Question about Dryers
Diagnostics and Repair Details
I have a kenmore dryer and it has recently stopped working.  After one load of clothes was finished drying and upon putting the second load in - I turned the timer, pressed start and nothing happened.  The light inside the dryer is working.
Any suggestion of possible location of problem.
  • 290 Answers
Check your door switch first. You should hear a click when you push it in and light should turn off.. If it clicks it is probably ok. If you need to know how to replace it or if it is ok, please reply back with model number so I can give you more detailed directions in troubleshooting.
Posted on Oct 12, 2007
  • Michael  Lindley
    Michael Lindley Oct 15, 2007
    Just wanted to follow up on your dryer problem and see what you found out.
  • Michael  Lindley
    Michael Lindley Oct 17, 2007
    Just wanted to follow up on your dryer and see what you found out.
Kenmore 110.66902690 electric dryer does not dry completely
Dear Barry,
Try 2 things.
One, be certain the clothes are very dry coming out of the washing machine.
If the washer leaves the clothes wet ( like the belt might be slipping), it can take the dryer forever to finish drying the clothes.
You can tell by hand-wringing them.
You should not be able to get any water out of them by hand-wringing after they have spun dry in the washer.
Two, try running a load with the vent hose unhooked off the back of the dryer.
If this fixes the problem, you are having a "clogged vent" issue somehow.
Be blessed.
Apr 16, 2013 | Dryers
Won't stop buzzing
electric dryerwon't stop buzzing
Dec 10, 2009 | Kenmore Dryers
Hello I have a Kenmore clothes dryer (80 series). It takes multiple cycles to dry the clothes.
Remove the connecting vent on the rear and run a timed load 45 minutes. If it dries correctly repair the vent blockage.
Oct 26, 2009 | Kenmore Dryers
Kenmore 11066912690 dryer stops working
if you are using the sensor drying cyle this could cause the unit to stop. it will detect the most dry clothing first usually light clothes that dry faster.if not and you are useing timed dry the most likely cause is a faluty timer,or a thermostat sesnor is going bad and turnoing off the dryer before the clothes are dry
Sep 16, 2009 | Kenmore 62602 Electric Dryer
Moisture sensor does not seem to work
your heating element may be bad if your cycle completely finishes and the clothes aren't dry. If
Jan 28, 2009 | Dryers
Kenmore 90 plus series dryer won't work
Sounds like the belt has broken. You could probably also use new drum support rollers. Check out this site which shows how to change a dryer belt:
It's not a difficult job if you're comfortable working with hand tools.
Oct 17, 2008 | Kenmore 62872 Electric Dryer
Dryer heats up but does not dry clothes
first take the venting off the back of the dryer and dry a load if dryes normal replace venting if takes a long time to dry have a repair man clean the dryer
Jun 12, 2008 | Kenmore 74602 Gas Dryer
Dryers Logo
140 people viewed this question
Top Dryers Experts
