Question about Sony Playstation 3 (PS3) Console
When i turn the power button on on my ps3. it goes green then flashes yellow then keeps flashing red. i cant get it on.
  • ardak May 10, 2009
    When i turn the power button on my ps3. It goes green then turns to yellow then it flashes red.
  • Anonymous May 23, 2009
You have the YLoD like the RRoD its either overheating or system failure.You need to call sony to get it fixed.Check in the instruction manual for the number.You cannot fix it
If you do get it fixed vaccum it once a week,don't play for more than 6 hours,keep it ventilated,make sure the fan can blow out into the room not into one space,the best place to sit a ps3 is a glass surface
hope this helps
Posted on May 10, 2009
After pressing the on button it turns green for 5 seconds then it flashes yellow/orange for a second then it flashes red.
Yellow Light of DeathThe "Yellow Light of Death" or YLOD is the common phrase people use to describe the following sequence when they try to turn on their PS3:
  • Press Power Button
  • Red Light Flashes Three Times
  • Yellow Light Flashes
  • Green Light Flashes
  • Beeps Three Times
  • Red Light Flashes
The sequence above may vary a bit but you do see the flashing yellow light (sometimes shows up as orange) that normally you would not see when operating your PS3. The YLOD is a general hardware fault that can mean a lot of things. However, one of the problems is cracked solder that leads the PS3 to think one of its internal chips is not connected or is broken somehow. Cracked solder can happen when the chips get too hot (RSX most likely) and leads the motherboard to start bending, which may crack the solder. Changing the power supply (lower the average wattage going to the chips to lower the heat) and better thermal compound (heat dissipates faster to the heatsink) may prevent this error from occurring. However, if your PS3 has already had the YLOD, then you can reflow your motherboard every few months to keep it working (but it is not a permanent fix as the YLOD usually comes back).
Oct 09, 2010 | Sony Playstation 3 (PS3) Console
Red light, turn on, goes green, flashes yellow then flashes green
connection problems or power surge connect to surge protecter
May 01, 2010 | Sony Playstation 3 (PS3) Console
My playstation has the light trun green yellow flashing red light
With your PS3 turned off, press and hold the Power button on the front of the PS3 for about 10 seconds (the system will beep as normal as it starts up but after 7-10 seconds it will beep again). The video settings should now be reverted. Doing this will also reset any theme settings. try this? seems to fix alot of issues.
Jan 22, 2010 | Sony PlayStation® 3 (80GB) Console
My ps3's power light goes from green to yellow and then to red and then swithchs off? anyone with any ideas wats wrong? many thanks
ps3 . when i turn it on the green light comes on then goes flashes yellow then goes red and will not come on
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
My ps3 it goes green beeps twice then goes red and flashes on/off
you might be holding the power on button to long. you hold the power on button until it beeps to reset the video output. try turning it on by using your controller. just press the ps3 button and if the red light is on then it should come on.
Oct 14, 2009 | Sony Playstation 3 (PS3) Console
I cant start up my console
Your system has overheated. The thermal compound has heated and moved away from the CPU/GPU and the heat sync keep the heat from being dissipated via the heat sync. Eventually you will get the YLOD which is the equivalent of the Xbox 360 RROD. This is due to heat sysnc problems. Your CPU and GPU will more than likely need to be reflowed. I got the YLOD on my PS3 around the first of March 09. I also fixed my PS3 in about an hour. I have had no problems since. You can slow the YLOD but i dont believe it can be stopped. It seems it will eventually happen to all PS3's. One tip do not stand the PS3 on its side keep flat. This will help keep the thermal compound from moving as much when it heats up. Also i run a home based computer repair business in southern California. Feel free to email me at dwdpcrepair@gmail.com.
Jan 18, 2009 | Sony Playstation 3 (PS3) Console
PS3 won't turn on
hi Torgsrus.
PS3 Light sequence
The following pictures illustrate the CECHX0X model, however the light sequence is applicable to all PlayStation 3 models.
