Question about Samsung HLP5085W 50" Rear Projection HDTV-Ready Television
HLP5085W We turned the TV on and heard a pop (like a blast of bulb...bulb going off) , followed by krinkling sound (as if something fallen on fan), we turned the TV off. Now when we turn the TV on, a weird sound comes from the tv for few seconds, the circular light keeps comming on in circle but no happy face, TV doesn't display any picture or sound.
  • 2 more comments
  • EZ Fix Nov 26, 2007
    The same thing happened to me last night. I heard a loud pop followed by a crinkling sound. Then my screen went black. I assume it is just the lamp, but wanted to make sure there was not a bigger problem before I replace the lamp only to have it "pop" as well. I have seen other posts that this could be a problem with the color wheel as well.
    Any thoughts?
  • neebee Dec 04, 2007
  • theduck Feb 09, 2008
    No picture and an arcing sound from the bulb area. I replaced the bulb and the same problem remains. How can I tell if the new bulb is bad and what other problem could it be that I can repair.
    Thanks
  • smokeyharris May 09, 2009
    My Tv went out and now recieve no light in the back of the tv or anything just ! in the front smiley face screen
If you look in the back of your tv, you should be able to see the light from the bulb, if the bulb isn't working no light.
Posted on Oct 14, 2007
    New Friend:
Sfwefwe ef fwef
Posted on Jan 30, 2010
I had this happen to my 5085w and it was the color wheel that shattered. Thank god for having the warranty because it was a costly repair from what I recall. It needs to be looked at by a repair shop or if you have the warranty still, send it in.
Posted on Oct 02, 2009
SOURCE:
Dark Picture
Your backlight transformer has failed, this is not a simple fix and requires the replacement or one or more of the boards in the back of your tv.
Mar 07, 2012 | Sony KDF-E50A10 50 in. LCD HDTV
Sony Wega 42
Sounds like the bulb popped up... does it smells like there something that burned? any error light?
Apr 24, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Replaced bulb now shows only triangle with exclamation mark. no picture and nothing else works
Check your lamp door. If it looks good, remove it. Now, push the lamp door up. Reach around the TV with the remote and try to turn it on. If it comes on, your lamp door wasn't on right. If it doesn't, you may have something going on below the lamp. It the lamp exploded, the hot glass fell out of the lamp and went down into the cooling fan below. It may be stopping it from turning. I hope this helps, best wishes.
Apr 29, 2010 | Samsung HLP5085W 50" Rear Projection...
Display problem with my Samsung HLP5085W DLP TV
What you are describing sounds like a tuner issue. Samsung had a run of bad tuners, and was recalled. If your watching a chennel and the image tears, this is the sign of the bad tuner. It is possible that the wobulation circuit is unstable. First units we bothered by subwoofers thumping the TV. Not much help other than that, good luck
Jul 07, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Rca dlp tv popped crackled and no picture today.
just might be the bulb. Have you unpluged you set make sure its cooled down and remove the buld examine the bulb ussally when the bulbs go bad they shatter not always but it good to check them out as the first step
Nov 17, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Read replace lamp then afew weeks later heard pop noise and now black screen
Two things in your TV can make that popping sound. One is the bulb of course and the other is a capacitor. Have you pulled out the bulb to inspect it? My guess is that you have broken glass in the cooling fan, which is why there is a grinding sound. Most bulbs tend to contain the glass from getting everywhere as it's only the filament inside that pops creating little diamond looking pieces inside the lens. If a surge was strong enough or if the bulb was poorly manufactured, the whole unit can explode inside spraying glass everywhere.
If the bulb looks fine, the pop must've been a capacitor on one of your circuit boards resulting in no display. Since the TV still powers on, your power supply and it's fuse appear to be fine. Check the bulb first and go from there.
Oct 17, 2008 | Panasonic PT-60LCX64 Television
Recentley my tv just turned off. I heard a buzzing sound which happened the 1st time my bulb went out. So I ordered a new one. When the new one was put in it worked for 5 minutes then turned off and...
This could be a couple of things. Look at the cooling fan and be sure that it can spin freely. If it is stuck, the buzzing could be the motor trying to spin the fan. Other than that, the ballast could be failing as well. This is the part that "fires" the lamp. Examine the fan first and let mw know what happens.
Dan
Jul 22, 2008 | Televison & Video
Heard popping now want turn on
Hi there!
Something did pop. Could be the fuse or something else. My guess as good as yours. Good luck, JUS004
Feb 26, 2008 | GE 25GT538 25" TV
Samsung HLP5085W 50" Rear Projection HDTV-Ready Television Logo
460 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
