Question about Pioneer PRO-520HD 53" Rear Projection Television
Replacement bulbs i have a 53" pioneer rear reflection tv. where can i buy replacement bulbs when they burn out?
  • sox57 May 10, 2009
    thank you very much. i actually have a sd-532hd5. searching the internet turned up nothing. i will call pioneer. thanks again.
    President:
  • 272 Answers
From Pioneer, unfortunately you have to call them.
Whether you're looking for a replacement remote control for your television or a faceplate for your car CD player, Pioneer Parts has more than 260,000 parts available.
Monday thru Friday: 10:00 AM to 7:30 PM EST
(800) 228-7221
(310) 952-2247 (24 hour Fax)
Posted on May 10, 2009
  • rjbeg123 May 11, 2009
    If my solution helped you please rate me!
Pioneer 52" projection TV, SD-533HDS,
It is likely that the CRT's (picture tubes or bulbs) are weak. It is a major job to change and all three should be changed to make the picture like new. However, it is not costwise to repair this old of a TV even if you can get the tubes. I estimate the cost of each tube is at least $200 each. I would call Pioneer and give them your model number and see if they are available. Only a trained technician should change the tubes because it requires a lot of time and setting up of the tubes and other things.
Jun 04, 2011 | Pioneer SD-533HD5 53" Rear Projection HDTV
Tv doesn't come on clicks on for a minute and returns to standby mode
You need a new projector bulb. Google up your model and buy the best warranteed one you can find. Buy a "caged assembly" and not just a bare bulb.
Then unplug your tv and get a screwdriver. Follow your model's instructions and just snug down the electrical screws. Do not overtighten them.
Then consult your manual on how to reset the lamp timer so it knows you put a new bulb in and fires up from the first try.
Treat yourself because you've just saved yourself a trip from a repairman!!
Aug 11, 2010 | Pioneer SD-533HD5 53" Rear Projection HDTV
Is it possible to replace the bulb in this tv or something like that? I was watching it the other day when a loud pop occurred and there was some burning smell accompanied by the picture and sound going...
Shop around for the Big Screen repair Tech. Shop.The problems u discribing,the tv have more than a dead projection bulb.Circuits boards have burn components,must be trouble shoot and replace first.Before even know the static of the projection bulb.
Jul 16, 2010 | Sony KP-53S65 53" Rear Projection...
TV Bulb
Tries websites like Ebay.com Partstore.com to buy bulb replacement and many other parts.
Jul 14, 2010 | InFocus ScreenPlay 61" Rear Projection...
Cannot use convergence on remote for Pioneer SD-532HD5Pioneer SD-532HD5Pioneer SD-532HD5Pioneer SD-533HD5 53 in. Rear...
Ur convergence it dead.Must know how to solders.Tries these Websites.Tv Repair World.com,Tvrepairkits.com to buy a convergence kit.
Dec 29, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
My toshiba rear projection 55 inch tv is showing a double reflection in blue how do i fix it
Replacing the Convergence IC'S should fix it. They should be STK392-110's. I would replace both of them as a pair.
I hope this helps,
Skyassoc
Nov 14, 2009 | Toshiba 53H71 53 in. Rear Projection...
"pop sound", picture out, burning smell...?
Usually, yes. A bulb that has audibly 'popped' will be apparently bad if you pull it out of the TV (shattered). Other times this is a lamp ballast board.
May 18, 2009 | Sony KP-53XBR45 53" Rear Projection...
Pioneer projection blurry picture
Sounds like you lost the converigence. Have you tried to realign the convergence through the user menu? Try that first and see what happens.
Jul 20, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer PRO-520HD 53" Rear Projection Television Logo
412 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
