Question about D-Link AirPlus DWL-G630 802.11g/b Wireless Adapter
Connecting to wireless network
Using the dlink dwl-g630 to connect to sons dlink 1310 wpa network.  I can only connect with using static ip address.  When i do connect its for 8 seconds then disconnects and the cycle repeats. When obtaining an IP automatically it just cycles through aquiring an address, we never connect.
I too am having an issue with the D-Link DWL G630 card. I am tyring to connect to a D-Link 615 AP. My previous D-Link router died and I recently purchased the 615 and it worked fine with my Inspiron laptops using WPA2-Personal/TKIP-AES encryption.on built-in Intel 2915 mini-pci cards. Well I got a couple of old latitude LS systems for the kids and stuck in a couple of the DWL G630 cards. The only way they work is if I turn off encryption on the AP (I don't want to do this). The tech support guy at D-Link said this is the only way to make it work -- I'm not believing that. Any ideas?
Posted on Jan 21, 2008
    Brigadier General:
  • 6,966 Answers
Offhand, I am getting the impression that either way (static or auto), the AP is the one responsible for disconnecting or refusing you. One reason is that you do not have permission to join the network or there is a security key that you need to be able to access.
A couple of clarifying queries pls:
1. Which configuration utility are you using for the G630, D-Links or Windows built-in?
2. Which security method is the "sons dlink 1310 wpa network" using WEP, WPA or MAC filter?
3. Have you tried different hardware configuration/settings for the 630 such as Auto Power Save, Power Management, Authentication Algorithm, Passive Scan Dwell Time, others?
4. Can you access the webbased interface config utility of the 1310 router?
Pls post back and then we can start figuring things out.
Good luck and kind regards.
Posted on Oct 12, 2007
I need to secure my wireless connection network. I have a iMac computer an a Dlink WBR 1310. How do I configure a Password to prevent intruders from using my connection?
First you will need to find the local IP address of your router. It should look something like "192.168.0.1" You might be able to find it in either your router manual or on the bottom of the router itself.
Then make sure your computer is connected to the router via wireless or ethernet cable.
Next, open your browser and type in the IP address into the address bar. It should take you to a setup page that looks a lot like a website. Find the "wireless security" tab and select a security protocol. I recommend using either WPA or WPA2. Now you can set a password. Finally, there should be "save" button on the page. Click it, then wait for your router to reboot and your network is now secure.
Jul 31, 2011 | D-Link 802.11g Wireless Router WBR-1310...
Wireless repeater
Hi there
Getting Started
Setting up a Wireless Infrastructure Network
Pleaseremember that D-Link AirPlus G wireless devices are pre-configured toconnect together, right out of the box, with their default settings.Fora typical wireless setup at home (as shown above), please do thefollowing:
1) You will need broadband Internet access (a Cable or DSL-subscriber line into
your home or office)
2) Consult with your Cable or DSL provider for proper installation of the modem
3) Connect the Cable or DSL modem to the DI-524 Wireless Broadband Router
(see the printed Quick Installation Guide included with your router.)
4)If you are connecting a desktop computer to your network, install theD-Link AirPlus G DWL-G510 wireless PCI adapter into an available PCIslot on your desktop computer. You may also install the DWL-G520, orthe DWL-520. (See the printed Quick Installation Guide included withthe network adapter.)
5) Install the D-Link DWL-G630 wireless Cardbus adapter into a laptop computer.
(See the printed Quick Installation Guide included with the DWL-G630.)
6)Install the D-Link DFE-530TX+ adapter into a desktop computer. The fourEthernet LAN ports of the DI-524 are Auto MDI/MDIX and will work withboth Straight-Through and Cross-Over cable. (See the printed QuickInstallation Guide included with the DFE-530TX+.)
Using the Configuration Menu
Whenever you want to configure your network or the
DI-524, you can access the Configuration Menu by
opening the web-browser and typing in the IP Address
of the DI-524. The DI-524 default IP Address is shown
bellow:
-Open the web browser
-Type in the IP Address of
the Router (http://192.168.0.1)
Note: if you have changed the default IP Address assigned
to the DI-524, make sure to enter the correct IP Address.
