Question about RCA 24F512T 24" TV
Resistor need to know the ohms on the 7 watt resistor in the sanyo tv DS27780 location rs601.power supply
  • joedirty
    joedirty Oct 14, 2007
    location #  R601 this belongs to the sanyo DS27780 (7 watt ? ohm)
    An expert who has answered 500 questions.
  • 556 Answers
down load the schematic diagram &get the value.
hope this will help you.
Posted on Oct 12, 2007
Convergence Resistors keep burning up
Some simple advice---if resistors are smoking one of the chips is shorted----The set has two voltages that go to them--one a positive voltage and one a negative voltage.
If either chip is shorted you can replace the resistors all year and not get anything. The resistors are protection in case one or both chips short----
Remove all old heat grease and install two new chips and replace the resistors at the same time.
Note that the set may have pico fuses on the power board also.
Jun 09, 2012 | Sony Televison & Video
On the sylvania tv, we cannot see the picture. we called time warner tv cable, they said they could'nt help, we need to contract or e-mail the sylvania for the code remote contact.
The power supply startup resistors on the inverter board, R1943, R1944, and R1945 may be open or changed values. You will have to replace the inverter board. If you think you can repair this on a component level, I will give you the new values for the resistors. Some of these TVs may have old values or the new values. Regardless you will need to use the values I mentioned. R1943 is 330K ohms at 1/4 watt, R1944 is 330 ohms at 1/4 watt , and R1945 is 39 ohms at 1/4 watt. There are three different inverter boards. These are as follows, A91F0M1-001IV,A94F0M1V-001-IV, and A91FSM1V-001-IV. When you look inside your TV, search for the correct number on the board. This info is my best advice. I'm glad you asked me. Thanks and show all hands of support!
Jul 06, 2011 | Sylvania LC320SLX 32 in. LCD TV
3 watts metal oxide resistor. Don't have to worry about volts. Just use a 3 watt
Apr 03, 2009 | RCA 20F511T TV
TV won't turn on
have a repairman check this the tech infor for repair is:
In rush Limiting Resistor location R8010 its comen for this model to open the resistor
its on the power supply module value is 6.8ohms at 7 watt standup cement Style resistor.
I think this will do it.
Jan 13, 2009 | Samsung HCL4715W 47" Rear Projection...
Samsung pcl5414r power resistors and pico fuses??
Hi again and welcome back to FixYa,
Appreciate the direct "Ask Me'.
Based on your original post, only the STK ICs were replaced. Presumably 392-040, the surrounding resistors and pico fuses could very well have been affected as well. Depending on the board revision (pls confirm location numbering on the actual board), the resistors could be:
RZ104 -RZ106 - 270 Ohm 1/2watt
RZ133-RZ135 - 27K Ohm 1/16 watt
RZ136 & RZ138 - 3.3K Ohm 1/8 watt
RZ146 and RZ147 - 3.9 Ohm 2 watt
RZ148 and RZ149 - 150 Ohm 2 watt
while the pico fuses would look like the image below.
Good luck and Thank you for using FixYa.
Dec 26, 2008 | Samsung PCL5415RB 54" Rear Projection...
Avm 3259 picture problem
Vcc is on Pin 6 of the vert. output IC so you can trace that back to it's feed resistor (not sure the location number but you can find it easily by following the circuit trace). Depending on what your problem is you may need to replace some electrolytic capacitors as well. Follow pin 7(pump up) back to it's electrolytic cap. and look for swelling or bulging. Look for other bulged capacitors in the vertical section. You may also identify a bad resistor by a discolored look but not always, if in doubt meter it.
Let me know if you need some more info.
Oct 03, 2008 | Sanyo AVM-3259S TV
Help follow-up
There is no kit for your repair.If your original IC's = STK392-110...
quality Sanyo-made will cost you $14.00 - $16.00 each.If you buy Panasonic packaged IC's,the part # is C5AA00000203 and they cost about $30.00 each. Use an ohm meter,your eyes and nose to locate burned resistor(s).Usually one or two 6.8 ohm
1 watt light blue color a total of twelve, I think.....However,your next step is to order / purchase first grade IC's = Panasonic is going to be your best choice.........and some 6.8 ohm 1 watt
Aug 12, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Toshiba tw40f80, replaced both convergence ic's, power light still blinks
Solder yoke plug and vertical IC connections.....try again.
Let me know.....T.
BTW....Tosh recommends STK-392-110's replace with -110T's
Toshiba OEM.....then there is no question about resistor value
Aug 03, 2008 | Toshiba TW40F80 40" Rear Projection...
CT-27SX11E Fixed but need advice on R value
i would not recomend replacing the 7w with the 5w, beacuse the resistor will allways run hot, hotter then the resistor should be. the resistor could possible melt anything that touches it & will not last as long as the original before it goes bad. find a 7w, if just for safty reasons.
Nov 01, 2006 | Panasonic CT-32D12D 32" TV
RCA 24F512T 24" TV Logo
165 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
