Question about Microwave Ovens
Cant set the clock
How do i set the clock
    Sergeant:
  • 296 Answers
Hi
In most brandsof microwave oven, you set the clock by one of these combinations of key presses:
Clock > time digits > Clock
Clock > Clear > time digits > Clock
Clock > time digits > Start
If that doesn't work, please reply back with your brand and full model number.
All the best and do rate this answer if u r satisfied.
thankyou
Posted on May 10, 2009
  • Phil Thompson
    Phil Thompson Aug 21, 2015
    CE 091 dm as in Cascade Microwave. Press Clock, Beep, no numbers operate. Numbers set otherwise for time of 'cooking..' but NOT for Clock.
Forgot how to reset clock on Microwave sharp carousel
Posted on May 22, 2009
Sharp R395 Microwave.. cant set clock.
Sounds likein the moving you loostened wires in the front panel or flexed the circuit board inside. You will need to open the control panel and inspect it. It could also be just some dirt or dust getting on the controls....blow it out with clean dry compressed air!
Dec 31, 2012 | Microwave Ovens
I have a GE sensor microwave oven. Tried to heat food and sensor eror came on. Everything is running even the timer but no sound but the timer is running. Cant this be reset pls help
HELLO.
This is the solution to reset your microwave.
1 Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
1. Set the clock by pressing the "Clock" button.
2. Turning the dial on the GE sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
3. Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the GE sensor microwave oven.
4. When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
5. Press the "Start" button to allow the clock to begin on the GE sensor microwave oven.
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I dont know how to set the clock on the oven, therefore I cant start the oven
It depends on the make/model of the set.
All you need is to press and hold and the clock will blink on the hour/minutes and it must be changed and set. Use the button marked clock to press to hold for setting. Change time using the 0-9 key pads by typing the correct time..
Jul 23, 2011 | Microwave Ovens
The clock is flashing all zeros - cant set it
Press: Stop cancel
Press: Clock or Autostart (depending on model)
Set time
Press clock or autostart.
Should have the time set......
If this is too generic pleae provide a make and model and I wil see what the manual says verbatim.
Kelly
Aug 21, 2010 | Microwave Ovens
Cant figure out how to set clock
try this first,
1 push button= clock
2 set the #s of the time
3 repush the clock button
Jun 24, 2009 | Emerson MW8168B Microwave Oven
I cant set the clock
Is there a button that says clock or has the picture of a clock? if so... just hold it down.. and then when the colon blinks, use the number pad to type in the time.. and then press the clock button again.
hope that helps
Jun 02, 2009 | Panasonic Microwave Ovens
Westinghouse microwave WST3502..... Problem:
Press "Clock", type in the time on the keypad and then press "Start". The clock runs a little slow (at least on mine) and I have to reset it about once a month. It gets about 10 - 15 minutes behind after awhile.
Sep 06, 2008 | Westinghouse WST3501 Microwave Oven
MW8107WA 1000 Watts How do I set the time? .
Cant find a manual, but on most microwaves, the clock is set by pressing the 'Clock' key, then the numbers for the time, and pressing the 'Clock' key again.
Jul 13, 2008 | Emerson MW8107WA Microwave Oven
Set the clock Sanyo EM-V860
You can request the manual in PDF form here: http://www.sanyo.com.au/aim.aspx
Mar 05, 2007 | Sanyo EM-S9515W Microwave Oven
Microwave Ovens Logo
1,760 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
