Question about Toshiba Gigabeat MEGF40S MP3 Player
Computer does not recognize Gigabeat Device
On my old computer the device worked well.  I recently bought a new computer (using Windows Vista).  I downloaded the Gigabeat Program with no problem - the program opens to the Gigabeat Room and it recognizes the music on my PC and on CD's, but it does not allow me to open the gigabeat device (to see all my music on my MP3).  What can I do to get my computer to recognize the Gigabeat Device so that I can get back to putting music on it??
  • 6 more comments
  • Richardtosh Dec 23, 2007
    I have the same problem except that my device is an MEGF20 MP3 player. My new PC has Windows Vista but it does not recognise the Gigabeat, so I am unable to play music, exchange files, synchronise etc. using Gigabeatroom 2.02.2. Thanks if anyone can help.
  • Jnay Feb 11, 2008
    I bought a new laptop and am unable to load the disc that came with my Toshiba of 3 years. Need the firmware or other means to be able to sync with my Gigabeat.
  • ChellB Apr 23, 2008
    My new Windows Vista computer does not recognize Toshiba Gigabeat or the Gigabeat room software. The gigabeat shows an error message saying "no file found" with every track. How do i get back to playing music and transferring files?
  • ak_swam Sep 02, 2008
    After resetting the Gigabeat, my computer / XP does not recognize the device. Thanks. Arun
  • Anonymous Sep 26, 2008
    My computer's settings were reset and now it does not recognize the software either. I have tried using the installation CD but no luck. I still have Windows XP so I'm not sure what the problem is. Also the buttons on the Gigabeat have stopped working.
  • Supersheep Oct 11, 2008
    I've got a Gigabeat MEGX30, my sister has exactly the same model. She has no problems connecting via her WinXP laptop, but Gigabeat Room on my WinVista desktop does not recognise the player when it's plugged in.
  • Mudhoney Dec 21, 2008
    Have a F20, personnelly have always hated it, think it is rubbish and not very good to use. Now have a vista computer can't get a download to have gigabeat room to load on music. Think may have to dump and save up for an ipod think Toshiba Gogabeat is the worst item I have every bought. Would be nice for Toshiba to have a simple download of Gigabeat for Vista, can't be that hard to sort.
  • frica Feb 14, 2009
    my new laptop just turns the gigabeat on and off, say it does not recognize. could not find software on toshiba site..... not happy!!! i will be calling toshiba.
The solution is simple. Simply Run both Gigabeat watcher and giga-room programs as administrator if u have windows vista.
How to do this :
Click on start in the taskbar at the bottom right of your screen,
then click on all programs,
then click on the Toshiba Gigaroom Folder,
then right click Gigabeat watcher and click on "Run as Administrator"
then right click "Gigaroom" and click on Run as Administrator
and then look in the bottom right of the taskbar, the little Gigabeat watcher symbol should be there with a green square instead of grey. If its green then it means Vista has recognised your gigabeat and u can now transfer music to it via gigaroom. i hope this helps people as i was on the verge of buying XP myself again... Peace all and HAPPY GIGABEATIN!
DREZO 9/3/2009
Posted on Mar 09, 2009
  • DREZO Mar 09, 2009
    start is on the bottom left of your screen, sorry i wasnt paying attention to what i was typing.
I have Vista and A Toshiba Gigabeat medf20 and gigabeat room 3.0 U.S.
The solution i've found was to change the compatibility mode to run the program as an administrator.
select the windows button
then all programs
then TOSHIBA gigabeat room 3.0
right click on gigabeat room 3.0 and select properties
select the Compatablitly tab
check Run this program in compatibility mode for
select "Windows XP (Service Pack 2)
Next Check the Run this program as an administrator
Click okay and re open the program.
Posted on Jan 20, 2009
  • 3 Answers
Right click on the program icon and run as administrator.
good luck!
Posted on Mar 19, 2009
Here is a good link for updating all gigabeats. www.gigabeat.com.au/support.htm Just follow the f-series links for the f20, f40 etc. Then download the version 3 software. It's easy and updating the actual gigabeat is a clear walkthrough though mine would NOT update. It said 'can't update' in the window but it works FINE on my vista home premium pc which would not tolerate the old version 2 original disk that came with the player.
Posted on Mar 05, 2009
Here's the latest link for firmware update to your gigabeat MES30V/60V device. This will allow easy recognition with Vista OS.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2265393&rpn=&modelFilter=MES60V&selCategory=6&selFamily=727858
Works perfectly
Posted on Jan 12, 2010
Megf20, toshiba software 3.0 and vista sp1
i check toshiba watcher with compatibility wizard for windows xp sp1 and now the medf20 is detected and toshiba room see the unit But when i try synchronise or transfert bang BSOD and reboot of the machine.
