Question about Refrigerators
Refrigerator not cold little ice build up in freezer.im not sure if it defrost timer or defrost thermosat or temperature control freezer is deforsting a little not as cold
  • 158 Answers
If it's frost free its possible the timer is defective or it can be thermostat or fan as well
Posted on May 10, 2009
Daewoo side by side fridge freezer FRS-U201CW-N186. Freezer is not self defrosting and fridge isn't maintaining a cold temperature
start with locating and cycling the defrost timer switch, generally found in the refrigerator side. The timer controls a heating element designed to melt off ice build up on the interior freezer coils. if the timer is bad, ice will build up, blocking air flow to the refrigerator section (making it not cool) and eventually build up enough so that the internal fan actually hits ice, making unusual noises. most timers can be manually driven with a flat head screwdriver, do it with the power connected, when you reach the defrost cycle you will hear the fans and compressor shut off, and you should be able to feel warmth on the back panel in the freezer after a few minutes.
if you find the timer isn't working properly, it is not difficult to replace, take your time, take pictures as you go along so reassembly is easier, and of course have the frige unplugged when you do it.
Sep 14, 2014 | Refrigerators
Kenmore classic bottom freezer refrigeration warm but freezer is cold
I would guess you have just caused a build up of ice to block the air way, which normally takes cold air into the fridge. manually defrost (unplug and wait until the ice goes away) then restart and it should be fine
Nov 11, 2013 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge is cold, freezer is not
Please look into the freezer for frost build-up on the rear wall. If you are having a defrost problem it may limit the freezer temperature and still be cold enough for the fresh food section to remain at safe temperatures but not for long before freezer and fresh food section warms because frost blocks airflow and the evaporator is unable to keep everything cold because of frost build-up. I don't have your model number so I will list the parts that may need to be replaced. The defrost control=> 12002754 Frost Kit, defrost thermostat and 67002493 Defrost Heater Assembly
67003426 Defrost Thermostat
For testing of the defrost thermosat and defrost heater refer to the same page as the parts, If these parts are good the the 12002754 Frost Kit, could be defective. The 12002754 Frost Kit,
can be found in the control panel inside the fresh food compartment. Let me know if you have questions and also if you are not having a defrost problem, Thanks Sea Breeze
Locate your model number
Aug 22, 2012 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
The freezer side is working but no cold temperature in the fridge section of our side by side door with water and ice dispenser kitchaid fridge. Wonder what the problem is?
Hi
If the refrigerator is in defrosting mode, the freezer compartment temperature will be less cold than usual. Wait 20 minutes, and you should be able to feel cold air blowing in the bottom of the compartment. If you have frost on the freezer coil, you probably have a defrost problem. Your freezer should go into a defrost cycle about twice a day. When this happens the compressor and fans shut off and a defrost heater in the freezer coil will turn on heating away the ice. This usually last 10 - 20 minutes. If the defrost coil doesn't defrost it will become a solid block of ice and this will in turn block the air from blowing into your refrigerator compartment. There are several things that can go wrong with the defrost cycle such as the defrost timer, defrost heater, or the defrost termination thermostat.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Jul 19, 2010 | KitchenAid Refrigerators
Frost Buildup in Frost Free unit.
You will have to check the defrost timer to make sure it is turning if it is working properly and you are getting power to the defrost heating element below the freezer coil it should get hot if you have a 115volts or so to the element and it does not get hot then you have a bad element
Jun 10, 2010 | Kenmore 57029 Side by Side Refrigerator
Ice building up in fridge
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Jul 12, 2009 | Refrigerators
Viking refrigerator with bottom freezer always running
Jul 05, 2009 | Viking VCBB363L Bottom Freezer...
Ice build up in freezer
Defrost system failure.
Defrost timer, heater, therma disk, any one could be bad.
You could manually defrost and this would get the Ref back to working for a couple of days before it iced up again. Remember there is a lot of ice build up on the cooling coils in the freezer that you can't see so, a little extra time with a hair dryer is needed to do a complete manual defrost.
Jan 21, 2009 | Amana Refrigerators
Freezer not cold, the meat is melted
Sounds like you have a defrost problem. Pull the back panel off inside of the freezer and make sure the fan is running (evaporator fan motor). If it is, check the defrost heater and defrost thermostat for continuity. If one is bad, you have found your problem. If both are good, replace the defrost timer, adaptive defrost board, or main control board (I'm not sure which you have since I don't have your model number). Let me know if I can be of further assistance.
Mar 27, 2008 | Kenmore 53542 / 53544 Side by Side...
Amana bottom freezer
Hello ghilitho, what you are having is an issue with the defrost cycle. There are 3 parts to this, heater, thermosat,and timer. Sometimes on the newer units the timer is the electronic control. What you are seeing is after you defrost the unit, it works for a time, this is because the evap fan pushes the air thru the unit. With the evap coil froze solid, the cooling drops. You will need a ohm meter to check the heater and thermosat, the heater & thermosat should show to be closed. Also make sure if this unit has a over heat thermosat that it is closed. It may have open up. If all this is good, then the timer is the issue. Hope this helps
Jan 28, 2008 | Refrigerators
Refrigerators Logo
93 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
