Question about Toshiba Satellite Pro A200-EZ2204X Notebook
A200 DISC DRIVE NOT WORKING
We've had the problem for a while and have been told it's due to i tunes.we were told to go and type run into the start box and go to the regedit and remove the upper or lower filters to get the drive working.but cannot remember were the filters are located.any help gratefuully recieved
  • 28 Answers
This problem could be more than a software conflict. When inserting a disc, does it spin up at all? If it doesnt the motor could be burnt out. Sometimes even if it does, the lens could be burnt out.I would suggest for one, removing iTunes to see if that is the real issue. If so post again with a little more information and results.Like you already heard it could be because i programs registry entry was not removed when the program was. For that i would suggest reading though this: http://support.microsoft.com/kb/929461
Posted on Jun 11, 2009
Acura Legend 86 wont start after initially running fine
fuel pump going out and it will not run at all
coil problem will starteasy but fail after running for a while
fuel pump relay again it is running after starting and if the relay is no good , it will not pump fuel
try having the fault codes read first then have the faulty sensor replaced
May 13, 2017 | 1986 Acura Legend
My car misses
Is there any engine light on?
Feb 03, 2013 | 1992 Plymouth Acclaim
My HP G60-630US notebook freezes during windows 7 loading up
Run the Check Disk Utility. You've got some bad or missing system or boot files.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Apr 27, 2012 | HP G60630US Notebook
2000 GMC Sonoma surges and dies
First the intake manifold should never leak start here. If the intake manifold leaks the air mix can not stabilize causing rich then lean condition.making your 02 sensors act up. The car will always search or purge in RPM range for its ECM required range. Fix the Leak first. get back to me.
Apr 03, 2012 | 2000 GMC Sonoma Extended Cab
My car will not start up and stay running it cuts off after a split second I've been told its my fuel pump went I know I need new plugs do you think that might be it a tune up?
Right after the car stalls, look for a light on the dash that says SECURITY. This is an indicator that you have a failing antitheft system. When the system fails, the car mistakenly thinks it's being stolen, and turns off the injectors in 5 seconds or less, thus stalling the vehicle. Very common problem on GM vehicles. This link explains the problem and offers solutions.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Feb 01, 2012 | Pontiac Grand Prix Cars & Trucks
My a200 sat I think had a crash the restore discs failed and I called tech sup and they want 35 just to help. Can you help?
This is an Issue with the operating system. The beat resolution is to completely format your hard drive and install a fresh version of windows. The error message listed is due to a bad or corupted file system. I hope this helps
Apr 04, 2011 | Computers & Internet
When i turn on my laptop it displays start up repair trys to repair the displays windows cannot repair this computer how do i fix this
It sounds like your windows installation has become corrupt. You might be able to solve this by re-installing windows but if it has become corrupt due to a hard drive fault it will happen again. I have a copy of the installation discs for A200/A205 series computers, if you are in the UK I might be able to help you out. You don't say what operating system you're running.
Jan 24, 2011 | Toshiba Satellite Pro A200-EZ2204X...
How do i restore my toshiba satellit pro a200 back
If you have a backup, you can do that, off your hard drive. Otherwise, you will need to get a replacement disk from Toshiba.
Feb 25, 2010 | Toshiba Satellite Pro A200-EZ2204X...
How do i do a system restore to factory settings i have the recovery discs etc just can't get them to run
Go to Start--all programs--accessories--system tools--system restore and from there you can restore your windows to earlier time.
Jan 31, 2010 | Toshiba Satellite Pro A200-EZ2204X...
Toshiba Satellite Pro A200-EZ2204X Notebook Logo
41 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
