Question about Xerox Phaser 7750DN Laser Printer
My Phaser 7700 Printer does not come to a ?Ready? state
The fuser will not heat up, the displays stays in the "Warming up fuser" text but fuser never heats up...
  • Xerox Contributor
  • 185 Answers
This might be a bad main Image Processor (650-4307-00) board. We can isolate it by printing an internal test print.
You can power up the unit in diags (hold "back" & "info" buttons while powering up) Go to "Built in Test Prints" and try to print the "Grid 1 Dot Pattern"
If you print, then it's proven...
If not, then you will get an error that will allow further troubleshooting.
-Whit
Posted on Jul 31, 2009
Printer warming up don't stop
Try another wall outlet for power. Make sure it is not plugged into a ups/power bar etc.. but directly into the wall. A ups can limit the amount of power reaching the fuser and cause it to fail at warming up. Also try putting your hand near the fuser to see if it is giving off heat (don't touch it though, you can burn yourself)
Mar 28, 2014 | Xerox Phaser 3117
Hallo, i have xerox phaser 3200 i want ask something why when i turn on the printer warming up progress can't finish (always warming up)
Srri but this is a fuser failure. The lamp has probably blown so it cannot generate any heat. best buy a new fuser unit. A lot of the machine has to come apart to fit it. You would be better taking it a shop for them to repair it.
srri
May 23, 2011 | Xerox Phaser 3200MFP/N Laser Printer
Fuser Error. Low Temperature
there is a small thermometer that contacts/sits very close to the metal heat roller on your fuser, chances are when removing the jam its been bent away from the roller, have a look and try and see if you can see it, not knowing this exact printer im not sure the exact position but it is usually in the middle of the roller coming from the top of the fuser housing, another thing to check is if your fuser is actually warming up atall, if you cant feel any heat then the fuser lamp that heats it up has gone bad
Nov 14, 2009 | Xerox Phaser 6100/BD Laser Printer
Fan Failure Error 54
1 of 2 things.
You need to clean or replace the fan.
You have to remove the back, right side and top cover to access that fan.It is near the back just behind the fuser module.
It could also be the low voltage power supply fan. Most likely the fuser fan.
Once you remove the fan, there is a label on it, remove the label, There is a rubber plug behind the label, remove the plug and drip some lubricant into the fan. Reassembly and it should be ok.
I would recommend replacing the defective fan though.
Here is a very reliable part source.
https://www.partsdrop.com/store/
If you call ask for Britt and specify the model number and that you need a fuser fan and probably order a Power supply fan, Neither are very expensive.
Have both on hand to be 100 percent sure the problem is resolved, But its a 90 percent fuser fan failure code. It operated in a heated area and can dry out faster.
Mar 27, 2008 | Xerox Phaser 7700 Laser Printer
Phaser 7700 not booting up
a yellow line is comming on both sides of the printout when i print using my phaser 7700
Mar 20, 2008 | Xerox Phaser 7700 Laser Printer
Phaser 7700 Accumulator Belt Replaced, upon startup there is an error
POSSIBILITIES
Problem:
1st BTR Contact Failure or 1st BTR Retract Failure Message is displayed after replacing the Accumulator Belt Cause:
A Phaser 7700 Accumulator Belt was installed in a Phaser 7750. The Phaser 7700 Accumulator Belt does not have retractable 1st Bias Transfer Rollers; so these errors will be reported if one is installed in a Phaser 7750 printer. Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Remove the Phaser 7700 Accumulator Belt and install a Phaser 7750 Accumulator Belt. TRY FIRST (Solutions without parts):
1. Check that all shipping restraits have been removed.
TROUBLESHOOTING TIPS AND HINTS:
1. Test the 1st BTR motor in diagnostics to verify proper operation. 2. Test the 1st BTR sensor in diagnostics, then run the 1st BTR motor test and recheck the 1st BTR sensor. Sensor state should alternate between L and H. The sensor is part of the accumulator belt.
PARTS:Parts are listed in the order of highest probability for repair.
NUMBER QTY DESCRIPTION
116177400 1 *KIT IBT - UNIT
REPAIR/INSPECT/PREVENT PROCEDURE:
1. Clean feed rollers, exit rollers and guides; replace if
necessary.
2. Clean feed rollers and exit rollers only when dust or
debris is visible.
3. Remove and clean all paper trays.
4. Clean the Laser Scanner Unit window.
5. Inspect the image density sensors; clean if necessary.
6. Inspect the accumulator belt home sensor; clean if
necessary.
7. Inspect the fuser assembly; clean if necessary.
8. Print the Error Log, diagnose and repair any problems as
indicated.
9. Print the Usage Profile, diagnose and repair any
problems as indicated.
10. Check version of all installed firmware; as
appropriate, install the latest version of firmware.
11. Check cleanliness of interior and exterior of printer,
including fans; if necessary, clean (dust or vacuum) these
areas.
Problem:
Jan 25, 2008 | Tektronix Phaser 860DP Thermal Printer
Xerox 7700 won't go past warm up
The fuser is a good place to start. If it is not hot you could try another fuser. You'll feel the heat well before you actually touch the fuser if it is working.
Do not swap fusers with another printer. These fusers have a life setting and when they are put into another printer it messes it up, leaving you with a fuser registering less than 10% life left.
An additional possibility is the the fuser may not be getting the power it needs. There are two boards that control power distribution if I remember correctly, T1 and T3, but I am not entirely sure which one handles power going to the fuser. In this case it would probably be best to get a repairman in. The 7700 is not particularly easy to work on, depending on the issue, but an experienced technician with a repair manual should be able to handle it easily.
Oct 29, 2007 | Xerox Phaser 7700 Laser Printer
Xerox Phaser 7750DN Laser Printer Logo
160 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
