Question about Car Audio & Video
I have an automatic 2003 dodge neon SE has 96 thousand miles and ran very well until I installed a car sterio system, I placed two twelve subwoffers and bridge it with a 700 WATT AMP. After two weeks my O2 sensors and camshaft went out and i had them replaced but they keep overheating and had to replace the O2 again. The car also idles and sometime quites if im not giving it gas or when i put it in reverse or let it idle. I was curious if it is to much power for the car or if I should try to replace any fuses,hoses, wires or sparkplugs? Thatks for any information given I greatfully appreciate it.
  • 518 Answers
IT SOUNDS LIKE YOU ARE DRAINING MORE POWER FROM THE BATTERY THE THE ALTERNATOR CAN PROVIDE, WHICH BASICALLY MEANS THAT YOUR SYSTEM IS NOW RUNNING OF YOUR ALTERNATOR, WHICH AS YOU WILL PROBABLY WORK OUT FOR YOURSELF IS NOT GOOD, GO AND SEE SOMEONE IN YOUR AREA THAT KNOWS ALL ABOUT STEREO SYSTEMS, TELL THEM WHAT THE PROBLEM IS AND I AM SURE THEY WILL GIVE YOU AN ANSWER, HOPE THIS HELPS.
Posted on Jun 13, 2009
Wont shift gears
Dodge Neon Questions - 04 neon will not go into high gear ...
www.cargurus.com > Questions > Dodge > Neon
CarGurusNov 3, 2012 - 04 neon will not go into high gear - 04 neon won't go into high gear. changed transmission fluid. (it tried to change after fluid was changed) gas cap ... ... Car: 2003 Dodge Neon SXT, automatic transmission. As of today, I have ...
Dodge Neon Questions - 2005 Dodge neon does not shift ...
CarGurusApr 6, 2014 - Your cars computer gathers info on speed in order to shift gears properly.... then you won't have a speedo and the ECM will not tell the TCM to shift gears in the trans. .... Car: 2003 Dodge Neon SXT, automatic transmission.
Neon wont shift out of first gear auto. - DodgeTalk : Dodge Car ...
www.dodgetalk.com > ... > Dodge Neon - General Talk
Jul 30, 2011 - I have a 2003 dodge neon se and it will run and drive. The transmissonwill not shift out of first gear. Where do I start? Compare to Toyota Tundra. Get Tundra on ... 2000 Stratus won't shift out of First Gear
Mar 14, 2007
Not shifting out of Second Gear???
Jan 15, 2007
46RE wont shift out of first at full throttle.
Nov 17, 2006
Transmission wont shift
Nov 3, 2005
More results from www.dodgetalk.com
Jan 06, 2016 | 2003 Dodge Neon
Neon 95 speed sencer diagram
95 dodge neon speed sensor ?!?!?! - Discussion on Topix
www.topix.com > Dodge Neon
Jul 28, 2006 - My 95 dodge neon brake pedal sinks somewhat on putting the brakes ... the speed sensor is located in the middle near the fire wall. just to the ... 1998 Neon + Speedometer
Mar 19, 2007
broken speedometer 95 neon
Jan 22, 2007
96 neon cranks but wont turn over
Oct 29, 2006
More results from www.topix.com
How To Install Replace Speedometer Input Sensor Chrysler ...
? 3:05
www.youtube.com/watch?v=y6bwJKFT6aY
Oct 31, 2013 - Uploaded by 1A Auto Parts
How To Install Replace Speedometer Input Sensor ChryslerDodge Automatic ... it with a 1A Auto Automatic ...
Oct 31, 2015 | Cars & Trucks
Automatic Dodge neon SE 2002 will not start.. Ran error code got P1684. When I was driving it wouldn't get out of first gear, I put in park shut it off turned back on still wouldn't get out of first g
that code is set when you disconnect the battery. It can happen if you have bad connections. Sounds like you have a lot of things wrong.
Mar 12, 2013 | Cars & Trucks
Car problems on my 2003 dodge neon se 2.0 engine
There are only two kinds of 2003 Dodge Neon SE's equipped with a 2.0L engine. The kind that has had car problems and the kind that is GOING to have car problems!
So tell me, what kind of car problems are you having?
Nov 10, 2011 | 2005 Dodge Neon
Last year my 2003 neon stopped running and we had the timing chain replaced WE got 40 miles and the car stopped then wouldn't even turn over we changed a fuse and got it to run another 70 miles to limp...
I would say yes, if it wouldn't let the car run, then yes the wire may be frayed now, repair the wires first and eliminate that problem . then have the codes read,
Jul 06, 2011 | 2003 Dodge Neon
2003 dodge neon PO700 (tcm)
You dont have to pull the tranny to fix this. Some so called "experts" on here shouldnt be giving advice if they dont know. The solenoid pack is located in the front the transmission just below the air filter and in front of the input speed sensor you just replaced. Unbolt the connector with a 10mm socket then the bolts connecting to the tranny. Replace with a new one 140 bux or close(get a new one). Installation is vice versa. Easy fix for any person who is mechanically inclined. Always get a second or third opinion when asking a thousand dollar question on any website. Some people think they know....but they dont.
Jul 16, 2009 | 2003 Dodge Neon
Engine Cooling problem 2003 Dodge Caravan 6
It needs a thermostat and a coolant flush, in the worst case scenario a head gasket may be blown or leaking, have your mechanic do a coolant flush,thermostat, and leak check.
Jul 10, 2009 | 2000 Dodge Caravan
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
