Question about Akai PDP4273M Television
AKAI PDP4273 - press power button, hear click sound, shuts off
After 2 years with this display it is no longer working.
While watching tv today all the sudden the screen turned off and I heard it click two to three times.
Pressing power button did nothing.
I unplugged the display.
Then I plugged it back in and pressed the power button.
I could hear the click sound (like it always does when you turn it on) but the screen never turns on, and then upon pressing the power button nothing happens at all.
I can get it to make the click sound when pressing the power button only after unplugging it and then plugging it in again.
I also tried plugging it back in and then keeping the power button pressed down. When I did this I was able to get the screen to turn on, but only long enough for the blue AKAI screen to show up before the display shut down.
Any help on this is greatly appreciated.
  • 4 more comments
  • matterinoman May 10, 2009
    what should i do to rectify the issue?
    what steps do I need to take to resolve this issue?
    Open the display? repair/replace part? I have heard parts for this model are very hard to come by.
    what do the capacitors look like? Is this an easy fix?
    I have never opened a plasma before.
    It is out of warranty, 2.5 years old.
    I have soldered plenty and have repaired computers and other electronics, just never a plasma.
    So, I just need to open it up, and follow the power cord to the main board and look for a busted capacitor???
    Remove capacitor, go to radioshack or frys to buy a like capacitor and then solder it in?
    Also, how much do you think something like this would run to be repaired?
    I plugged the display back in and pressed the power button this morning.
    It worked as normal for about ten minutes before it shut off again.
    Is this still a capacitor issue?
    I want to be sure this is the issue before I take apart the display.
    how can it be that, this is a plasma hdtv monitor.
  • 62 Answers
It does sound like it is a capacitor problem, blown capacitors are usually curved out or bulg out when they are bad. You can try taking apart and look for the power board and check to see if there any blown capacitors, Most repair shops usually charge about $150-$200 to fix it. I have never fixed a plasma before, but I have fixed numerous LCD panels and 95% of the time it is a capacitor issue and sometimes a transistor issue in the invertors. I am not sure if Plasmas have invertors or not, I think only LCD's do.
Heat is the enemy of electronics, and these sets operate hot. You might wish to unplug the TV for an hour or more. If this power reset does not allow the TV to turn on component failure is indicated. These sets are assembled using the wave soldering process they are known for having cold solder connections. This model of TV has over 2,000 parts which include millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Integrated circuits and transistors can go bad. This can cause other components to become defective, which can have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again since if the parts that caused the failure to begin with are not replaced. The only way to know for sure what is causing the problem, which parts that are no longer within factory specs and for proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment and the skills to use the test equipment.
I would reccomend having it done by a professional, or getting the TV replaced, preferebly LCD HDTV as they are easier to diagnose and fix than plasma's.
Posted on May 11, 2009
  • proresearch May 11, 2009
    Also to make note I just saw that it worked for 10 minutes then shut off again, Another problem could be an overheating issue, take it apart and clean out all the dust with a can of compressed air doing it in short bursts, dont tip it upside down or hold in for too long as it will cause liquid to come out instead, after cleaning it and it still dont power on properly then it is definately component failure, bad capacitor, transistor, or both.
    Please rate my post according to how helpful I have been.
    Sergeant:
  • 322 Answers
Basically sir, it is not a capacitor issue. It is a flyback issue or video amplifier. As you have said, there is no picture.
Is there any sound? if there is it could be the two i mentioned earlier. The best way to deal with TV is to take them to a technician and let them do the work. Working with TV is very dangerous since it can electricute once you made a wrong move.
It can be the video amplifier that it is not getting much signal or the flyback has a hole/leak since you hear a sound. The sound is actually the current that escapes thru the holes. So i suggest that you don't plug it again and take it to a technician before you burn your house.
Posted on May 10, 2009
    President:
  • 1,197 Answers
The photon charges at the back of the tv might be damaged, if ur tv is not under warranty i suggest u to check the interior to see if there is any burnt capacitors at the back..... have a multimeter and test the capacitors
identifying and fixing it shud solve ur problem
thank you have a nice day
  • 2 more comments
  • SAM JAYANTH CHANDRASEKAR
    hi this s iversh again
    sounds like some slow capacitors in the power supply here.
