Question about Mackie SWA1501 Subwoofer
Thermal light came on at power up and stayed on. No sound came out.
Hi, My swa1501 was working fine 3 days ago. Tonight when I turned it on the Thermal Protection light came on and no sound came out. I swapped the EIC cord just in case it was bad and I left it on for a while to see if the thermal circuit would reset like it's supposed to. Neither solution worked. The unit was cool and had plenty of airspace behind it. Can you point me in the right direction? Thanks, Chris
4 Suggested Answers
XSdB
  • 80 Answers
SOURCE: Mackie SWA1501 Base Bin - Circuit Boards burnt.
They are not publicly available. Mackie authorized service centers are the only places that will have that information. The amp (if it has failed) requires a bit of skill to rebuild, and up to 100$ in parts alone. (not including the speaker driver if it's blown). I have repaired several of these in the past, and they aren't that simple. There is also a service bulletin about 2 diodes that usually need to be swapped with one another because of a defect during manufacture (the parts were installed incorrectly). (One is D20) if you rebuild the amp, and fail to address the diodes, it will fail again very shortly.
Posted on Jun 12, 2009
SOURCE: Hi, my does not power on. When I turn on the
Hay asanchez23, had the same problem, turned out to be the switch. I just moved the wires on the switch to the other poles. (switch is a Double pull, single throw) it only uses two to the four poles.
Posted on Jan 23, 2010
Testimonial: "I got such a terrible year at work that I abandoned my subwoofer and never checked back until today. I followed your advice and it worked! Thanks!"
turinband
  • 7 Answers
SOURCE: mackie 450 thermal light on no sound
could you give some more info? what are your running into your speaker? and how exactly is it run? once we weed out common issues like switched up cables, than we can move on to internals.
which on that note, I think this is a manufacturing defect
here's a link to the schematic if you want to go poking around the circuits.....
http://www.mediafire.com/?myion3zkxn3
or
http://www.mediafire.com/file/myion3zkxn3/Mackie-SRM450 actspk.pdf
take a resistance test between D56 pin1 and Q35 pin2. thats where this issue seems to be stemming from from ones ive worked on. I have know it to be an internal track that was broken and needed to be glued back down. definitely not the first time ive seen this....
Posted on Dec 08, 2012
3 weeks ago my car would not start, replaced battery and it has been fine till tonight and it would not start.
3 days on a new battery, yes it is significant. Four things can do this in a short time. alternator, starter, radio, and interior lights/ light switch. Alternator can be checked on the car, A sign for the starter is that it may drag or drag sometimes. Radio is lights staying on after the door is opened,Even the clock. Light switch is interior lights don't work or the dimmer switch doesn't work. These are just suggestions that I have run across. They still need to be checked. It can get costly.
Feb 12, 2015 | Cars & Trucks
Frigidaire Furnace model #FG6RA-096C-16B status light blinks 3 times.
Pressure Switch is Closed with Inducer Off. The inducer will only kick on if the pressure switch is open to initialize the call for heat.
Dec 07, 2013 | Heating & Cooling
My 2003 Mercury Mountaineer has an electrical problem. It started about a year ago with the key fob not working, I have bought 3 and all won't work even after re-programing. now tonight I went to
Could be a windshile leak down the A-Pillar & water
gets into the delayed accy relay for the GEM Module
(Body Computer as ford called it for a few years) & you
get what you have now
Try Goolge as I did a few weeks ago for a relative
He had the same issue with the blower being on &
killing the battery
No real fix I found for the windshield leak
Seem a robot didn't put the rubber sealant
on correctly at the factory fo about 5 years
on several fords.
If it isn't water related then the GEM Module
controls all those body features
If you get a used one & match up the numbers,
you supposedly can avoid buying a reman gem
& the expense of having to reflash it to your factory
built combination
Jan 27, 2013 | 2003 Mercury Mountaineer
Purchased a 46' RCA (46LA45RQ) less then a week ago. Tonight, cannot turn the power on by remote or panel. The power indicator lights up red indicating that it has power, however it will not power on. Any...
Hi there ,its sounds like the classic case of electronic field interference that can freeze most electronic items nowadays from time to time ,simply unplug the power plug from the wall and plug it back in after 5 minutes ,it should be fine now ,thank you for using FIX YA
Apr 20, 2011 | Televison & Video
Heater less than 1 year old. Worked fine 3 days ago; tried turning on tonight and got a "E01" in display. Anyone know what that might mean?
E01 is low system voltage. This can be caused by 3 things. Either the incoming power is incorrect, the heater is connected to wrong voltage, or the tranformer is not outputting the correct voltage.
Check voltages going into the heater, if these are all correct, then replace the transformer
Feb 06, 2011 | Pentair Minimax NT Heater
Turn on unit. Red power light is on. No picture, no sound. Turn unit off, hear a click and a small square flash on the screen. Did the same thing 2 months ago, let it sit for 3 days and then it was...
It seams to be a problem in video and video out put stage some TV set design there is no video signal the sound out put also not working this TV high voltage ( horizontal out ) is working fine that why flash squre visible when the sw off. may be dry joints in the video section or some auxilary power supply cricuit feeding power to video section having a problem
Sep 04, 2010 | Toshiba 27A60 27" TV
M1991 screen stays black, little light is yellow
The fault is a back-light problem and the fault could be a faulty inverter board or a faulty CCFL lamp.
For service, parts and DIY info check out LCD Parts WEB site, please click on this link :-
www.lcdparts.net
Mar 15, 2010 | Dell Computers & Internet
Sw 1501 no sound output
in my dvd dts audio is not playing
Feb 13, 2009 | Mackie SWA1501 Subwoofer
C-8080 Turns off/on randomly..
Hi Galaxy,
Try running camera directly on DC from charger and see if it stays functioning.
If it does, they you either have:-
1) a faulty Lion battery
2) the battery detect circuit in the camera is faulty (reporting low battery and forcing shutdown)
3) the power switch on top of the camera may be leaky or partially collapsed
4) internal power supply circuit in camera has developed a fault.
Good luck...hope that the issue is the battery.
Kiwi-Mark
Jun 05, 2007 | Olympus Camedia C-8080 Wide Zoom Digital...
Mackie SWA1501 Subwoofer Logo
246 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
