Question about Canon PowerShot A75 Digital Camera
NO memory card Problem - Powershot 550
Mine is a CANON powershot 550. 2years old. was working in a very good condition before few days. BUT now Am getting a error like "no memory card". i get it often while using my camera. sometimes it disappears by itself. i have tried removing the internal battery, tried lot of memory cards, tried all kinds of formats. all memory card work fine in card readers. left the camera with out batteries for more than 48hours. but no effect. once the error shows up, it does not accept any card. it just keeps showing the error. sometimes after showing the error it shuts off, and sometimes it remains ON. i doubt if some kind of disturbing plastic is stuck behind the contacts in the memory card receptor in the camera. but wanted to know if there is any FIX with out disassembling the camera.
  • Canon Master
  • 10,073 Answers
More likely one of the spring contacts in the camera that connect to the SD card has become weak causing the problem.
Posted on Oct 31, 2017
  • 2985 Answers
SOURCE: Zoom not working for my canon Powershot SD 550 Digital camera
 Seems like the motor has burned out
A reaiar is not a likely economic move
Check out Canon support
Posted on Oct 18, 2007
  • 2985 Answers
SOURCE: Need Instructions Powershot A 550 in Russian
Check Canon Support site.
Posted on Dec 31, 2007
  • 10594 Answers
SOURCE: I have a powershot a
Clarification Request by welcomejee, posted on Oct 01, 2008No driver available for Win 98se. Win 2000, XP and Vista drivers are available.
I will provide you website link if you require any of them driver.
Posted on Oct 02, 2008
  • 3 Answers
SOURCE: memory card error after inserting SDHC card on powershot A620
the a 620 only goes up to 2 gb no higher
Posted on Jan 28, 2009
  • 55 Answers
SOURCE: Memory card error - can't format card
If it is an SDHC card your camera is too old to support it.  You need to get an older-style SD card.
Posted on Apr 26, 2009
Why does my new PowerShot SD 1200 IS say I have no memory when I just inserted a new memory card in it? I followed the directions.
Same problem here but i solved it on my own.
When i try my memory card into my bestfriend's camera, it works. Now the problem is on my Camera.
The question is. How old is your Camera?
Mine is just two days ago after i purchased it, so i used the warranty period.
Jul 15, 2011 | Canon Cameras
"cannon powershot sd870 wont turn on when memory
Please check the memory card with your PC and check if there are any corrupt files within. If so remvoe and format the card , Also so a virus scan and confirm that the Sd card is clean.
Now insert and check. If however the card is found in good condition in the first place then there are errors in the interface to the processor in the camera which might need a technical help from the Canon-service center.
Jan 22, 2011 | Canon PowerShot SD870 IS Digital Camera
The camera will not turn on.
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jul 30, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Canon powershot SD1200 IS says Memory Card Error
You probably just need to format the card in the camera. This will completely erase it so download any pictures you want to save first.
Oct 21, 2009 | Canon PowerShot SD1200 IS / Digital IXUS...
I have a Canon powershot A700. I took out the old
As you've already tried sliding the card's locking switch, see this link for additional things that you can try.
Sep 08, 2009 | Canon PowerShot A700 Digital Camera
Canon camera won't accept SD memory card
It's a good bet that anything 4GB or greater is a SDHC card (look on the card, see if SDHC is written there). Your A530 was designed before the new SDHC format came out. Sorry, but your camera will not recognize this type of card. Recommend instead that you get a 2GB standard SD card. They're relatively inexpensive these days.
Jun 07, 2009 | Canon PowerShot A530 Digital Camera
No Memory Card Error
May memory reader correpted or insert reversely memory card into reader.
Feb 18, 2008 | Canon PowerShot A560 Digital Camera
Canon powershot A520
I had a similar problem. Lens came out , and will not go back to off position. Will not tun on either chnaged couple of batteries with no luck.
I took the memory card out and it worked " Turned on". I formatted the memory card and it started working fine. Hope it will help few of you.
Good Luck
Dec 12, 2007 | Canon PowerShot A520 Digital Camera
Memory card error
Canon will fix this for you for free. It's an inherent fault with the S400. It has a little internal button battery that causes the problem as it gets old and run down. Check this website for more info. Look for the bright/bold yellow post describing how to return to Canon.
Good Luck!
Nov 19, 2007 | Canon PowerShot A430 Digital Camera
Canon powershot G2
I just repaired my Canon G2 with the same symptom.  The internal PCB that you plug the external AC adapter is defective.  The numbers on the board are:
Oct 21, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon PowerShot A75 Digital Camera Logo
1,071 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