-Type admin in the User
Name field
-Leave the Password blank
-Click OK
TheHome>Wizard screen will appear. Please refer to the QuickInstallation Guide for more information regarding the Setup Wizard.
Home > Wizard
Thesebuttons appear on most of the configuration screens in this section.Please click on the appropriate button at the bottom of each screenafter you have made a configuration change.
Home > Wireless
SSID-Service Set Identifier (SSID) is the name designated for a specificwireless local area network (WLAN). The SSID’s factory default settingis default. The SSID can be easily changed to connect to an existingwireless network or to establish a new wireless network.
Channel-6 is the default channel. All devices on the network must share thesame channel. (Note: The wireless adapters will automatically scan andmatch the wireless setting.)
WEP- Wired Equivalent Privacy (WEP)is a wireless security protocol for Wireless Local Area Networks(WLAN). WEP provides security by encrypting the data that is sent overthe WLAN. Select Enabled or Disabled. Disabled is the default setting.(Note: If you enable encryption on the DI-524 make sure to also enableencryption on all the wireless clients or wireless connection will notbe established.)
WEP Encryption- Select the level of encryption desired: 64-bit, or 128-bit
Key Type- Select HEX or ASCII
Keys 1-4- Input up to 4 WEP keys; select the one you wish to use.
Home > WAN > Dynamic IP Address
Jul 18, 2008 | D-Link AirPlus G Wireless Range Extender...
Hello i have d'link airplus g dwl g630 e2 5.0 network card in my other laptop.. it has drivers installed and it connects to network, but i cant get in internet.. it says " the connection has limited...
This happens when the wireless network card fails to get an IP address from the wireless router.
To get the router to issue your wireless network card with a new IP address, right click on the wireless card icon on the task bar and click Repair.
Mar 16, 2011 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Where can I purchase an installation disc?
Send me $100 US in small, unmarked bills.
My address is on the web-site:
http://www.dlink.ca/products/?pid=DWL-G630
First, download the device-drivers from this site, and then send the money to me. :-)
Nov 14, 2009 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
I need to boost the sending signal from my D-Link wireless router so my secondary computer can access the net - presently the router works for one extra computer but keeps losing the signal intermittently...
goto start - run - .cmd - enter..type ipconfig..you`ll get ip address,subnet mask,default gateway.copy it.goto start- control panel - network connections now right click wireless network connection and click on properties and double click on internet protocol(TCP/IP) or if you are using vista goto network and sharing center - view status - properties - double click on IPv4.type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
this will fix your problem...
Jun 12, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Ping www.yahoo.com - FAILED
try to check the ip address before accessing the internet.
if you not getting a valid ip address then try to reset you d link router.
Apr 13, 2009 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Connecting an adapter to laptop running linux
Yes/No. Dlink has no support for Linux. Ubuntu should install generic drivers but it may work or just epic fail.
Apr 10, 2009 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Download driver
Please paste the following link into your browser's address bar and run the setup after unzipping the file downloaded and watch how all your problems vanish!
ftp://ftp.dlink.co.uk/wireless/dwl-g630/DWL-G630_driver_v5.11.zip
Oct 21, 2008 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Verification and signal problems
Hi Sir F,
You don't need to do a re-install of the DLink WiFi adaptor since I believe it is running as it should (as you posted). All that is needed is to configure it to exclusively select only your NetGear WiFi Router. This could be done in the DLInk Wizard (Start/All Programs/DLink.../) set the DLInk to connect only to the SSID of your NetGear. Though it may pick up your neighbors WiFi, the DLink will only acknowledge the presence of the other WiFi but connect only and always to the NetGear.
A couple of other things that may help improve your WiFi connection. Use static IP add in your PC to match that of the NetGear, disable wireless security (WEP or WPA) but rather enable MAC filter and input that of your PC's WiFi Networking Card.
Should you need a more detailed instructions, pls post back the model of your router and the make/model of your PC as well as your OS.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Thank you for using FixYa.
Apr 07, 2008 | D-Link Air DWL-122 802.11b Wireless...
D-Link AirPlus DWL-G630 802.11g/b Wireless Adapter Logo
175 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
