Question about Acer Aspire 3000 Notebook
Embedded numeric keypad
I have a Acer Aspire 3610 laptop, that I cannot get the embedded numeric keypad to switch off. If I want to use the letters I need to hold the blue Fn key, otherwise the blue numbers on the top right of the keys show up instead. I have tried turning number lock on but then nothing shows up?
  • Anonymous Mar 17, 2014
    How can I activate my numeric key pad on Inspiration 17 laptop?
To toggle the embedded numberic keypad Hold down the blue Fn (function) key and press NumLk.
Posted on Oct 25, 2007
  • John Davidson Oct 25, 2007
    To toggle the embedded numeric keypad on an Acer laptop hold down the the Fn key and press NumLk.
    Problem Solver:
  • 17 Answers
Take it to the nearest repair shop where they will switch the key off because if you continue using it like that one of these days it may create a short circuit in your machine.
Posted on Oct 24, 2007
SOURCE:
How can i lock the keypad?
Hi Eliza,
Enabling and disabling the embedded numeric keypad
Press fn+num lock to enable the embedded numeric keypad. Press fn+num lock again to return to standard keyboard functions.
NOTE:
The embedded numeric keypad will not function while an external keyboard or numeric keypad.
Thanks Hope this helps!
Don't forget to rate:)
Gary
Apr 05, 2016 | HP EliteBook 2530p Notebook
The function key for the numbers on the keyboard i can't seem to stop it. When I want to use the letters i have to use the blue funtion key
The "problem" is simply that there is a persistent toggle. If you press "Num Lk" (I've also seen it labeled "Pad Lk" for numeric Pad) it turns on the blue keys, and inverts the meaning of the "Fn" key - it's a way to use that embedded numeric keypad without having to hold down the "Fn" key the entire time.
To fix it, just find and press the "Num Lk" or "Pad Lk" key again. (Note, sometimes these keys are themselves "Fn" keys, so you may, or may not, need to also hold down the "Fn" key to get the right function.) Often there is an indicator light associated with the setting.
Jun 27, 2014 | Acer Aspire One Netbook 8.9" Notebook
Can I know how to turn off Fn key in my LG laptop? whenever i top on 'l' key that appear '3' so please help how to release it?
Embedded Numeric Keypad
Press the Fn+Num Lk hotkeys to:
Disable the embedded numeric keypad (Num Lk light
turns off).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 18, 2011 | LG Computers & Internet
Hi, I have somehow switched the blue numbers on the keyboard, the one at the letters: J; K;L;M;U;I;O and so on. And now instead of them when i type the numbers 1,2,3,4.... will come up instead of...
You have turned on the Number Lock. This enables the number keypad that is embedded in the main keyboard. There is set of three lights to the right of the power button; the middle one indicates when the Num Lock is on or off on the keyboard. To toggle this on or off press and together. The key is between the and the at the lower left of the keyboard.
The user's manual is here: http://static.compusa.com/pdf/Acer_Aspire_5920_Series_NotebookPC-UserGuide.pdf .
I hope this helps.
Dec 11, 2010 | Acer Aspire 5920-6727 Notebook
On my acer aspire 5551 keyboard i dont know how to type the number key... how do i do it?
See page 23 of the manual here: http://global-download.acer.com/GDFiles/Document/Generic%20UG/Generic%20UG_Acer_1.0_A_A.zip?acerid=634079355121696686&Step1=Notebook&Step2=Aspire&Step3=Aspire%205551&OS=722&LC=en&BC=Acer&SC=EMEA_27
Num Lock + *
When Num Lock is on, the embedded keypad is in numeric mode.
The keys function as a calculator (complete with the arithmetic
operators +, -, *, and /). Use this mode when you need to do a lot of
numeric data entry. A better solution would be to connect an
external keypad.
In other words, hit the "Fn" key, and without letting go, hit "F11". That will allow you to type numbers.
Nov 16, 2010 | Computers & Internet
My function key is on and i cant figure out how to turn it off
To use the embedded keypad
After pressing Fn+F8 to activate the numeric keypad, you must press the Lock key
(in the top row of the keyboard) to turn number lock on or off.
When number lock is on:
• Keys change to the numeric or arithmetic designations printed on the right side of the
keys in the numeric keypad area.
• The Num Lock status indicator is lit.
• To turn off the embedded keypad, press Fn+F8 again.
For further reference of usage of Function keys, check the HP manual:
http://h10032.www1.hp.com/ctg/Manual/lpi05379.pdf
Page number: 30/141
Regards,
Nags
Jan 19, 2010 | HP Pavilion N5415 Notebook
Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
Mar 22, 2009 | HP 2133 Notebook PC
Web cam
those embedded acer webcams are not too hot..get a usb version and enjoy the utility
Apr 27, 2008 | Acer Aspire 3610 Notebook
Acer Aspire 3000 Notebook Logo
432 people viewed this question
Ekse
Alun Cox
