Question about Sony Dual Shock 3 Controller for PlayStation 3
PS3 Dualshock Does not Charge.
The controller all of a sudden refuses to charge. It is working fine with the remaining charge, vibrates, startsup the PS3 console via the PS button etc. But does not charge.
Local Sony Gulf refuses to repair it.
Hi i had this problem my controller would not charge although my head set would useing the same usb cable .i brought a new controller and tried two usb leads it was no different .this is the silly bit go and buy a new genuine ps3 usb cable and and i promise you all your problems will be solved .i have no idea y the cables stop working with only the conroller but they do i hope this helps all you people pulling your hair out trust me this will work
Posted on Jul 30, 2009
I had almost the same problem,but a bit worse. Controller wouldn't start the console, controller shut down immedietly when i removed the usb cable etc.
Turns out that when i switched to a shorter usb-cable it all of a sudden started to charge the controller. The longer usb-cable i've used (~3meters) have worked perfectly on my other controllers (non dualshock though)... just upgraded from old ps3 to a ps3 slim where i got the dualshock controller which for some reason don't get charged with my long usb-cable...
So my solution, use the original usb-cable that comes with the console or buy a short usb-cable.
Posted on Sep 24, 2009
Keep trying it it will work some time
Posted on May 10, 2009
Hello, my problem is with the Dualshock 3 controller from the ps3. It was working well but then it suddenly turned off and now it doesn't turn on anymore. I've tried pressing the reset button, connecting...
Its due to the whole BATTERY DRAINAGE.
Connect it to console/PC and make sure that light is blinking on number 1.
Leave it for atleast 30 mins to get some charge to power.
Let me know if it works like this or not.
Mar 12, 2011 | Video Game Consoles & Games
Hey!!! I got 2 New PS3 Dualshock 3 controllers that were working perfectly and one day out of nowhere they don't vibrate anymore. I didn't change any settings or do anything for that matter. Please...
Try resetting the vibration on the controllers. press the PS button, Settings, Accessory settings. then controller Vibration functions, Vibration Function ON.
Jan 12, 2011 | Sony Dual Shock 3 Controller for...
My ps3 pad dualshock 3 doesnt vibrate when playing call of duty world at war(which supports dual shock 3)should i take it back? its brand new an works fine on other games..
You might want to make sure you have Vibration set to "On" for that game, and if it is on, then yeah, I would suggest getting a refund on that piece of.......
Oct 07, 2010 | Sony Dual Shock 3 Controller for...
My ps3 controller wont charge
Bosa, you're wrong. Had the same problem. The USB cable that comes with the PS3 won't charge the new Dualshock Sixaxis. I had to use a thicker, more robust cable in order to get the controller to start charging.
Apr 03, 2010 | Sony Dual Shock 3 Controller for...
Dualshock 3 battery is not charging
Have same issue. Contollers only 2 month old and stopped holding a charge. The controllers flash 'dead battery' when switched on, if I plug up the charge lead they flash to say charging, and after 10mins or so they stop flashing. But no charge in battery. both my controllers have been charged less than 10/15 times.
This fault seems to have come about after the latest system update?
I think you should contact Sony.
Nov 26, 2009 | Sony Dual Shock 3 Controller for...
Is it ok to charge my controller on laptop/pc
There isn;t a reason why you shouldn't charge using a laptop/pc, did a bit of resaearch and many people claim to be charging thier pads via a pc's usb,
I tried it on mine and it didn't work, it recognised the PS3 pad and installed it as a game controller, which was pretty cool but it wouldn't charge, haven't tried it on my mac yet . If it doesn't work first time try a diff. usb port on your laptop pc, as sometimes its certain usb ports on your system that carry enough juice to power a device
d:)
Jul 31, 2009 | Sony DUALSHOCK® 2 Analog Controller for...
PS3 Controller will only work when plugged into the USB
I picked up the folling troubleshooting tips from the PlayStation Knowledge Center. I know it may seem silly or insulting; This is not my intention. Problems like this are usually just little things you're over-looking. Give thest tips a shot, one by one, and see if your solution is in here. If it isn't, message me back here & we'll try something else to get your controller working, ok? By the way... Is it a sixaxis controller or dualshock?
  • Verify if the SIXAXIS or DUALSHOCK 3 wireless controller works with the USB cable.
  • Verify that the SIXAXIS or DUALSHOCK 3 wireless controller's battery is charged.
  • Attempt to pair the SIXAXIS or DUALSHOCK 3 wireless controller to another PLAYSTATION 3 system. This helps determine whether the problem is with the system or the controller.
  • Attempt to connect another SIXAXIS or DUALSHOCK 3 wireless controller to the PLAYSTATION 3.
  • Move closer to the PLAYSTATION 3 system. The maximum range for Bluetooth is 30 feet.
  • Make sure you have less than seven Bluetooth peripherals paired with the PLAYSTATION 3.
  • Unplug any other USB device plugged into the system when pairing the SIXAXIS or DUALSHOCK 3 wireless controller.
May 19, 2009 | Sony Playstation 3 (PS3) Console
Ps3 version 2.10
hello There..i think you might check your controllercoz there are 2 type of controller
1. Sixaxis Controller
2.Dualshock 3 Controller (vibration)
And Here The Latest Version For PS3 Firmware - (2.42)
Here You Go - file:///C:/Documents%20and%20Settings/WinXP/Desktop/PSP%20&%20NDS%20Files/2-PS3%20Folder/PS3%20Firmware/PS3%202.42/PS3/
Jul 31, 2008 | Video Game Consoles & Games
Sony Dual Shock 3 Controller for PlayStation 3 Logo
2,350 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
