Question about Sanyo PLC-XP55L Multimedia Projector
Sanyo PLC-XP55 "new" both temp and ready lights flash
The unit is near new, less than 50 hours on the lamp. I bought it on Ebay from a reputable dealer as a working demo tested but no warranty. It starts normally when the power button is pressed but as soon as the lamp strikes a few seconds later the temp and ready lights both flash the fan slows and it goes into a "locked standby" mode. Page 42 of the manual advises to remove power and try again but if it happens again "the internal check and service will be required".
Any checks I can do to solve the problem or have I bought an expensive lemon in need of a major repair?
One of the common problems on this and the 56 model is the exhaust cooling fan, the reason being that due to the heat given off from the lamp assembly the bearings dry up, even if they dont fail but go stiff, this also causes problems because inside the fan it is fitted like most of them now with a rotataion speed sensor and the system control monitors the pulse reference.If this changes and is not upto speed to keep the lamp cool enough the internal heat sensor detects this and the unit locks up into protection mode to protect the lamp assembly from getting too hot or even exploding.Kind regards John Williams www.jvsvisual.com
Posted on Jun 04, 2009
    Genius:
  • 1,447 Answers
Hi
When it flashes, how many seconds is the interval? If its one-sec interval chances are you are having a hardware issue with the projector. You can clean the filter/exhaust of the projector and the other option is try to reseat/remove and reinstall the lamp of the projector.
Hope this helps
Posted on May 10, 2009
My Sanyo plc su20n comes on but shutts off after a couple of minutes. Does not give a temp warning just ready indicator goes of and picture goes off. IF you wait a couple of minutes the ready light will...
check the physical nature of the lamp in the projector. around the filament of the lamp, you might notice dark corrosion building around it. this what normally cause premature shut off.
Sep 14, 2011 | Sanyo PLC SU20N Multimedia Projector
I have a model PLC-XT11 and when I turn the power on the temp light and green ready light begin to flash. The red lamp light is on steady. I replace the lamp but no luck.
one or more of the fans may not be working right. also, the temp sensor may be shot. if the last time you used it it wasn't shut down properly, it may still be in cool-down mode.
Nov 06, 2009 | Sanyo PLC-XT11 Multimedia Projector
Hello, I have a PLC XP45L. As soon as I turn on the projector it goes off. The only light on top of the projector is the READY light. We replaced the lamp last year and probably have around 50 hours on...
good day mr david, just clean the air filter of your projector, check all the fans if working... if this problem occur again your lamp ballast is defective.
jahting
Oct 29, 2009 | Sanyo PLC XP45L Multimedia Projector
How do i replace the lamp
remove the lamp door, remove the old lamp (2 or 3 screws), replace with new lamp, replace door, reset lamp timer (menu-settings-reset lamp timer-yes).
Oct 15, 2009 | Sanyo PLC-XP55 Multimedia Projector
I just replaced the lamp on my Sanyo PLC-XP55 projector and reset the lamp counter but now it won't turn on. When I press the power button, it goes into a cooling mode for 90 seconds and then never turns...
did you get the bulb from sanyo, or from another company that sells aftermarket bulbs? some of those are cheaply made and malfunction shortly after if they work at all. find your reciept, take it back and get a new one.
Jul 22, 2009 | Sanyo PLC-XP55 Multimedia Projector
Sanyo plc-xp46 lcd projector
In the on-screen menu...
Press MENU, go to SETTINGS ICON, Move to Lamp Reset
Also, to see lamp hours used, press and hold the UP ARROW (on the unit, not on the remote) for 30 seconds while projector is on
Feb 10, 2009 | Sanyo Projector Lamp for PLC-XU100,...
Sanyo PLC SW20AR - Shuts itself down
check the follwoing :
check lamp physically for melted filament, white deposits on filament/ reflector, if so change lamp
if lamp looks perfect, the ballast needs to be replaced, also check for fans if they are running fine
Feb 08, 2009 | Sanyo PLC SW20A Multimedia Projector
Temp warning
Clear the air flow and replace or clean air filters. that will solve.
Nov 02, 2008 | Sanyo PLC XF45 Multimedia Projector
Sanyo PLC-XF46N projector shuts down before powering up completely
The Fix Ya rep suggested that I try the "Reset" button located next to the Audio out on the side of the projector; this solution proved to be the fix I needed. I was able to get the lamps to warm up and get into the menu to cut back the bulbs/power consumption on start-up, allowing the projector to function for a problem-free 4 hour period Unfortunately, I had the same issue this morning, but the same fix worked again.
Jul 06, 2008 | Sanyo PLC-XF46N LCD Projector
Sanyo PLC-XP55L Multimedia Projector Logo
214 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
Electro Med Services...
k24674
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
