Question about Kenmore Elite 45986 Front Load Washer
F02 code - won't spin
I tried the solution suggeseted by both catriver and sofico76 - checked inside the rubber seal to make sure nothing was stuck in there.  Then I took off bottom panel and cleaned out the filter - there was nothing in it but a small hairband.  Tried the washer again, still won't spin - can smell hot rubber.  Any other suggestion as to how to fix this F02 code?
  • LPeoples Oct 22, 2007
    I ended up having to call a technician to come to my home and identify the problem.  Based upon watugot's response, if I needed a pump, that wasn't somethinhg I was willing to take on.  When I initially removed the filter cover, like I said before, all I found was a small hair band but the filter was otherwise clean.  I even snaked the line to make sure there wasn't a blockage further up.  Well the techician opened the filter cover.  There is a line leading to the pump on the inside right of the filter.  He immediately identified that there was a larger hair band that was clogging that side line to the pump.  I didn't even know to look for that "side" line.  So I hope this helps someone else out there who may run into the same issue - hope it saves you the $70.00 service fee.
  • DrHooke May 11, 2010
    I just want to thank you watugot.
    I searched high and low for a solution to my F02 issue. I tried all the fixes including cleaning out the trap, clean out the hoses, run with no soap, doing the diagnostic test, etc, etc. They all say "check the Pressure Switch" but nobody says how. Except YOU!!!
    My wife was counting the days before she was going to call the service man.
    I almost purchased a new pump but I could not get passed the idea that it was pumping water like a champ but just not quitting when it was finished. You know...the 8 minute timeout occuring.
    I read your post and thought it was beyond my ability. But I'm a DIY-er. I went to and got a good look at the diagram. Finding that pressure switch was easy after I figured out how to take the top panel off.
    The switch can be removed (not neccessary for this fix) by removing the electrical plug and the hose. Then turning it 90 degrees. I had to remove two support screws for clearance. I tested the electrical leads with a continuity option on my multi-meter. I don't know a lot about electricity so don't think this is out of your ballpark if you got this far. I don't even know if it was working correctly, but it was changing conductivity when i blew into it. Leads 22 &21 are connected at 'rest'. When positive pressure is applied (blow into the hole) leads 24 & 21 are connected and 11 & 14 are connected. I looked like i was smoking a pipe doing that test....LOL.
    I blew through the hose going to the tub. It was not clear. So I blew harder and that was it! Something clogged it up. No idea what it was...Thank you so much!!!
    I'm pretty sure this will probably happen again...Is this common? Does it have to do with non-HE detergent useage? Or the mold growing everywhere.
    I'm thinking about drilling a hole in my floor and attaching a low-pressure release fitting to drain that trap. It would require a little ingenuity. Its unbelievable how disgustingly dirty that washer gets. EWWWW....
  • 290 Answers
You you probably need a pump, but try this first.  Remove the pump filter again and put you finger into the hole going to the pump and see if there is anything in it and see if you can turn the pump impeller. If this checks ok, Put filter back in and put washer into drain/spin. It should spin since you have drained the tub. If so replace the pump.
If it still doesn't spin remove the top of the washer and find the pressure switch. It will have a rubber hose going from it down to the bottom rear of the tub. Remove the hose from the switch and make sure you can blow through it. Hook hose back to switch and try drain/spin again. If washer does not spin now, you will need to do some trouble shooting with a volt/ohm meter or have a tech come out.
Post back to let me know what you find out.
Posted on Oct 13, 2007
  • Michael  Lindley
    Michael Lindley Oct 17, 2007
    Just wanted to follow up on your washer and see what you found out. Thanks/Mike
As it spins very slowly back and forth it also makes the grinding squeeking noise.
Hi Robert.
What you describe sound like a distorted drum and/or collapsed bearings. The grinding noise is typical of bearings which are worn out, and the squeaking can come from the drum rubbing on the door seal.
Check if the inner drum is loose and flops up and down. Also spin the drum by hand and see if it's touching the rubber door seal anywhere. If it spins freely but make a growling noise your bearings need to be replaced..
Neither of these situations are good. A serviceman is probably required to know for sure.
Good luck.
