Question about Toshiba Tecra 8000 Notebook
Just bought a s/h Tecra 8000. When plugged in to the mains, there are two green lights on the front edge, but the screen is blank. Also we have a WiFi insert but can't see where it goes?
Light on power on switch keeps blinking, screen blank.
Definitely a problem with the monitor. If you can get the back open then look at the main board and the power board. You will want to look for puffy capacitors. Instead of a flat top it will look puffy like its pregnant.
If you find any like that then you need to replace them with new capacitors that have the same Uf rating and at least the same voltage or higher.
This will take some unsoldering and soldering skills. Make sure the stiped edge gets aligned with the striped edge on the board.
If you replaced them then the monitor should turn back on. If it doesn't then its a screen problem and you'll need to get a new monitor.
May 01, 2010 | Acer AL1716 17" LCD Monitor
Black screen
Sounds like your screen is being switched to "Power Save" mode due to inactivity. This should switch back when the mouse is moved. This can take several seconds on a laptop. You can remove this "Power Save" by right clicking anywhere on blank desktop, select "Properties", "Screen Saver" and "Power Settings" then select "Always On" for the monitor.
Sep 13, 2009 | Toshiba TECRA 8000 13.3" TFT LCD Display...
Toshiba tecra m4 tablet pc screen problems
Video driver update try updating your video driver
Jun 16, 2009 | Toshiba Tecra M4 Notebook
My toshiba tecra 8000 will not power on
What you need to do to test this is the following:
1 - Check if its the battery : Remove the battery, plug in the laptop and try to power on the machine, if it powers on then your battery is dead and the system board is fine
2 - With the batter in and the laptop plugged in you should get a charging LED light up somewhere on the laptop, if you do not then the board is most likley gone.
If removing the battery and plugging the laptop in still fails to start the board of spin the fans and you hear no beeps, then the board is gone.
Hope this helps
May 26, 2009 | Toshiba Tecra 8000 Notebook
Toshiba tecra 8000 EC/KBC update
go to system setting by pressing F2 when you see the toshiba or bios logo
disable the system setting auto update.
Mar 16, 2009 | Toshiba Tecra 8000 Notebook
Toshiba tecra 8000 boot problem
sounds like the batteries are incompatible..this is an important aspect
Oct 09, 2008 | Toshiba Computers & Internet
Phone cord connection
hmmm..that's really strange. that tab opens by simply prying it off one side..take a nice thin bladed screwdriver(blade type) and shim it under the edges. should come out on one side or the other.
got backup for your Tecra?
Feb 11, 2008 | Toshiba Tecra 8000 Notebook
Tecra 8000
4 to 6 screrws with small round rubber stopers under them are screws. i would let a pro do it. it can break easy
Nov 29, 2007 | Toshiba TECRA 8000 13.3" TFT LCD Display...
Toshiba Tecra 8000 Notebook Logo
64 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
