Question about GE Energy Star WCVH6260F Front Load Washer
How to clean pump
I know that the problem with my washer is that the pump is clogged because my 3 year old decided to put in a blanket full of lent into the washer with my load when I wasn't looking. I cleaned the pump filter which was loaded with lent, but it still doesn't drain. I was told that the pump was probably clogged. I have taken off the pump and I can't see how I would get in it to clean it out. how do I do this?
  • Samantha Slinkard Oct 31, 2007
    The impellar won't run freely. That's what I figured when I noticed this. I have checked the hoses, they aren't clogged. So I guess I need to buy a new pump? I haven't checked the spigot, though. I'll do that next. Thanks.
  • miek Nov 14, 2007
    I also cleaned the filter and checked the hoses as mentioned in previous notes. When checking the impeller on the pump it did not easily rotate a full 360 degrees and needed a little pressure to move it. then I put it back together and ran the rinse drain cycle and the pump had developed a ticking sound. I opened the filter again and was able to push the impeller in as if to slide it on to the shaft. I restarted the machine and the ticking went away and every thing looked good until I got F 02 at the very end of the rinse cycle. Is it possible that the impeller on the pump is slipping on the the shaft and causing a slow drain or maybe no drainage because it is slipping causing the ticking sound? It this a an oobvious case of just replaceing the motor or is there more I can do to confirm my suspicions? All checks per the oweners manual seemed to be OK
    Scholar:
  • 146 Answers
If you can turn the impellar on the pump with your hand and it runs freely, then the pump is ok. You should maybe look at the hose that leads to the drain pump from the drum, or the drain hose that goes from the pump to the sink/tub. It may be clogged with lint. Remove the drain hose from the spigot under the sink/tub and check the spigot. It too may be clogged. It is not possible to get into the pump. It is a sealed unit, unless you are able to unscrew the impellar from the motor shaft to check underneath it.
Posted on Oct 31, 2007
SOURCE:
Washing machine drain is clogged
The drain hose must be cleaned.
Jul 26, 2018 | Washing Machines
Kenmore Elite Model 44836
Check that the feet are level to the floor as this may cause the vibration. Also set the machine to wool mode this then knows what material you are putting in the machine then should cycle to that material.
Thanks J
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Dish washer not emptying
put your model # into a google search and choose a place that has parts and look up your drain pump. you probably have either a clogged drain hose, not likely, or a bad pump.
May 13, 2012 | Dishwashers
Water will not drain, makes a noise when filling, pump does not seem to be froze up.
Three things to inspect are:
  1. Clogged drain hose - cause water to back up to the pump and shut down
  2. Clogged drain tube - usually occurs when the drain hose is attached to a drain tube that empties out into the homes sewer system. Just like a clogged drain, water will back up all the way through the drain hose into the pump and shut down.
  3. Clogged or bad drain pump - Many times, debris left in pockets will work it's way into the drain pump. Over time, enough debris (paper, coins etc) could lodge itself into the pump. When the machine tries to empty or spin out, the pump becomes overwhelmed and shuts down. Sometimes, you may even see a puddle of water appear under the washer due to a clogged pump. This can also happen if the pump itself is worn out and no longer working up to specifications.
Luckily, your drain pump is easily accessible. Placing a towel or blanket down, unplug the machine, disconnect the fill and drain hoses and gently turn the washer forward onto the towel or blanket. Only tools needed are a pair of pliers and a phillip head screwdriver. After removing the drain hose and the screw holding the pump in place, it should easily be removed so you can inspect for debris (a very common problem with F&P washers.
Best of luck with your repair.
Greg
Jul 20, 2011 | Fisher and Paykel GWL11 Top Load Washer
My GE washer # WJSR2080T2WW (about 10? years old) won't drain but will agitate. I don't know if it will spin. Do I even bother to pay for a repair person to look at it?
This is more than likely a clogged or bad water pump. Most of the time it is just clogged. Check to see if the pump is clogged and if so unglog it and it should go back to work. If it is not clogged you need to see if it have power when the washer is in spin. If it has power but will not pump replace the pump. http://www.appliance-repair-it.com/clothes-washer-repair.html#GE
Oct 01, 2010 | Washing Machines
Wont drain looked in pump area does nto appear to be anything clogging it. Shoulds I take pump out? If so how? Fault code is 37 on a fisher paykel IWL12
After taking all apart and putting back together 3 times looking for some type of clog in the pump area I decided to take the hose off that is located underneath the washer. There I found a penny!
All better! I love my fisher paykel! I personally fixed it.....saved myself $95.00 per half hour and parts. Since i am a woman lots of times a repairman would have said I needed a new pump!
Jun 12, 2009 | Fisher and Paykel IWL12 Top Load Washer
Kenmore 98702 not draining
That is, in short: FO2 is the code for long drain. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 screws underneath. The panel will drop and come off. The filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in.
Apr 01, 2009 | Kenmore 98702 Stacked Washer/Dryer
Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
GE Energy Star WCVH6260F Front Load Washer Logo
576 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
