Fan doesnt turn on everything else does what part do i need
  • relaga58
    relaga58 May 11, 2010
    what kind of a/c, split ,ducted or window?
  • 306 Answers
Could be the fan is bad if you have a ohm meter check for resistance and if it is good then focus on the capacitor. I just had a job that the fan was good but the capacitor was bad. The fan on the unit was on it's last leg but the capacitor did the fix. By your limited information you gave I am filling in blanks thinking you are talking about the condenser section of your split system.
Posted on May 10, 2009
94 thunderbird heat or cold air doesnt blow
if you saying the fan wont blow it may need a fan motor not uncommon it might be a speed switch if it has one some time you can hook a wire on the back of the speed switch plug in to get it on high use a 14 gauge wire or bigger a small jumper bent in a loop with the rubber peeled off the ends and shove them in the switch plug find the 12 volt ht wire on the plug with light or vom then try the other wires one at a time til fan runs with ignition switch on
Dec 24, 2017 | 1994 Ford Thunderbird
Lg dehumidifier fan doesnt work
have you checked the timing belt to check take down the cover and turn it on you will notice a belt by the fan if it looks out of place thn try fixing it
Jun 28, 2012 | LG Dehumidifiers
None stop noise(sound) the first time i turn the machine on, but it seems working alright coz everything functioning sofar
From your description I would say they hard drive is failing and would suggest that you buy a new one and transfer all your data over to it or go to a pc place and have them do it.
Feb 28, 2011 | Computers & Internet
Just rebuilt top end of motor replaced everything I could think of to do with the radiator fans and they still won't kick on even when I turn on the defrost what else can I do?
My buddy used to have a car that he wired the fans to a toggle switch in the cab. I know it sounds bad, but its cheap & will get ya by till you figure it out
Jan 12, 2011 | 1996 Chevrolet Camaro
My emachine T1742 desktop will not turn on. When plugged in the power supply's fan turns on, cpu fan doesnt start, both hdd/power led's flicker and pressing power button doesnt power on/off system.
Disconnect all the devices from the computer(tower) including keyboard, mouse, monitor(everything)..even the power cable
Now keep on holding down the power button on the computer tower for 15-30 seconds..
Now release the power button, plug in the power cable, monitor, keyboard, mouse and turn on the computer...
If it works, great!!!
Otherwise, take it for repair..
Dec 03, 2009 | E-Machines eMachines Desktop PC
Sounds like a bad fan
Over time, everything gets old. I suggest buying a "Inter-cooler" it helps keep everything cool, and takes a little less pressure off the fan.
Feb 03, 2009 | Microsoft Xbox 360 Console
Sub woofer its on for 3 sec..
your cooling fan is not engaging and coming on like its suppose to. One, the fan is probably burned out, which sucks because its low voltage and the only thing on the board that is low voltage. Two, there is a thermostat type component that tells the fan to start which HAS burned out and doesnt start the fan accordingly. If you look at the back fan and turn everything on you will see the fan either doesnt start or starts right as the relay trips turning the sound components off. If it starts at all your fans good.The thermostat component will need to be replace and I cant recommend a source. Just trying to explain the problem so you can look for the right repair. Hope it helps. I have one of these and have found this is the problem, but cant find the solution.
Apr 28, 2008 | JVC TH-M505 System
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
