Question about Harley Davidson Harley-davidson Motocyclette Hardwood Motorcycle
The starter wont kick over bike engine
Electric starter------- it seems when i try to start my bike, the starter just spin's and the engine doesn't crank and I just changed the starter. i checked the battery, it was low on water I filled it up- put a battery charger on it for a day. it cranked over but it was weak. I took an hour drive came back home, turned the bike off and tried to start it again. It started doing the same thing. i have a tender charger on it now
  • Anonymous Mar 22, 2014
    harleyfxrs@bellsouth.net
    Ken
  • 351 Answers
I had that problem with my Harley, ended up being in the switch on the handle bar.
switch was about $80 australian
Good luck
Posted on May 10, 2009
Kawasaki starter not engaging
Hi, Ricky the starter drive/Bendix/clutch is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Starter spins but engine does not crank
Starter spins but doesn start the bike Ex 500 com The home of the Kawasaki...
Starter spins but doesn turn the engine
Mar 22, 2017 | kawasaki Motorcycles
97 roadking, not going into gear, starter just spinning while bike is in neutral, in gear bike just free-wheeling push the starter and bike lurches forward but then starter just spins
Hi Rod, sounds like your starter drive is going south. I'm sorry you can't find the first and very best tool your Road King ever needed, but don't despair for a mere $6.50 you can download another one at the website below:
Harley Davidson Manuals Mark Workshop
Good luck and enjoy the video.
Mar 26, 2014 | Harley Davidson FLHR-FLHRI Road king...
GS550 Electrical Problems.
try carefully shorting a screw driver accross solenoid the two big nuts with ignition on . try a meter on continuity starter casing to earth
Jul 18, 2013 | 1980 Suzuki Gs 550 L
Starter wont start bike it just spins
Hi, Anonymous the starter drive/Bendix/clutch is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day. Starter Clutch Problem
Starter spins but doesn turn over the engine Yamaha Star Forum
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-36_96.pdf
Jun 11, 2012 | Yamaha V Star 1100 Classic Motorcycles
Starter works but gears seem to free spin, wont crank engine
sounds like the sprag clutch has failed. If you can see the large gear that sits behind the rotor and its turning but the rotor isnt turning the sprag clutch has failed. Very costly. usualy you would have a missed start eg not engaging every now and then before this fails all together.
Jul 01, 2010 | 2003 Yamaha V Star 1100 Classic
I have a ktm 640lc4 (2002) it has a leaver in front of the clutch leaver. what is this for?
Is it a kick start or does it have a kick starter in addition to the electric start? If so then it is a decompression lever which you pull in when you are trying to start the bike by kick start. Hold in the lever and try the kickstart vs not holding the lever. You'll feel a huge difference.
Dec 03, 2009 | 2002 KTM LC4 640 Adventure
Fault with electric start on my Suzuki GSF 250 Bandit
Check that the clutch is in, kick stand up, and neutral light ablaze. Then try your start button. When you had it running and hit the button, the starter engaged at a slower speed then the bike engine was turning, which led to the stall. The stall means your starter works. If the starter works when the engine is running then it is wiring. Check your kick stand wiring along with the clutch wires which plug in on the handlle bar or where the clutch cable enters the engine.
Oct 18, 2009 | 1995 Suzuki GSF 250 Bandit
Gilera dna 50cc electrical starting problems. It was ok now it spins but wont turn over only had it a day!! could it be petrol or lack of it. the kick start works
it sounds like the bendix on the starter is bad you can try to remove the starter and spin it off of the bike to make sure
Apr 11, 2009 | 1992 Gilera Saturno Bialbero
Harley Davidson Harley-davidson Motocyclette Hardwood Motorcycle Logo
292 people viewed this question
Top Harley Davidson Toys Experts
Tre Elkins
ray gallant
L Pfaff
L Pfaff
Are you a Harley Davidson Toy Expert? Answer questions, earn points and help others
