Question about Brother MFC 420CN All-In-One InkJet Printer
Can you force a printer to print in grayscale?
My brother mfc wont print anything even though there is plenty of black ink, because I am out of cyan. Can I make it print in grayscale and bypass the need for color till I can replace the cyan cartridge?
  • bmclemore May 10, 2009
    nope, wont work..a note at the bottom says that if one cartridge is out, it will not print in color or in grayscale. I have delt with this before in Brother printers an was wondering if anyone had found their way around it.
  • 1,170 Answers
Yes, you can bypass the color printing. The software you are using for printing can help you change from colour to gray scale or adjust it in the printer properties.
Posted on May 10, 2009
I have a all in one color LC61 printer, do all colors have to be filled to print blk only?
Greyscale is color not black only.
You can print in black and it will look grayscale only darker, printers are a pain to work with after a year has gone by, I can expect almost a half hour to print something with my $400 epson because one of the colors is out even though I never printed in the last year a colored page. I take the color cartirges out and they are empty, but I only print a page 2-3 times a year. I use the scanner all the time. Brother and epson have their print heads in the printer not the cartridge so make sure your inks are always have something in it or it will be miricle for the printer to last more than a year. Check colors every other week. One Epson printer only lasted 3 months because I never used it(print head dried up). Never use the set up with tubes running outside printer to small tanks of ink if you only use it occationally.
May 11, 2014 | Unknown 10pk 4B,2C,2M,2Y Compatible LC61...
My brother CIP-J140W is only printing in cyan. I had accidentally put the cyan cartridge in the black cartridge spcae. Despite changing them around, cleanre the head etc, it is still only printing in cyan....
Oops, You really have to print, selected black, till all Cyan ink is gone. This could take a while. Cleaning the head, won't solve anything.
If you really want to clean the ink out of the head and everything, you need special cleaning fluid. Refill shops do have this fluid. You should bring some cleaning fluid in the tube under the black cartridge, in the tube where the ink is going in. If you have a syringe you could try to gently press some fluid through the tube. Not to strong. could damage the head.
After placing back the black cartridge, select clean the head and let the printer do some black and withe print jobs, till the cyan is gone.
Nov 27, 2013 | Brother MultiFunction Center MFC-440CN...
After I replace my black ink cartridge the message " install cyan..." comes up. I don't know what is cyan is. My printer is a Brother Multi-fuction center mfc-3360 c I am only replacing my...
Possibly at the time of release catrid black ink, color ink catrid position slightly annoyed and thought catrid sofwear printer cyan ink has been removed so that the request to install cyan. But it could also be due cyan ink has run out and ask to be replaced as new. Please check the contents of cyan ink may have run out, if still a full release catrid cyan and black, then attach it again, then go into maintance, and do head celean and do nozzle check or test printing
Aug 23, 2011 | Brother Multi-Function Center MFC-3360c...
I want to print in just back and white, but my printer wont do it.
In order to print in Black and White using grayscale, you will need to adjust the printing preferences within the driver. To change the printer properties complete the following steps:
1. Open the Printers Folder:
  • Windows 2000: Click Start => Settings => Printers.
  • Windows XP: Click Start => Printers and Faxes.
  • Windows Vista: Click the Start button => Control Panel => Hardware and Sound => Printers.
  • Windows 7: Click the Start button => Devices and Printers.
2. Right click on the Brother printer driver and left click Printing Preferences.
3. Click the Advanced tab.
4. Select Grayscale.
5. Click APPLY => OK. Your printer will now print in grayscale.
Oct 26, 2010 | Brother MFC-990CW COLOR INK-JET MFC Ink...
Black is not working in my brother mfc-240c printer
did you use genunie brother black ink cartridge?
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
I located a page on http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
Try the forum, there are alot of issues like yours.
If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Apr 06, 2010 | Brother MFC 240C All-In-One InkJet Printer
I have a brother MFC-490CW and replaced the black ink, and my color ink has run out. It will not let me print as it says ink is low, so it won't even let me use the black? How do I print with only using...
By design, Brother printers stop all printing when one of the cartridges is empty. This is done to avoid cleaning cycles sucking air into the system, which could possibly damage the printhead.
Even if you print in black only by changing the print settings to "Mono" or "Grayscale" to avoid printing in color, cleaning cycles would still **** air from the empty color cartridge because they are programmed to clean ALL the ink nozzles. The only way to continue printing is to replace the empty ink cartridge(s).
After replacing the empty color cartridge, you could print in "Mono" or "Grayscale" to make better use of just the black ink.
Jan 21, 2010 | Brother MultiFunction Center MFC-440CN...
Printer wont print
Try remove all cartridges then put back it one by one.Make sure the color cartridges are not empty too.The printer need all cartridges not empty to initialized and working.
Nov 25, 2009 | Brother MFC 490cw Color Inkjet...
Out of color ink; won't print black and white.
The printer will need the colour ink to be replaced otherwise it will not print at all. You can try pressing the Start/Reset button but this will most likely not work and the only way forward is to have a colour cartridge with ink in it even though you may never use it!
Oct 07, 2009 | Brother MFC-465CN InkJet Printer
Printing when ink is low
The machine requires all color in order to print anything, even just black and white copies. You need to install a new cyan ink before it will print.
Feb 10, 2009 | Brother MultiFunction Center MFC-440CN...
Cyan ink won't print on Brother MFC-665
talked to Brother, cost to much to fix, replaced the printer.
Dec 24, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
956 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
