Question about Toshiba TE55T11 55" Rear Projection Television
Cracked screen The outer screen covering( dark plastic) on my Toshiba TE55T11 projection tv is destroyed. My young sons cracked it years ago and it finally fell apart. Does anyone know what the part number is or where I can get a new screen? I can't seem to find a parts list on line or from Toshiba at their website
  • 3 Answers
Rmaura,
My Toshiba TE55T11 also has a broken screen. I contacted the Toshiba hot line in Australia and they said that they don't make screens for this TV anymore. so i just got a new Toshiba 72CM9UA.
I hope this info is useful!
Posted on Apr 20, 2008
I have been looking for the same thing for my te50t11 and have been told the screens have been discontinued. This is how I happened on to your questions. Good luck...
Posted on Nov 12, 2007
SOURCE:
Have Hitachi model 51F59A projection. The plastic screen is severly cracked on the left side due to a recliner. Can the plastic be replaced with plexiglass? You can actually see darkness thru the crack. Is...
Because this was 3 years ago It would now be cheaper to just replace the unit altogether and you would be alto happier let alone you would have a SMART TV as well.
Mar 23, 2011 | Hitachi 51F59 51" HDTV Projection...
Our large screen tv ( 2 years old and over 1000pounds from Dixons, UK) went blank. We switched it off immediately. On swtiching back on we heard a "pop" follwoed by the screen filling with dark...
Good Day, cjm364;
It sounds like the TV's panel has failed. A 2 year old TV should not fail in this manner. Call the manufacture and express your concerns to them very strongly and 90% of the time they will give a concession.
Good Luck, Big Irish, Let me know.
Jul 09, 2008 | Televison & Video
62hm85 cracked inner screen
If the screen cracked from daily use and was not cracked on the outside of the set,then you are entitled to a replacement or to have the tv repaired under warranty from a manufacturing defect. If the outer glass panel is not damaged and the internal screen is,then call the manufacturer.
Oct 31, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
Cracked outer screen on projection tv
No it can't be repair only replaced.
Part# 4-090-943-01 $76.15
Freight charges may range from $45 - $150
Jun 10, 2009 | Sony KP-46WT500 46" Rear Projection...
Crack and hole in the screen...
There are several parts distributors in the US that supply parts for Hitachi TV's You can try Herman Electronics, Tritronics and PAC parts, all have websites. Be prepared for the cost: a new screen will be in the $300-$400 range. It's not just a piece of ordinary plastic; it's actually two pieces of specially designed plastic designed to disperse the light evenly, called a lenticular and a fresnel.
Oct 31, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Cracked protective screen
Would buying Plexiglas and cutting to fit work? no
you could buy a used one try craiglist.com
Mar 17, 2008 | Samsung HCL4715W 47" Rear Projection...
Replacement of outer screen for a Toshiba TP50H60 projection tv
A frosted sheet of plexiglas works well. I put a plexiglass screen on my own 62 inch projection TV. It must be frosted to received the image being projected.
Jan 03, 2008 | RCA R52WM24 52" HDTV Projection Television
CRACKED SCREEN
the outer screen on these units easly replaced. RCA #258797 their called supersheilds.. rca charges about 70 dollars for the item...If it is just that i have seen people just use a clear sheet of plexi. removeing the screens requires removein several torx 20 screw around the outer and remove the frame.. then the clear peice of plexi is attache with serval brackets.
Dec 25, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
60" TV has a crack in the plastic outer screen
I have a Magnavox 9P6040C101 that i am selling of the parts.
I have the plastic protective covering. Call me for dimensions.
443-255-1892
Nov 16, 2007 | Philips Magnavox 9P6034C 60" Rear...
Toshiba TE55T11 55" Rear Projection Television Logo
193 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
