Question about Toshiba 27AF42 27" TV
Toshiba 27AF42 27" TV Problem
Hi, can someone please help me, I am looking for the replacement parts list for the hirizontal line problem that I have on this TV... I am a electronics guy and know how to replace this just need to know what parts need to be replaced and if possible the schematic ... thank you!
  • nicksjunk123 May 11, 2010
    the eserviceinfo.com site does not seem to be up any longer & I am having similar horizontal line problems. do know of any other free sites where a schematic can be viewed? or really even an overly generalized graphic of where the vertical selection is located & what it looks like. I really think it's just a loose wire because...please don't laugh too hard....hitting the top of the TV temporarily corrects the issue. Thanks in advance for any help or advice you might have.
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
Http://www.eserviceinfo.com/index.php?what=search2
  1. please reduce brightness to avoid crt damage.
  2. h/ line is mainly due to failure of vertical section.
  3. please check the the following.
  4. supply to vertical section
  5. connector loose in vertical section
  6. print open in vertical section]
  7. parts connected to vertical section like capacitor,low va lye resistor& ic .
  8. hope this will help.
  9. good luck
Posted on Oct 12, 2007
  • manahar modern Oct 12, 2007
    the given web site is for zenith products you can select your exact or more or less same & download for schematic.
SOURCE:
Need to know the size of screws that goes into TV stand for a Toshiba TV model number 40S51u
58 cents each mail order. Not only do they have to be right diameter and thread, also the correct length.
40S51U Toshiba Tv, 40" 1080P Led Lcd Replacement Parts
https://www.encompassparts.com/model/TBA40S51U/_/_/Toshiba/40S51U/Tv,_40
  1. Cached
Toshiba from Encompass parts & accessories. ... 40S51U Toshiba Tv, 40" 1080P Led Lcd. 40S51U Tv, 40 ... 75024004, Toshiba Screw, Stand, Mac000, 0.77.
Toshiba 40S51U Parts List - PartStore.com
https://www.partstore.com/Model/Toshiba/Toshiba/40S51U.aspx
  1. Cached
  2. Similar
List of Spare Parts for Toshiba 40S51U Parts List. 40S51U UNKNOWN ... Toshiba TV Mounting & Installation. 75024004. SCREW, STAND, MAC000. $0.58.
Toshiba TV Stand for 40S51U Complete with Neck and Screws ' eBay
www.ebay.com > ... > TV, Video & Audio Parts > TV Boards, Parts & Components
  1. Cached
TOSHIBA TV STAND FOR 40S51U COMPLETE WITH NECK AND SCREWS in Consumer Electronics, TV, Video & Home Audio, TV, Video & Audio Parts ' eBay.
Toshiba TV model number 40S51u Google Search
Nov 27, 2016 | Toshiba Televison & Video
I have a 10yr old thomson TV 21"some sort of unusual voice is coming out what to do??
I have an old Thomson TV 21FDR more than 10 years old. Recently the Tv screen has a lot of disturbances with the screen full of hirizontal lines and a hissing sound. A well trained technican had replaced the tuner with a new one . But after some 2-3 days the same problem is with the tv. Kindly help me with suggestions.
Aug 22, 2010 | Thomson 21DC320 21" TV
Hi, Please can someone help? I can not find my manual for my Thomson DTI 6300 does anyone have the codes for a toshiba tv?
0538 0090 1538 0065 1319 0066 0100 0132 0744 0271 0247 0139 0225 0221 0648 1938 0039 0067 1194 1193 0748
These are the list of codes to try for your toshiba tv for connection to thomsoo dti 6300.
Hope i`ve helped
Dec 04, 2009 | Televison & Video
Colored lines across TV
what this sounds like is that you may have a cable in the wrong part of the tv like maybe a vcr or audio cable check your inputs in the back of your tv that sounds like it what it might be i have a big screen tv and if i have a cable in the wrong part it will hiss and have lines on it too i hope this can help if not reply to me at Jonk3y @aol.com
Sep 23, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
Convergence problem red lines are out of wac on
Most of these sets use two STK-392-110 convergence IC's; both along with any open resistors around them need to be replaced and the set adjusted.
You can buy the chips on Ebay for less than 13 dollars(look for suburban electronics--Sewsale--they have the best price on these parts and give a 6 month warranty) if you are able to replace them yourself if not, look for someone in your area to do the job for you; this is the slow time of year for TV repair shops---some shops get 300 or more for this repair. I fix a lotof these smaller sets(42 etc) for 200 parts and labor.
Find someone and make sure BOTH IC's are replaced. If you have questions let me know here. I do this for free so if this was helpful give me a vote here.
regards, SD TECH
Aug 25, 2009 | Toshiba 42H81 42" Rear Projection...
Toshiba TV -- horizontal line
sounds like you have feild colapse.take off the back and on the ciruit look for the horizontal and when you get it sue a screw driver and a mirror. put the mirror in front of the tv once you locate the horizontal plug the tv back on and look at the mirror and as soon as you turn the horizontal you will see the picture come back up to the correct size, if no good???? take it out and get a new one if you look on the side off the component you must get tthe same for safety, solder the new component in and try again
Apr 20, 2009 | Toshiba Televison & Video
Toshiba Projection Television Problems
we are facing server problems please reply to me at [email protected]
don't worry i have found your part..
Apr 11, 2008 | Toshiba 57H81 57" Rear Projection...
Hirizontal Lines on the TV screen
Yes your laptop will onterfere with your television if you are to close.  But it can cause no HARM?
Oct 17, 2007 | Toshiba Satellite A60 Notebook
55'' t.v. blurry screen on right side with green line going down
SWounds like the convergence is bad in this set. If there are color outlines or part of the picture looks like it is in 3-D, you will have to have someone change the convergence ICs. Good Luck
Jun 09, 2007 | Toshiba 36A40 36" TV
Toshiba 27AF42 27" TV Logo
145 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
