Temperature red hot when oven set to 180 ,back of oven glows red,then still heating when dials set to off,eventually stops temp light still on when dials set to off
SOURCE: electric fan oven
Sounds like the oven thermostat stuck, for whatever reason and then the oven overheat thermostat kicked in. At the very least, I think you will need a new oven thermostat and possibly an overheat one as well. On the 720 there are two, one for each oven, so when you take the oven to bits, check both out.
SOURCE: dhow do i remove stoves efa600H oven door hinges?
1. Open the oven door and remove the 2 screws at the side of the inner glass window 11cm above the hinges and lift off the door. Place it somewhere safe!
2. Remove the 4 screws that you can see nearest to the left and right edges of the oven with the door removed. These secure the oven to the kitchen unit.
3. Slide the oven forwards about 20cm out of the unit, being careful not to pull on the cable.
4. Each hinge is held in place by 2 screws at the side of the unit now exposed, about 18cm apart. Remove them and slide out the hinges. Reassembly is the reverse of the above.
5. Note that the hinges have no means of adjustment. If not working properly, renew them.