Check that drum (2nd below) is not rubbing on this door seal
Drum should rotate quietly and smoothly
Jan 13, 2015 | Washing Machines
Banging when spinning and rubber smell
if the basket wabbles like crazy, could have a cracked spider that holds the basket
Mar 01, 2014 | Washing Machines
I have a kemore elite he 3t front load washer it won't drain and its giving me a F02 error message. what does this mean? Help!
it's a long drain error code,most likely the pump is blocked with all kinds of good stuff,coins, screws,and who knows what else,vac out all the water with a shop vac, and next time open the door,look around the opening where you put the clothes into the washer and you'll see a tag with the model and serial numbers,just need the model number,remove the bottom panel,look at the pump,if the center part can be removed,turn it slowly counter clockwise until the water starts to leak out and stop and vac up the water as it leaks out,do this until it's empty and then remove the center catch piece of the pump and clean it out,stick your finger in the pump and make sure nothing is stuck in the impellar,also check the rubber boot part of the hose,sometimes stuff is still in there,if the center of the pump doesn't come out,pull off the hoses to the pump and check them for junk in them and check the pump,reconnect the hoses,fill with some water and put in a spin cycle,if the water still doesn't drain out most likely you'll have to change out the pump.
Aug 16, 2011 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet, F02 code. Filter is clean, pump has great volume, pressure switch tube is clean, flex tube ball is free. Some times the machine will just stop, no code with the display flashing.
F02 Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Check both the drain hose at the back (check height setting and look for blockage), and make sure you have checked the drain filter (access door in front bottom side in front loaders- Bottom side or back in top loaders).
If the drain filter and hose are OK, next step will be checking the pressure switch. The pressure switch is the sensor that detects water level, deciding when to start/stop drain pump and when to advance to spin. When the pressure switch is clogged or defective the machine may not drain or spin. The pressure switch is located in control assembly and looks like a kind of plastic disk with 4 or 3 contacts and with a long thin rubber hose connected to the switch. Clean the rubber hose and replace the switch if that does not work. While disassembling the control panel check also if tucked inside the control assembly you find the envelope with the tech sheet. The tech sheet will describe the diagnostic procedure that may be useful to find out what the problem is.
Pressure switch is a common fault causing drain problems . If the problem was not the pressure switch next step would be reading volts while machine is cycling to test control module and pump. For safety reason I suggest the users only performing tests and maintenance that can be done with power not-connected.
Aug 11, 2011 | Whirlpool Washing Machines
My whirpool front loader say f02
If I am not mistaken f02 code means that long drain. put into spin and see if the pump turns on if it does check if water is coming out... if not need to check if there is something stuck in the pump blocking the flow for the water
Nov 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Loader will not drain or spin
Based upon your description, the drain pump has either failed or become clogged.
To check the pump, remove the bottom access panel (three screws along the bottom). There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris
If you need further assistance, let me know
Jul 05, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite HE4t Washer
Error code F02 f the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the ?Sud? error will be displayed, then 4 minutes later the F02 error code will be displayed. Potential Causes ? Check the drain hose and make sure it is not plugged or kinked ? Check the electrical connections at the pump and make sure the pump is running. ? Check the drain pump filter for foreign objects ? If the above does not correct the problem replace the pump
Sep 11, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite He 4t washer
washer weary, You need to clean the filter on the pump. Remove the bottom panel and the filter will be right in front. 3 #11 torx screws it will pull down and off. Get yourself a bucket to catch the excess water. Unscrew the filter and clean it. Check to see that nothing is in the impeller. The F02 should go away..Catriver.
F02 what does it mean
I have had this issue more than once. It was an easy fix for me (maybe a 20 minute job and best of all no money). For my F 02 error it was my 4 year olds socks that some how got down the drain line and stuck in the clean out. Here is what you do. There are 3 screws bottom of the front access plate. Remove these and the lower access plate will pop right off. Right in front you will see the pump and the drain line. It has a clean out right there. Unscrew the cap (be ready for alot of water to rush out, so have alot of towels ready). Once the water is drained remove the cap. The cap has a trap so that larger items do not get to the pump. This is where I find the socks stuck. Clean it out, tighten the cap back into place, put the access panel back on, and hit run. Has worked for me at leaste 3 times. Those pesky kid socks every time.
Apr 28, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Frontload washer
Dea, F02 is the code for long drain. Your filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 screws. The panel will drop and come off. The filter cover is right in front. Get yourself a bunch of towels and unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in. See if the washer comes back to back
Kenmore Elite 45986 Front Load Washer Logo
97 people viewed this question
Sal De
 Brian Main
Brian Main
