor is running in the freezer. Please let me know if you find any of these issues. When that area is hot, usually there is more going on and the temps are not right. Let me know so I can assist you further.
Thanks
Vic
Posted on May 13, 2009
I don't know the model number but our refrigerator is approximately 6 years old and is a side-by-side model. My problem is that the metal frame that separates the two compartments which touches the rubber...
Usually when the outside of the refrigerator is hot, there is some problem in the refrigerant cycle. I suspect that if you reach under the refrigerator and touch one of the coils, it will be very hot, too.
First, look at the coils and see if they are dirty. If so, clean them good. Second, the compressor should be running properly (I assume it will be.) Third, make sure the compressor fan is turning. If this fan doesn't operate properly, the heat in the compressor coil will not be removed and transferred to the room air. It certainly sounds like the heat is not being removed from the coil since it is so hot.
If the compressor fan is not turning, you will likely have to replace the fan motor.
Oct 19, 2009 | Refrigerators
Kenmore refrigerator top door freezer surfaces are hot to touch.
Sounds like the mullion heater is on. This heater is used in very humid climates to prevent refrig from sweating in summer. Find the switch for this and turn off.
Sep 14, 2009 | Refrigerators
Kenmore Refrigerator Ice Maker
ck condensor fan motor that cools compressor under unit. yoder loop runs through center divider and causes gaskets to get hot
Aug 26, 2009 | Kenmore Freezers
Divider between freezer and fridge is HOT to the touch
That is a heat strip to prevent condensate near the door seals and yours is possibly shorting out because the control fo it is defective. Send me the model number for your Roper and I will look at the diaqrams to confirm my theroy. Thanks, Sea BreezeEnter your model number at the link below and it will take you to the parts and photos.http://servicepartstec.blogspot.com
Jun 05, 2009 | Roper RS25AEXLQ Side by Side Refrigerator
Trouble locating model numbers
i put your model number into the system its here, what did you need? you want to replace the refig with the same refrig??? if htat s the case take your model down to the sears showroom and the salesman will be able to locate the latest year model number for you. the number you have is probably a few years old they have moved on to new numbers,possible same dimensions just differnet numbers
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd;jsessionid=Bgl2MEGpgV3YgMXSX1xt+w**.shcapp3005?modelNumber=106.53603202+&pop=flush
Nov 26, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore refrigerator not cooling and lights out
is the compressor hot? same as last job. unplug ref. clean the condenser coil, install new 3n1 start relay on compressor.
Nov 04, 2008 | Kenmore 53642 / 53644 Side by Side...
Freezer works ok.refrigerator temp varies from 39 deg.to 60 deg.
check to see if there is frost in the back of the freezer if so you have a defrost prob..
Jun 20, 2007 | Kenmore 44109 / 44102 Side by Side...
Kenmore 53542 / 53544 Side by Side Refrigerator Logo
163 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
