Question about Cadet Manufacturing American Standard 2366.100 Cadet Pressure Assisted Flush Toilet
My Pressure Assisted toilet does not have the power to flush
Hi, my name is Patty. I have an American Standard pressure assisted toilet in my upstairs bathroom. It was installed in December of 2000. Up until now, it was running great. But now it does not have the power or force that it used to have when you flush. I called the plumber on Friday, 5/08, but they will not be out until this Tuesday, May 12. Luckily for me, I have a second regular toilet to use in my basement.
Anyway, what would be causing this to happen? I hope that the plumber will be able to fix it and not tell me that I need a brand new toilet. My model number is : M-101526-F3
Serial number is: 103000-F3A-1115
Series No: 503
Purchased at Home Depot
Also, are these type of toilets more expensive to repair? I was just curious how much would it cost with labor and parts, etc, estimated ballpark figure of the total cost.
Any advice would be greatly appreciated!
Thank you so much!
Regards,
Patty
Omaha, NE
My upstairs toilet burps air when flushed all other toilets ok
Your vent stack may be clogged. The pipe that goes up to the roof. Let's air into sewer pipes when you flush. A birds nest or something can do it.
Mar 10, 2015 | American Standard Home
Do you turn the screw to the left or right on a american standard toilet to adjust the water level in the toilet tank
Usually to the right will drop the float, deceasring the water level, left will increase the water level.
Aug 25, 2014 | Cadet Manufacturing American Standard...
50 year old American Standard toilet . Bowl fills up ,makes noises like it's pluged & then flushes
You have a blockage in the trap as the water goes out . What happens is that there is so much pressure with the water building up in the tank,, that it finally pushes the water out. Also check the vent above the toilet which is located on the roof. It must be free of debris to allow the pressure to stay equal and not a vacuum.
Feb 18, 2013 | American Standard Traditional Champion4...
Elijer Diplomat toilet flushes perfectly, but after the water in the bowl takes forever to fill up again. You have to wait 10-15 min. before the water is up to normal level and it will then flush...
Pressure assisted toilets have a stainless steel tank that refills under lid,if your refilling bowl it only needs to fill trap for smell,the pressure assist does the rest,thats part of the water saving of the toilet,you don't have a lot of water in the bowl
Jan 28, 2011 | Eljer Aqua-Saver 12" Two-Piece...
Tank serial # looks like this? S 00 K 4520 ...
that is a Kohler model 4520<br /> the other numbers are for manufacturer codes.<br /> <br /> is this an older toilet? Kohler discontinued that model.<br /> <br /> <a href="http://www.designtool.kohler.com/us/detail.jsp?item=9654702">http://www.designtool.kohler.com/us/detail.jsp?item=9654702</a>
Aug 31, 2010 | Cadet Manufacturing American Standard...
American Standard toilet rear gasket is leaking
Check that the two bolts holding the tank are tight, if they are then remove tank and replace the gasket
Nov 06, 2009 | American Standard Glenwall Pressure...
We just replaced out toilet because we had no flushing power on the old one. After cleaning the vent pipe and using a snake and putting on the new toilet, we still don't have any pressure when flushing...
its got a blocked down pipe lime scale will do this to you, the only way to sort it out is strip it out completly and give it a good clean, if that still failes to flush then its the flushing pump needing looking at,
Oct 25, 2009 | Cadet Manufacturing American Standard...
Can't locate serial number
get a mirror and look behind the toilet by the rim, under the tank and inside the tank above the water line
Aug 03, 2009 | Cadet Manufacturing American Standard...
Cadet Manufacturing American Standard 2366.100 Cadet Pressure Assisted Flush Toilet Logo
1,382 people viewed this question
Top Cadet Manufacturing Home Experts
Donni Steen
Tom Chichester
Are you a Cadet Manufacturing Home Expert? Answer questions, earn points and help others
