Question about Marshall MG100HDFX 100-Watt Amplifier Head
Feedback noise when overdrive is on
I have a marshall mg 100hdfx half stack i just got second hand and its ok except when I change to the overdrive channel and it gets a feedback noise. and when it gets louder it gets worse. is there something wrong with the amp??
  • rjivaro May 11, 2010
    The answer is maybe.
    Feedback occurs when the sound coming out of the speakers is picked up by your guitar pickups and amplified again, round and round. This can be a very desirable effect when it is under control, but running loose it is not only difficult to listen to, it can also blow out speakers and amps.
    It is entirely possible that some of your amplifiers components have become 'microphonic' (acting like a microphone) and this creates a very bad kind of feedback.
    If moving away from your amp and/or off to the side does not help you gain control over it, you may want to take it to a pro audio repair shop for an opinion. They will likely want a few bucks, but by giving them some you also get to expect good answers. Obviously it would be impossible to make a meaningful determination of it via text.
    Problem Solver:
  • 5 Answers
It could be your guitar pickups. try using another guitar or getting your pickups waxed at your local music store. also if your playing in a small room kind of loud, or if your using single coil pickups (like fender statocaster pickups) you will definitely get a feedback noise. if that does not work let me know.
Posted on Apr 16, 2010
Treble nob only works all the way up
nomally that means the pot is either dead or has come unsoldered form the board.
May 14, 2015 | Marshall Amplification Marshall MG Guitar...
Can some one tell me how to hook up my half stack.
Using a speaker cable, plug head 16 ohm output to cab 16 ohm input, making sure the cab switch is set to mono if it's a stereo cab (1960)
Oct 01, 2013 | Marshall Amplification Marshall JVM410H...
I HAVE A MARSHALL 410H HALF STACK I WAS JUST PLAYING ON IT AND STARTED TO FADE OUT AND STOP MAKING ANY SOUND THAN I HEARD A LITTLE CLICK THAN THAT WAS IT CAN YOU HELP ME PLEASE.
The circuit is being overloaded and turning off automatically, file a claim with Marshall and they will fix it for free
http://www.marshallamps.com/support/support_overview.asp
Jun 20, 2011 | Marshall Amplification Marshall JVM410H...
The guitar is not amplifying
faulty lead? when the lead is plugged in turn the amp distortion on (may be called 'gain') and when you tap the end that goes into the guitar with your finger you should hear a buzz. try another lead if not, and if it still doesn't work make sure that volume is up on the amp and the guitar. there may also be a knob in the back of the amp, turn that up too (but not all the way or when you do get it working you'll blow the speakers out).
Apr 19, 2011 | Marshall Amplification Marshall MG Guitar...
Can i connect 2 jbl 300 watt speakers to the mg 100hdfx 100 watt amp head ?
Yes you can as long as the speaker impedance when paralleled doesn't go below the rating of the amp. Marshall seems to hide their design lowest output impedance. Possibly you can find that in your owner's manual. Then find the impedance of the JBL. If half the JBL impedance is equal to or greater than the lowest impedance the Marshall is rated, you are fine to use it. The speaker Watt rating should always be bigger than the amp rating which it is in this case.
Dec 11, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Marshall jvm 410h i'm getting loads of feedback when i use od1 or od2 orange or red mode
Dampen the strings of your guitar. If feedback disappears, then you need to move the amp so it can't resonate the strings of the guitar. OD1 and OD2 WORSEN the chances of the feedback into the strings. When this occurs you can often see the strings vibrating without the player picking them.
Nov 22, 2010 | Marshall Amplification Marshall JVM Guitar...
The fan on the back of my marshall mg 100HDFX is making a weird noise when i first turn it on. It eventually sounds normal after about three minutes. Im not sure what i need to do?
You can either oil it up OR replace it for around 20$
Both ways involve removing the amp from the casing by unscrewing the 6 screws on top and sliding it out and then getting the fan out
locate the fan; locate the 4 outside screw covers that are next to the fan grill screws and pop them open. Remove the four screws that are under those plastic covers. The fan should separate. Take Fan out and remember how it was in there.
To oil: lift the sticker and locate the rubber plunger in the middle of the fan; remove it. Then, put ONE drop of regular 3-1oil NOT-wd-40, pb blaster or bike lube. re-assemble
To replace: just unplug old fan and then replace with new fan. I recommend replacing the fan when it gets to the point of bearing noise because oil doesn't always fix this.
Oct 02, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
I have a Marshall MG100HDFX 100-Watt Amplifier half stack (solid state) and I now am not getting ANY sound out of the amp. I changed the fuse and the power module behind the fan, and still no sound,...
plug headphone in the effects send jack...If you get somme sound (won't be too loud) there, that means preamp sections are probably ok. Drive a signal into the effects return jack... If power amp responds, it is OK... If both these are OK, then suspect the switch contacts on these two jacks that forward the preamp to the power amp when effects unit is NOT plugged in.
These contacts are a chronic problem.
Sep 19, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Marshall mg 100hdfx fan
Some of the Marshall equipment uses computer size fans and even on occasion the same connection.
Take the bad fan with you to a computer repair shop it will be much cheaper than a marshall part they should be able to help you out
Sep 09, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
Hi,I turned on my Marshall mg series 100 dfx and there is no sound,just static comes on.Its starts with a kinda bad feedback sound than turns to loud static.
I suspect the power supply for the effects processor has failed. The effects unit will "go crazy" when power supply is too low voltage.
If the amp has loud noise, then the power amp portion is PROBABLY OK.
I had a similar problem in a Behringer amp caused by a bad electrolytic filter cap.
Aug 11, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Marshall MG100HDFX 100-Watt Amplifier Head Logo
338 people viewed this question
Top Marshall Music Experts
matt martin
matt martin
Leonard Jeffrey
Level 1 Expert
rjivaro
Are you a Marshall Music Expert? Answer questions, earn points and help others