No lights are on:
When no lights are on, this means that the main power switch on the back of the ps3 is off or the PS3 is unplugged. When the main power switch is off (the '0' is pressed) and you will not be able to access any features of the PS3 system. To turn on the PS3 system, make sure the main power switch is on (the 'I' side is pressed down).
If the PS3 does not turn on:
· Make sure the power cord is not frayed or damaged
· Try using another power cord, if available
· Make sure the main power switch on the back of the PS3 system is turned on
· If you continue to have issues contact our Technical support.
Solid Red:
When the power status light is solid red, this means that the PS3 system is off (or in standby mode).
Standby, mode means the PlayStation 3 system is off, but is ready to be turned on by pressing the power button.
If the ps3 system will not turn on when you press the power button, this is an issue with the PS3 system and you will need to send your system in for service.
Solid Green:
When the power status light is solid green, this means that the PS3 is turned on.
You should be able to navigate the XMB, play games, access the Playstation store,etc.
To turn of the PS3, simply press and hold the power button for two or more seconds.
If the power status light is green ,and you are experiencing problems- have a look on our forums for troubleshooting.
Flashing Red:
When the power status light flashes red after using the PS3 system for 3 or more minutes and shuts off, the PS3 system has possibly overheated.
This may be caused by poor ventilation or the vents may be blocked.
If this happens:
· Check to see if the vents are blocked. If the vents are dusty, vacuum the vents to remove the dust.
· If the PS3 system is in an enclosed area like an entertainment area, move it to a more open area.
· Leave the ps3 system off for 30 minutes to let it cool down.
· If you continue to have issue, you may need to send the console in for service.
Flashing Green:
When the power status light flashed green, it means that the PS3 system is turning off. Please wait while the system turns off.
If the PS3 system does not shut down immediately, it may be trying to finish save data to the Hard Drive. If it is, do not turn the main power switch on the back off as it may cause data on your hard drive to be corrupted.
If the green light continues to flash green, the ps3 system maybe trying to write to the hard drive, shutting down or running programs. It may take longer to shut down depending on when you pressed the power button. If the green power light flashed for a very long time, you can try holding the power button down for 5 seconds, the console will beep and should turn off. Then try to restart the PS3 system.
Flashing Green, Yellow and Red:
When the power status light goes from green, to yellow, to green, then to a flashing red, this means that they may be an issue with an internal part with in the PS3 system. This may be caused by a variety of reasons and would need to be diagnosed by our support line.
When the PS3 power light flashes in this order, you can contact our Support Line for further assistance.
Solid Blue:
When the disk status light is remaining a solid blue, it means the disc is inside the PS3 system. If you wish to eject the disc, hold down the eject button for 2 seconds and the blue disc status light will flash indicating the PS3 system is attempting to eject the disc . (NB: the power indicator light will always be a solid green).
If the disc is inserted into the ps3 system, but does not show up on the xmb or will not play, this may indicate an issue with the reader- check our guide Discs are not loading in my PlayStation 3? for further troubleshooting.
Flashing Blue:
When the disc status light is flashing blue, it means a disc was just inserted into the ps3 system or a disc is trying to eject from the ps3 system. Depending on when you pressed the eject button, it may take longer for the disc to eject. (NB: the power light will always be a solid green)
If the light constantly flashes blue, it may be an issue with the disk being stuck in the system. If this happens there is no way to remove the disc yourself if you are using an orginal 60GB PlayStation.
Dec 02, 2017 | Sony Playstation 3 (PS3) Console
Well when I turn on my ps3 the green light turns into a yellow light some people call this the yellow light of death after it goes yellow it turns into a flashing red light I try to repaet it but it keeps...
well yes obviously the flashing red light means that if u do not turn off ur PS3 it will die. but depending on how long u have had ur PS3, it may be becuase the life span is almost over.
if u have not had for a couple years it is most likely a manufacturing error
u should send it in to sony before the warranty is up and have them take a look at it
Jul 25, 2008 | Video Game Consoles & Games
Sony Playstation 3 (PS3) Console Logo
253 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
