Question about Motorola Mobility RAZR V3c Cellular Phone
I want to get the sim card location? what procedure about solve it?
  • 3 Answers
Open up your back plate
Remove your battery and
hold your sim try to insert by using upword movement ,replace battery,close the back plate
Posted on May 10, 2009
My nokia n8 restart after insert sim card,can you give me a solution for that problem please.
Restart:::
mY Dear:
First:
restore your Phone Settings
IF Restart problem not Solved So
Secend Option:
Please Format Your Phone
we can solve this problem but i need you to backup the whole DATA that you have in the phone and perform this reset procedure.
*#7370# or *#7780#
Default security code is 12345
release some memory then it will b opened
your phone or memory card get attack by virus. pls do a format phone and memory card.
If Problem Not Solved So
Very Best Solution:
flash new software install in the phone problem will solved quickly
FOR INSERT SIM:
First All Check:
1.Confirm whether same sim card is working in other h.s or not.
2.Make sure the sim slot is o.k. only try these two.
3.If all the above steps fails, check the SIM card connector pins for damage.
if so try to get serviced.
4.if ur sim card is good then it is problum form sim card ic u have u raplace it with SMD.
u can make it jumper mean u can fix this prob with out sim card is for this contact.
5.take sim connector slight up by pin then cheak by inserting sim.
6.hot air gun on sim i.c. then cheak it.
Last Option:
IF make sure that the sim card hasn't been damamged at all sO Please You Go to Service
& Sim Office and Get the Duplicate Sim Same Your No From Office Oprator
Problem will Solved Quickly
Jan 21, 2013 | Nokia N8 Cell Phone
I 'm using the nokia 1209 model, i need to get copy of the sms located there, yet there is no blue tooth, cable, or option to save sms on memory card... how can this be solved out !! Regards
Dear, just try to copy you messages to your sim card.
then put that sim card to any other mobile then copy that sms to that mobile memory, if you insert that sim card to a multimedia set that support backup then you can backup your message to memory card.
or try sending those messages to your any other mobile number!
it is that simple!
regards!
Jul 30, 2011 | Nokia 1209 Cell Phone
SGH-C140 NO NETWORK
Good day to you!!!
If your sim card is too long in service maybe that sim card is expired already please try to use another new sim card so that you can test if the problem is on the sim itself before any other procedure to solve your problem...
If you find it helpful please testify or rate me...thank you....
Jul 03, 2011 | Samsung Cell Phones
When I put in 2 sim cards in my Samsung C5212, the phone starts up and then hangs at Sim Initializing. Please help me. Thank you.
First:
u have to restore your set again.
OR:
*#7370#
or:
Very Best Solution:
Aug 18, 2010 | Samsung Cell Phones
My blackberry curve screen shows a SOS in the upper right.....I cannot make an outside call.......it blocks with a message "emergency calls only"! A message at top of screen says"insert SIM card". What...
The message you are getting from your phone indicates that no sim is present in your phone,perhaps you have inserted the sim in a wrong manner, hence the phone does not recognize the presence of the sim card.
Here is the solution;
1.Remove the back cover of the phone and remove the battery respectively,
2.Afterwards,re-insert the sim card in a manner indicated by an arrow located beside the sim port,or as described by the user manual.
3.Ensure you turn on the radio connection,which is located in the manage connection settings in the main menu.
Problem solved
Have a nice day...
Aug 04, 2010 | Cell Phones
Sim card rejected
this happens when ur sim cant establish registration with the preffered networkk . this is not a phone problem . ur sim card may not hve been used for long time (recharging account) . please contact the nearest office of ur network provider
Nov 06, 2008 | Nokia N73 Cellular Phone
Sim Card
Hello Natalie im glad to say I have a solution for you now follow the steps I give to you and in a moments time you will have all your contacts off your sim card and into your motorola. OK here we go, while your phone is in idle mode go to contacts then push the options button located in the middle of the black surrounding navigation buttons located on your keypad then scroll down to copy, now at this moment your contacts should be in your sim card. After entering the highlighted copy to options will open choose the one that says "all to phone" and that should solve your problem. If not choose the "enties" options in copy press change with "entries:...." highlighted add everyone else in your sim card and press done then your problem will now be fixed. hope I really helped bye!
Jun 19, 2008 | Motorola Mobility W375 Cellular Phone
Motorola Mobility RAZR V3c Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