Posted on Jun 18, 2008
I have almost all of the same problems, only difference, I am using XP. I have been trying to get this thing to work for 4 hrs today. I have uninstalled and reinstalled several times. I do see the unit in the computer but Gigabeat room does not open. I click on the icon on the desktop, the system thinks for a few seconds, then nothing. Any sugestions? Thanks
Posted on Jun 11, 2008
Http://www.toshiba.co.th/download/support.html
I came across this link, its a firmware / software update.
Install this and vista should recognize gigabeat.
Vista does not recognize ANYTHING, if you have XP then KEEP IT.
I have learned about vista's compatibility issues the hard way,
and now im stuck with Vista and lovely payments from Dell.
Posted on Nov 28, 2007
The solution is simple, install xp on your main pc, you'll have a better performance and no softwware-problems, i now vista looks "pretty" but it's not very functional yet
Posted on Oct 22, 2007
Download the Gigabeat room 3.0 software (google it and find a megaupload link to the software) adn the Gigabeat should now be functional with Vista. The only problems i am having is that the Room does not always recognize when the Gigabeat is connected. Other than that, the 3.0 version is much better than previous ones.
Posted on Sep 12, 2008
My T400 windows embeded toshiba gigabeat is fully charged and is not turning on. what should i do? i plugged it into my windows xp computer and my computer told me the USB device that is connected is...
sounds like something inside has shorted or blown. when you plugged it into windows did it say power surge on hub or did it say USB Device not recognized
Mar 03, 2011 | Toshiba Gigabeat T400 MP3 Player
Vista recognises Gigabeat F40 as a hard drive and not an Mp3
hi had the same problem with mine, you must use the dock and have the connections setting set to media player it will sync then
Dec 05, 2008 | Toshiba Gigabeat MEG-F20S MP3 Player
Archos 404
Archos is not claiming compatibility with vista, even with their latest firmware upgrade - sorry
May 08, 2008 | Archos 404 Digital Media Player
Toshiba Gigabeat
try using windows media player it does work if you go to the setting file on yor f20 and slect media player in the pc connections folder
Apr 20, 2008 | Toshiba Gigabeat MEG-F20S MP3 Player
I have a Toshiba Gigabeat F60 from several years ago. It stopped working shortly after I got it and now I would like to try to get it working again. Upon start up it says "no system found oh HDD" but my...
The Gigabeat is not recognizing the firmware on it. The easiest way to re-install the firmware is to install Gigaroom. It will be able to recognize the Gigabeat and replace the firmware.
Apr 06, 2008 | Audio Players & Recorders
Win Mobile Device 6.1 Vista will not Connect
Slmgato: have you tried to delete the old pairing on wmdc?
also to the other users: check the usb charge port on the tilt. Make sure it has not been bent or the pins have not been damaged. My tilt recently was damaged and now i can't charge or sync, but i can buy the replacement port for about 10 bucks and solder it myself.
Mar 18, 2008 | AT&T 8925 Tilt Smartphone
Check the manufacturers website for specific Vista drivers.
Mar 08, 2008 | Philips GoGear HDD075/17 MP3 Player
Gigabeat u202 sl, winXP sp2
I have a similar problem. I bought a new gigabeat U 2Gb in USA last week. It functioned properly in computers in USA. Now I'm in Argentina and I can't connect it to my computer (windows XP and windows media player 10 both in spanish)I tried install WMP 10 in english that came in the CD and the other
two files windowsmedia10-kb902344-x86-intl.exe and windowsmedia10-kb895316-x86-enu.exe and in the last case apear this message:
"Setup cannot update your WMP 10 files because the language installed on your system is different from the update language". Do you have any suggestion to solve my problem? Thanks
Jan 04, 2008 | Toshiba Gigabeat U202 MP3 Player
Philips HDD6330/17 suddenly not recognized by Vista
Check which version of Windows Media Player you have loaded.
Open Windows Media Player. Click "Help" and "about". This should show which version you have.
Windows Automatic Updates may hve updated to version 11.
The Philips HDD6330 is only compatible with version 10 under Windows XP.
If you have version 11, then uninstall and it should roll back to version 10.
Dec 22, 2007 | Philips GoGear HDD6330 MP3 Player
Toshiba Gigabeat MEGF40S MP3 Player Logo
1,967 people viewed this question
Top Toshiba Audio Players & Recorders Experts
James DuPont Jr
James DuPont Jr
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
