Question about Fuji FinePix F460 Digital Camera
I have used my F460 about 6-7 times. It is 4 years old. Nowm, even after a fresh charge, it shows no sign of having any power. Everything is dead.
  • 1,305 Answers
Replace the battery with a fresh one.
Posted on May 10, 2009
How to turn my 1080 hp monitor on connected to my computer
Look for the power button/switch on the monitor
Oct 13, 2017 | HP Computers & Internet
Hp pavillion zv6233nr
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Rechargeable batteries will fail if stored in a discharged state for long periods.
May 05, 2013 | HP Pavilion Computers & Internet
Satellite M205 S4804 Problem
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Jan 27, 2013 | Toshiba Satellite Computers & Internet
Tom is 5 times as old as todd.In seven years Tom's age will be 6 years more than 3 times as old as Todd. How old is Todd
Todd is 4 years old.
Let Tom's age = X
Let Todd's age = Y
From the given facts:
X = 5Y
and
X + 7 + 6 = 3 ( Y + 7 )
X+13 = 3Y + 21
X = 3Y + 8
So if:
X=5Y
and
X=3Y+8
Then:
5Y=3Y+8
2Y=8
Y=4
I hope that helps.
Joe.
Sep 14, 2011 | Office Equipment & Supplies
Hi my laptop presario v3500 turn off after 10-30 minutes...my laptop battery is dead...i using power a/c only...what wrong with my laptop..i saw this model always have same problem...thnx u
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Mar 20, 2011 | Compaq Presario V3500 Series Laptop...
Forgets date / time every power off/on
Yes there is and about two years is the right time for it two be losing it's power. Check on the right edge of the body and the left edge of the body, there should be a small slide out compartment for a button battery.
Sep 07, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Kodak Easy Share z712 IS not detecting charged battery
I have the exact same camera almost a year too. It is a total "swinka" on batteries. About 10-15 shots on super ni-cads, and quits without warning.
A pair of Energizer 7X gave me near 500 shots. Much cheaper but still ...
So 4 months ago I bought a charger and 2 rechargeables. Charge one while using the other one.
I may get 70-90 shots per charge on these lithium-ion rechargeable batteries, without flash.
Testing the batteries without a load doesn't really tell you anything.
What's the reading? Should be well over 4 volts when fully charged. Mine show 4.2V
Jul 24, 2009 | Kodak Cameras
Iriver h340 shows no content or does not load properly
Sounds like the battery is dead. Rechargeables only last so long. I'd copy all the content off it, before the battery dies totally, which could make it not work even connected to your computer. Looks like you can get a replacement battery: Iriver h340 Google Search
And here's a video on replacing the battery: How to Replace the iRiver H340 Battery
May 25, 2017 | iRiver H340 MP3 Player
I have Canon power shot S2 IS digital camera.I bought it around 2 years back.Now my camera is showing the sign of "change the batteries" even though the batteries are fully charged and the lens does not...
i suggest replacing a fresh battery will most likely solve your prob, overtime rechargeable battery can drain easily, try changing with a new battery and see if it does work well, there might be insufficient current, thats why it tends to drop of voltage easily upon using,
there is a specified lifetime for rechargeable battery, depends on your usage and charging method, theymaybe fully charged but sometimes wont give you enough power to drive
cheers
Nov 26, 2008 | Canon PowerShot A540 Digital Camera
Old unit not powering on
Hold down the power button and push the reset button. Then select the corresponding cancel button (unless you want to loose everything. If that doesn't work, pull the battery and the backup battery. You will loose everything but it might bring it back to life.
Nov 10, 2006 | Dell Axim X5 Pocket PC
Fuji FinePix F460 Digital Camera Logo
99 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
