Black screen on my laptop
I turn my laptop on and there is no display its just black .it seems to be powering up lights are on and you can hear it loading up.
  • 1,170 Answers
Remove the battery and power lead
Hold down the power button (on the laptop) for 30 Secs
Re-insert the power lead only
Turn on.
Posted on May 10, 2009
Black screen but i didnt hear any beeps
Dear frnd,
its looks like Operating system problem. some times its happens that you power on and its display nothing except a black screen. you need to re-install the os but before it you have to confirm that your display screen is working. for that check the display in dark place so that when you power on its screen going to slightly white if its happens than its screen is ok if its doesn't than you have to change display screen cable inside of the laptop.
Jan 15, 2014 | Dell Inspiron Mini 1012 Netbook...
Everytime i turn on my k42j laptop, screen becomes distorted ( multiple dots with different colors) then suddenly the display just disappear ( blockout).
It seems that either the display for the laptop is going, or the video card is. Is the computer's power light still lit when the display blacks-out?
Apr 22, 2013 | Computers & Internet
Screen blank
I believe the sound you hear is simple static, if there are no power buttons showering where they should, look for a bad power adapter, make sure it is on, see a light? next check your battery.
Now past this you have a problem inside of your laptop, as in a bad motherboard or bad video chip....
Feb 11, 2013 | Kocaso Computers & Internet
My screen is black
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.If it seems like the laptop is up and running but the screen is not displaying anything then the issue is with the screen. Take a flashlight and shine it on the screen and look very hard and you might see the icons or something very faintly on the screen. If so, your LCD Inverter needs to be replaced. It is located at the bottom of the screen and covered by the strip that goes around the screen. IIf you don't see anything on the screen then try plugging an external monitor to the laptop. I can be any kind of monitor, even the old big fat crt's as long as it has a vga cable that can go into your laptop's vga port. If you see the image on the external monitor, that means your video card is good and the screen needs to be replaced. Sometimes you might have to hit the FN key plus one of the F1 thru F12 keys to get the image to display. The correct F1 thru F12 key will either say CRT/LCD or it will have the icon of a display on it. Press and Hold the FN key then hit the correct F1 thru F12 key. This will toggle the the image to display either on the computer's screen, the external monitor screen, or on both screens.
Mar 25, 2012 | Computers & Internet
Toshiba Satellite L450 black screen on startup no fune sound
OK, you get the yellow light which I assume happens when you plug in the power cord even though you have not pressed the Power Button. So, when you pressed the Power Button, did you see any other lights flashing such as the disk drive light? Did you hear the Fan running and the Disk Drive running? Did you hear the DvD/CD drive click once or the light on the DvD/CD drive door flash? If you did see the aforementioned that means your system is trying to boot and might in fact completed the boot process but the Video is not displaying. If it seems like the computer is running by no video is displaying try shinning a flashlight on the screen to see if you can faintly see the icons or something on the screen. If so that means your LCD Inverter is probably bad and needs to be replaced. You could attach an external monitor to the laptop then press and hold the FN (Function Key) + the (F1 thru F12) key that corresponds to displaying on an external monitor. If the video shows on the external monitor then surely you have an issue with the Laptop's screen. If the laptop is not running and you hear no fans, no disk drive running and saw no lights then you probably have a motherboard issue. Get a quote from your local repair shops, then try the guys at: http://www.generalsystemsconsulting.com. They will repair it and ship it back by Fedex or UPS and most times their prices will beat any quote you find including shipping.
Mar 14, 2012 | Computers & Internet
I had been using my computer when all of the sudden screen went black and I could hear the windows shutting down. I thought maybe my battery was dead and I was not paying attention, so charged it. But when...
Do a hard reset by turning off the computer and removing the battery and unplug the AC adapter. Without any power source, press and hold the power button and put everything back after. Power on the computer again, if it does not work, try to connect your laptop to an external monitor. If it shows some display it means that the LCD monitor of your laptop has gone faulty.
Aug 30, 2010 | Dell Inspiron Mini 10 Notebook
Black Screen
possibly ur display chip or graphic chip faulty. repair it from laptop repair prof.
Jun 25, 2010 | Toshiba Satellite A205-S5804 Notebook
Toshiba Satellite Notebook starts with black screen
It sounds like video card problem. Bring it to a repair shop.
Dec 11, 2008 | Acer Aspire 5100 Notebook
POWER TURNS ON BUT SCREEN DOES NOT
Try Holding The Screen Up to A Bright Light And Look at it from an angle to see if you can see windows running without the light.... If you can..... The Problem Is Either Your LCD Bulb (needs Replacing) or It's the Power Inverter....
If.. You See No OS Running .. Just Black You Could Need Either A New Display ... or your Video Card/Chip is Shot...
Try Connecting an external Monitor if able to..... If It SHows Up On An External Monitor then Your Video Card/CHip is Good..
If You Get No Display, But The Black Screen Lights Up.... It Is Either The Display Cable Or The Display Panel Itself....
Nov 17, 2008 | Sony VAIO PCG-K23 Notebook
Dark Display compaq presario m2005us
it seems that the screen laptop has been used for a long time you might need to connect the laptop to a monitor to see if there is any change.
Apr 21, 2008 | Computers & Internet
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
