Question about Sony Televison & Video
Sony TV works briefly then turns off by itself makes a click
I have a Sony TV which is about 6 yrs old and has never had a problem.
Recently it will turn on and then 10 mins later will shut off. When I try to turn it back on it makes a click noise that it usually does turning it on, but it wont actually turn on.
If I let it sit for a while it will turn on, but then once again shut off shortly.
What exactly is going on with it? is it repairable? please let me know.. I'd hate to lose this TV.
  • 371 Answers
It's serviceable, and will need service on either the thermistor that is turning the set off, and/or the parts of the circuit that are overheating the thermistor.
Posted on May 10, 2009
If it's a rear projector led then you may need to replace the light source as it is overheating. Try cleaning out the vents too.
Posted on Sep 20, 2014
What is the life span for the Sony Wega KV-32HS510?
10,000 continous woking hours is calculated to most of the CRT based TVs.
It is only calculation, but the life span might be much more that that. I've repaired a Sony TV recently, which was released by Sony Corporation Japan. The model is KV1820, an 18" Trinitron TV, still works perfectly. Just see, it is an '80 model one.
Jul 31, 2014 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony bravia blinks 6 times
i have a Sony Bravia LCD TV KDL-60EX645
and it Blinks about 6 times every 25 seconds and it blinks next to the "Power" symbol? what does that mean? i cannot turn on the tv because it turns of and its not on eco and i just got it for christmas. its a 55" and i have a 3 year warrinty. but do i need to pay for it, or will it turn back on later ive been waiting about a week? i am a major gamer i usually spend 14-16 hours using the tv i am a youtuber, but does it burn out? i know alot about tv's but im not used to this error... i need some help so please contact me at Alexcromwell1@live.com
Please help me. i might seem like a slacker but actually i make money of using the tv. thankyou for taking the time to read this and try to help me please. thankyou -Charles
Apr 24, 2012 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Tv turns off (both video and sound) after running for 20 sec and then turns on after 20 sec. This pattern continues over and over. None of the lights are blinking. Lamp is less than 2 yrs old and is...
TV will show Lamp Light warning if lamp got broken or dead.
Symptoms of TV shows lamp is weak and will be replaced. Weak lamp consume more current than allowed ratings and causing activation of protection circuit that shuts off TV and TV turns on again itself, that is why no blinking red light.
Please replace lamp in your Sony KDF-E55A20 TV, lamp replacement procedure is easy and written in user manual, click Sony Support to download user manual copy, if required.
Always buy Sony original lamp for TV safety, Sony original lamp is available in Sony Accessories Store for $200 with following part number..
A1085447A... LAMP BLOCK ASSY XL-2200U
Hope this info will help you.
Thanks.
Dec 31, 2009 | Sony Televison & Video
My tv turns on and off. It will stay on for about 3 min and then turn off. What is the problem??
If its Sony KDF-50WE655 TV then its weak lamp symptoms like TV turns off and on automatically and work for 3 minutes as you mentioned.
How old is this TV and did you replaced lamp recently?
Replace its lamp that is weak in result and causing TV off and on itself.
Lamp replacement procedure is written in user manual, very easy, click Sony Support to download copy, if required.
Please buy Sony original lamp for TV safety that is available in Sony Accessories Store under following part number for $200
A1606034B... LAMP BLOCK XL-2100U
If model number is different, let me know.
Thanks.
Dec 01, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Set wont turn on red light just keeps blinking
this is a malfunction of the power supply block (inside your TV-device),or over load of it.please contact the nearest repair shop.
Aug 08, 2008 | Sony Televison & Video
60" RCA PROJECTION TV
my tv is 12 yrs old it started with the color starting to fade and then it started cracklin real bad and now theres no pic but there is sound
Dec 29, 2007 | RCA P60921 60" Rear Projection Television
Sony tv kv-32fv300
you probably aren't checking this posting out anymore, but maybe someone else will see this and it can help them.
i was having the same problem, did a search and found this solution. worked like a charm!! go here:
http://www.floggingenglish.com/2008/07/22/diy-tv-repair-fixing-screen-flicker-on-a-sony-hd-wega/
Nov 24, 2007 | Sony FD Trinitron WEGA KV-32FV300 32" TV
Sony kdl 32 inch lcd tv (apprx 2.5 yrs old)
Usually resetting a device like that is done via it's On Screen Display (OSD). Maybe you need to contact Sony Tech support.
You can do this by clicking the below link:
[Sony Tech. Support]
Let me know if they have a solution to your problem.
Greetings,
DarkNeogen
Aug 20, 2007 | Sony WEGA KDL-32XBR950 32 in. LCD HDTV
SONY TV KEEPS TURNING ITSELF OFF!!
Its the BULB people! You need to change it every 3 to 5 years! I have had my sony 55" for 6 years... I had Best Buy come out 3 years ago, changed the bulb... it worked fine. Just started flasshing and shut its self off and back on again. Time for another bulb.
May 23, 2007 | Sony KV-28FX60 28" TV
Televison & Video Logo
472 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
