Question about iLO DVDR05 DVD Recorder
No disk message
After loading a fresh disk and it goes through the "loading" routine, it reports that there is no disk in the machine. I've tried both "+" and "-" disks and get the same result. It also won't play previously recorded disks.
Any suggestions on what I might check?
Thanks,
Bill
  • Damador Nov 15, 2007
    I've put dvd/r and dvd/rw and neither one is detected. Even after I've recorded a dvd from another device, it still doesn't detect it.
  • Anonymous Sep 28, 2008
    when I put a disk into the recorder it comes up and says no disk. So I eject it and put it in again and it still comes up and says no disk.
I'd say if you've tried cleaning the lens, tried different brands of discs, tried discs from other devices and that doesn't help, then its time to give up. I bought one second hand that wouldn't recognize anything and I couldn't fix it. I took it back.
Posted on Oct 31, 2008
I have the same problem
Posted on Sep 13, 2008
SOURCE:
Recently had D1 color screen. Now I cannot load floppies or disks. I keep getting error messages. I did re calibrate the machine. Any suggestions is appreciated. Thx
Sound like your floppy disk drive has failed. However, if you have a vacum that will blow, try blowing air into the disk drive in case it has some thread or other debris in it. Good Luck!
Jan 05, 2015 | Sewing Machines
Unable to format Seagate ST9500423AS
Have you tried reformatting your hard disk? this happened to me when i tried to us PartionMagic tool. my hard disk stopped working tho' it's still showing up when i plug it in another PC. this is how i get it working again:
i plugged my hard drive to another PC and i used DiskPart to clean it and i formatted it in Windows Disk Management.
it worked for me and i doubt, there was an error partitioning my hard disk so i needed to make it fresh again.
Apr 18, 2013 | Seagate 500GB ST9500423AS 7200rpm SATA2...
I have a DMR EZ48V. I was copying a vcr to a DVD last night, and it suddenly shut down. I believe there was a fault in the DVD disk (it has happened before). The machine shut itself off and began an...
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. ....
Mar 10, 2017 | Panasonic DMR-EZ48VK DVD Recorder
NEW MacBookPro crashes! I just bought a new macbookPro and it has crashed on three different programs; won't download the manual from online (get the beach ball) and makes a sound when power-ing u
The two "whirring" noises that you hear on power up is normal. The beauty of having a new macbook is you can reinstall the software very easily and a fresh install should fix your problem. Put the disk that came with the machine into the disk drive and turn the computer off. Turn it back on and press and HOLD the "alt" button until you are given the option of booting from your hard drive or your disk. Choose the disk and when it boots up, FIRST go to disk utility and verify the hard drive. If it comes back with no problems, proceed with the fresh install of the system by following the prompts on the disk.
Jul 07, 2012 | Apple Computers & Internet
My hp pavilion dv7-4285dx has lost everything, os and all. How can I get it to read the recovery disc I ordered from HP?
What makes you think you've lost everything? Unless you specifically instructed your computer to Format the hard drive, I would doubt very seriously that you have lost everything. Everything might still be there, but a virus has hidden it to make you think you've lost everything. Oh, one more way to lose everything is to interrupt a System Recovery before it completes, or interrupt an Fresh Install of Windows before it completes.
A lot of times the System will think you've lost everything because somehow a setting the bios was changed either by you or some virus and it has set the hard drive where it is not detectable. Turn your computer off then watch the screen to see which key you have to hit to get into the BIOS or SETUP or System Setup.
Once you are in the BIOS scroll through it looking for AHCI that will be associated with disk drives or disk controllers. If it is Enabled, Disable it and Boot your machine. If it is Disabled, Enable it and Boot your machine. In other words just change the settings for AHCI.
Do that and report back.
Mar 22, 2012 | Computers & Internet
Error Message This embroidery card cannot be used with this machine
Is it a pre-loaded card - or one you add patterns to?
If its one you add patterns to, make sure the pattern isn't too large for the machine. EG if machine does 4"x4" and you've loaded a 5"x7" pattern, try down-sizing the pattern/ breaking it up into smaller sections to load & sew
Feb 16, 2012 | Brother SE-270D Computerized Sewing...
We have messages in the memory but keep getting message to 'load Paper' there is paper in the machine . I hvae tried putting fresh paper in , but it comes up with the same load paper message?
first thing is you have to insert new A4 sheet in to the rec/paper tray.then press the STOP key.after machine try to feed the paper in to the printer unit and you can get print.( if the machine cant feet the paper,the machine have some paper feeding problem and you have to get technical support to solve this problem)
Mar 07, 2011 | Canon L220 Plain Paper Laser Fax
I cant donwload yahoomessenger 9.0 version
after i submitted my complains i tried loading the yahoomessenger 9.0 again and it loaded there after i clicked on the download button and it no longer gives error message
thanks.
Jan 02, 2009 | Yahoo Messenger
iLO DVDR05 DVD Recorder Logo
99 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
