Question about Sony PlayStation 2 (PS2) Console
Ribon Cable where can I get a replacement for the little ribbon cable that conect the controls
  • 709 Answers
Hi Aj1938,
If it is the white colored ribbon that goes to the Power/Reset and Eject buttons, I have several. I can send you one for $1 plus shipping $1.  Send me you email address, I will invoice you for the part and send it to you.  I have the other cables as well. just let me know which one you need.  www.playstationclinic.com and my email is [email protected]
Posted on Oct 12, 2007
  • Greg Stokes
    Greg Stokes Oct 14, 2007
    Hi Aj,
    I have all the ribbons you need, just contact me  at [email protected],  they are all $1 plus $1 shipping.
SOURCE:
My pc is dad.it don't initialing pavilion dv 6000z
usualy is a ribon cable you have to change, it conect mainboard and power buton
Mar 20, 2010 | HP Pavilion dv6000z Notebook
Nokia n95 8gb lcd is blank but i hear it's turning on
if its blank you have to replace the lcd screen with a new one.
sometimes it maybe a flex cable problem which occurs in some slide phones.
at mobile phone repair stores, the cost of an original lcd screen replacement is usually $150-$200, though sometimes an original lcd screen may not be fitted into your device but rather a hong-kong made one which is similar to the original but is less brighter and a little less sharper.
if you take it to a nokia care centre to replace the lcd screen you may have to pay over $250.
you can just buy an lcd screen off ebay, replacing the lcd screen yourself isnt hard with the tools provided. you just have to take the ribbon cable from the old lcd screen and insert the new lcd screen and plug in the ribbon cable for it.
the reason for original Nokia n95 8Gb lcd screens being so expensive to repair/replace is that it is also the same lcd screen used for the Nokia N96.
cheers.
May 30, 2009 | Nokia N95 Cellular Phone
Brother CE-70 typewriter. Was typing perfectly well. Over about 15 characters the impact on the print head reduced to nil. Although printhead appears to strike the daisy wheel the character does not strike...
Make sure that the ribbon is moving. If characters are piling up in the same spot on the ribbon you will get this problem. Easiest fix is to replace the ribbon. Many brand new ribbons can have a problem. If this dosent solve the problem it may be a mechanical problem with the mechanism that drives the ribbon, requiring a technician to repair.
Oct 22, 2008 | IBM Wheelwriter 30 Typewriter
3gb microdrive
have you checked the cables that connect the drive to computer first remove the ribon cable from hard drive and power up computer check if hdd is spinning up you may feel a slight vibration if you feel this vibration then power off if you have the cd ribbon cable still attached place this end to hdd then power on if boots in then you need a new ribbon cable. if hdd is not spinning replace hdd hope this has helped
Aug 08, 2007 | Hitachi (MD4GB/A) 4 GB Hard Drive
Samsung slider phone
hi reckon you have a faulty ribbon cable replace and it should be ok thats if a software flash doesnt sovle ya problemas lylo recommends mrjazon
Jun 18, 2007 | Samsung SGH-D600 Cellular Phone
GE Oven JKP15
it is the connector for the ribbon cable on the back of the control panel. I bought a new panel as well and figured out it is the ribon cable connector in the back doesn't hold the ribbon well . I am looking for the part to replace it on line with no luck yet ( the whole board area is 178.00 us dollars so i just want the 5 dollar or so ribbon cable connector to soder in.
Jun 10, 2007 | GE Profile JK915 Electric Single Oven
Pioneer DV-C36 disc tray will not stay open
Solution for Pioneer DV-C36 Multi Disk DVD player - tray door will not stay open.
My player would open the disk tray when the open button was press but when the tray was fully open it would retract
back into the unit leaving no time to change or load disks.
I found a poor connection at the ribbon cable connector was causing this problem. A seven conductor ribbon cable
connects the main unit with the travelling tray. A position switch (S21) senses when the tray is fully extended and retracted.
On my player pin 1 of the ribbon cable connector on the travelling tray was not making an electrical connection which
causes the control system to retract the tray. The fault lies in the connector - the tang was not pressing against the ribbon cable conductor.
I was able to desolder the connector and pull the contact out just far enough to reform the tang with fine needle nose pliers.
This is very tedious and required an eye loupe for magnification.
Tools required:
#1 and #2 phillips screwdrivers
Soldering and desoldering irons (or other desoldering tools)
Fine needle nose pliers.
Remove the tray ribbon cable
1. Remove the cabinet cover - 6 screws. Open the tray. To keep the tray from retracting pull the power cord when the tray is extended.
2. Remove the front bezel from the tray. Gently pry up the bezel by relesing the catches with a small screwdriver. Allow the tray to retract.
3. Remove the front panel - undo large ribbon and wire connections on right, remove screws left and right, release
two catch tangs on bottom edge using a small screwdriver on the inside of the unit.
4. Remove the white plastic cover over the laser mechanism ( 2 screws) Remove the disk carrier by removing the center screw.
5. Extend the tray again. When the tray is out the small ribbon cable is visible below the tray. Undo the ribon cable where it attaches to the main unit unit.
6. To slide the tray off the main unit use a small screwdriver to depress the stop catches (2) in the tray. They are molded into the tray.
Pull the tray out further then lift up.
7. Flip over the tray and find the small circuit board the ribbon cable goes to. Desolder the motor wires (red and black) and remove the 2 screws
holding the circuit board and position switch.
Use a multimeter to confirm there is an open or poor connection in the ribbon cable connector.
Remove the ribon cable and inspect the connector with an eye loupe or other magnification device. On my player contact #1 was not positioned properly
to press against the ribbon cable conductor. You can either replace the connector or repair it.
Warning: repairing the connector may damage it.
To repair the contact desolder the connector from the circuit board. Bend the circuit board prong straight and push it into the body of the
connector which will extend the contact out and the contact can be reformed. Be very gentle. Bending the contact may cause it to break.
Reassembly is the reverse. Don't forget to solder the motor wires with the proper polarity. Red and Black are labeled on the circuit board.
May 28, 2007 | Pioneer DV-C36 DVD Player
EM 500 RIBON CABLE TORE how to replace?? HELP!!
It might be possible to repair the tear. You'd need to bond a plastic backing to the back of the ribbon to support it. Clean off the front layer to expose the torn conductor ends then paint a thin strip of conductive epoxy or car heater matrix repair along each of the flat wires. Finish off by covering (when set) with scotch tape. Everything needs to be completely squeaky clean (use alcohol) before you start.
Sep 05, 2005 | Casio Cassiopeia EM-500 Pocket PC
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
