Question about Dryers
Dryer keeps cutting out, filter is clean, load is not too heavy, it runs for about 5 minutes then stps. If you press go again it goes every time? Can anyone help?
  • adamnic May 11, 2009
    No error codes is Fisher and Paykel, can't see model number as is on back and would need to dissasemble ducting to see it properly.
  • jdthefixer May 11, 2010
    Sounds like a bad sensor or thermostat. Check the sensor on the heat manifold to be sure it's tight and that the wiring connections are solid.
    Is it generating any error codes?
Need thermostat
Posted on May 10, 2009
My lg 2240 clean filter light blinks even though the filter is clean. when started it runs for 3 to 4 seconds then shuts off. if you wait for about a minute it will start again then shut off after 3 to 4...
This problem usually is caused by a restricted or blocked vent. The filter itself can be clean, but the duct work in the dryer after the filter, or the vent hose attached to the dryer, or the exhaust door attached to that hose is either restricted, plugged or blocked. Lint likes to build up in all areas the exhaust air goes, so check them all. The dryer has a sensor that will shut the dryer off if there is a restriction. Cleaning all of the duct work, from the filter all the way to where it exhausts outside, will usually solve this problem. An easy way to check is to unhook the exhaust hose from the dryer and run it. Does it keep running now? It is possible the sensor in the dryer has gone bad, but that is rare. 99% of the time it is lint build up in the venting.
Dec 12, 2013 | LG WM-2277HW Front Load Washer
Gas lights up for about 5 minutes and then burns out. Try to turn on dryer again, but flame won't light. I let dryer sit for aout 30 minutes and turn on again - flame starts up, but will only last...
If the flame is shutting of before it reaches the operating temperatures the likely failure is a restricted venting system. There is a high limit thermostat that will cause the flame to shut off if there is a lack of airflow due to a restriction in the vent system. Remove the lint filter screen and clean in with soap and water. The filter may appear clean but it could have a clear film of fabric softener residue covering it causing a restriction in the air flow too. After cleaning the filter reinstall it before running the next test.
For testing purposes only, disconnect the dryer vent hose from the back of the dryer and put a normal load of clothes in the dryer and start the dryer. If the clothes dry in the normal amount of time that would confirm a restriction in the vent hose or the venting system. NOTE: Do not leave the vent hose disconnected after running the test. Reconnect the vent hose.
You will likely find the clothes drying in the normal amount of time indicating a restriction in the venting.
Aug 02, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Bosch WTL5400 Drier runs fine for 5/10 minutes, then it stops and the "start" light flashes. Pressing this then restarts the process, but a few minutes later it cuts out again. I have checked...
I have the same problem, the dial to select the dry program is making a bad contact causing it to stop. Try using a different program.
I tried to clean the dial but it didn't help.
Dec 06, 2010 | Bosch Axxis WTL 5400 Dryer
Filter light is on. I pull filter - its clean. I put filter back in - filter light goes out. I start dryer. It runs for about 5 seconds and stops
Did anyone come up with a solution to the problem, we are having the same problem, except our dryer keeps running, the filter light goes out, and when the dryer is turn back on the filter light is back on, the filter is clean.
Oct 22, 2010 | Kenmore Elite HE4 Electric Dryer
MY SIMPSON MAXIDRY 362 3.5KG HEAVY DUTY DRYER KEEPS OVERHEATING AND CUTTING OUT. WHEN IT STOPS AND I PRESS THE SAFETY SWITCH IT TURNS ON AGAIN BUT ONLY FOR 10 MINUTES. CAN YOU ADVICE ME ON WHAT I CAN DO...
I would check the exhaust pipe outside and make sure it is not blocked and has good strong air flow while the dryer is running. If there is not good airflow, then clean out the exhaust hose and pipe. There could be other problems, but I would start with this.
May 01, 2010 | Dryers
My Kenmore dryer keeps cutting off
Vacuum all of the air passages including the hose to the outside vent. Remove the lint filter and wash it in hot water and detergent; rinse and replace after drying. Restricted air flow may be tripping an over-temp switch.
Oct 12, 2009 | Dryers
Kenmore Heavy Duty Dryer
If the dryer is still powered on but the motor stops, it sounds like the over load in the motor is cutting out and the motor will have to be replaced.
Feb 23, 2009 | Kenmore 63942 Dryer
Bosch Exxcel tumble dryer error code F:09
Mine did this. Because the bottom left filter was blocked the overheat cut out had tripped. This is inside the rear of the machine accessible after removing the rear panel
Aug 10, 2008 | Bosch Exxcel WVT 2850 Front Load Washer /...
Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Jun 11, 2008 | GE DBXR463EBWW Electric Dryer
Dryers Logo
144 people viewed this question
Top Dryers Experts