    If
    you are experienced and can do fine soldering..............take a
    lookat the power board.............where the cord goes and look for any
    puffed electrolyitic capacitors if you see obvious
    ones.............replacing them should solve this.
    if u have no experience with tinkering with tv i wud advice u to find a repairman.... its for ur own safety as a lot of bad burns have happened to people who try to fix plasma tv's.
    stay safe
    thank you
    have a nice day
    then dont try it urself........ call a local repairman.....
    good luck
    iversh here
    ask ur repairman to  take a lookat the power board.... ask him to check for burnt capacitors he shud be able to do it
    if u feel i was of help to u kindly rate my service
    thank you
    yes the procedure u told is correct.... kindly take adequate checks to ensure the tv is plugged off..... replace the burnt out capacitors..... tv capacitors barely cost 50 cents.... the real headache is the soldering.... but since ur ok with soldering.... u shud be able to fix it without any problem...
    thank you
    Genius:
  • 1,847 Answers
This seem issue with the HT transistor, or rectfying diode from chopper transformer.
Let me know
Thanks
Kevin
AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Nov 27, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Almost same symptom
Probably what happend to mine. It's all the same problem. It's actually fixable. I repaired mine.
Jun 04, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai hd projection tv pt4299hd won't turn on
Sounds like a power supply issue. Does the power indicator light up? Can you hear a click when the power button is pressed?
May 31, 2008 | Akai PT4298HD Rear Projection Television
Flashing RED Light
Our AKAI also shut off & the red light started to blink...got no help from AKAI, but did from COSTCO. We bought the set before the 90 day warranty they have in place now, so they referred us to COSTCO Concierge Services: 1-866-861-0450. We were referred to a repair service & after discovering what the problem was found out that AKAI not longer has parts for this model. COSTCO replaced our TV---talk about satisfaction guaranteed.
May 14, 2008 | Akai LCT2701TD Television
Akai model lct2721ad. tv.
Mine does this all the time. It appears to be a factory flaw. The only way around it is to set the channel you are watching to "MONO" and the crackling sound will disappear.
May 11, 2008 | Akai LCT2721AD 27 in. LCD Television
One day it worked the next it didn't
These TV's are prone to power supply failure. I can fix the power supply on this TV for approx $100 +s/h.... Contact me and all you have to do is remove the power supply and send it to me and I will repair it with high quality parts. Reinstall and you TV will be good as new...
Jan 25, 2008 | Akai LCT2715 27 in. LCD Television
Akai model pdp4249g
Hello drifter,The design of the tv enables the auto search to detect any input signal you have selected. It could be TV (off air, video signals etc) so just switch on whatever inputs to the akai plasma befote you switch the Akai plasma on and let it do the work for you. just relax and watch the tv. recap 1. switch on the input eg video deck, DVD, VCD, or satellite dish. 2. switch on your AKAI PLASMA and 3. wait for the akai to search for your input signals. TRy this simple procedure and if it doesnt work just post back the message. The DON
Jun 15, 2007 | Akai PDP-4249G 42 in. EDTV-Ready Plasma...
Loud electrical sounds
It sounds like the Power transistor that drives the High Voltage Transformer shorted out. The rapid clicking sound you are hearing when pressing the power button now is that of the power supply starting to come up, detecting a short circuit and shutting back off again, preventing further damage. It is likely that the HV Transformer is shorted as well which usually causes the Output transistor to fail. Since the set is only 2 1/2 years old, it is probably worthwhile getting it to a repair shop as long as you have been very satisfied with the picture quality up to this point. If the picture size was larger than you needed, you might consider going down to a 37" LCD HDTV set. Toshiba is tops in this category IMHO.
Mar 30, 2007 | Zenith R40W46 40" Rear Projection...
Televison & Video Logo
170 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
