Question about Jl Audio 1000/1 Car Audio Amplifier
Bass boost i have a jl audio 1000/ i need to put the bass boost all the way up to get the full 1000 watts of power?
It says in the manual not to bridge the amp to ur speakers! it will cause damage to ur amp... btw there is not a bridge mode connection...
Posted on Feb 01, 2008
  • 790 Answers
Yes! just set it to bridge mode connection!
Posted on Oct 12, 2007
I have 2 12in kenwoods and a 1200 watt pyrimade amp, how can i hook these up to be the loudest
1st have your subs facing inwards towards the front of the car, not facing out the boot, This creates a better bass.
Wire 1 sub to one channel and the other sub to the other channel.
Turn down your gain as low as possible and then power everything up.
turn volume to desired loudness and then start turning up the gain slowly, if distorts a little turn in back down a notch.
avoid using bass boost, I agree it sounds great but it puts more strain on your amp and shortens its life.
after sorting out your gain, tweak all others until sound is bassy and clear with no distortion.
If you would like to use bass boost, turn on bass boost first, then up your gain etc.
Jan 16, 2013 | Pyramid PB915X 1200 Watts 2 Channel...
I have 3 JL Audio 12
Reduce the amount of boost or, better yet, turn off the bass boost. With your installation, overemphasis on the bass is causing the rattles and distortion
Nov 16, 2012 | Kenwood KAC-9103D Car Audio Amplifier
JL 13w7 & 1000/1 Settings
There is no "perfect" setting that can be placed in a manual. It's all done by ear. Your settings will vary depending on the vehicle you are in, the type of enclosure you have, the type of music you listen too, how much voltage your deck put's out. There are many variables, but I can try to give you a basic guide.
First of all you need to know your enclosure. If you have a ported enclosure tuned in the mid to low 30's you may want to set the low pass to around 70-80 hz with your sub sonic set at 30 hz. this will give you the higher bass frequency you need for the loud bass you want, and protect the sub from going too far below the tuned frequency of the enclosure, and losing it's composure.
As far as the gain, and bass boost are concerned, you just have to adjust them by ear. First adjust the radio volume to normal listening levels, by that I mean as loud as it can go without the speakers in the car sounding like ****. Now you adjust the gain first. slow turn the gain control, carefuly watching and listening to the sub.. Adjust the gain to the point of the woofer getting a lil sloppy then back it down a bit until the sound is clean again. Now do the same with the bass boost. if there is a bass boost frequency adjustment, set that as close to the tuned frequency of the box as you can.
If you are in a sealed box the adjustments are a bit easier, and are all about taste. Adjust the radio as described before, and put on your favorite song. Next start udjust thing lowpass frequency to taste, not too high tho, try not us higher than 100 hz in your sub's for better sound. Sub sonic is not quite as important in a sealed box, as there is much less danger of the sub losing control.
Well good luck, and hope this helps!
Jul 13, 2009 | Jl Audio 13W7 Car Subwoofer
Trouble with jl amp
well start with. turn your hi pass completely off. Turn your bass boost completely off. Turn your input gain copletely down. and turn your cd player to about 3/4 of what you listen to it at. Then turn your input up until it starts to sound a little dirty(distortion) then turn it down a notch. set it at a 80 herz filter so it allows nothing over 80 herz to come through. I just installed one of these jl amps a week ago. 1400.1 and it made two kicker cvt's sound amazing just have to set it just exactly like i told you. it will hit tight as hell and loud and it will hit all frequencies way better.
Jun 09, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Want too get best low bass i can from this amp
you turn your low pass filter (LPF) on the amp down to your desired frequency, but the box you have it in will drasticly change the sound (if you werent aware) hope this helps!
Mar 22, 2009 | Jl Audio 500/1 Car Audio Amplifier
JL Audio 1000/1 hook up to alpine type x
it is all up to the user, you can start by turning the input up slightly, I would not go over halfway because it usually starts to distort, then the bass boost up till they distort a little then back down a quarter turn.
Mar 10, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Adjusting wattage on kenwood kac 9103 class D mono amp
That amplifier is 900W x 1 @ 2ohms.
If your subs are 4ohm SVC wired Parallel, resulting in a 2 ohm load, each sub will only see 1/2 of the rated power. (450W ea.)
Your gain (sensitivity) setting should be between 75% and 85% to max. You will be fine.
Jan 02, 2009 | Kenwood KAC-9103D Car Audio Amplifier
Do you have instructions for wiring install on volfenhag GX8200??
Amplifier Class AB
Number of Channels 2
RMS Power (4 ohms) 120 watts x 2 channels
RMS Power (2 ohms) 200 watts x 2 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 400 watts x 1 channel
Total RMS Power Output 400 watts
Peak Power Output 1000 watts watts x 1 channel
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.1%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
High-Pass Crossover Frequency 40 - 250 Hz
Low-Pass Crossover Frequency 40 - 250 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 20A x 2
Dec 24, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
Need to know the right setting to apply for my subs
You need to match your amp's input voltage (the gain) to the output voltage supplied via your deck's preouts. Turn you radio up to normal listening level, and turn the amp's gain until you induce audible distortion then back it off slightly. Set the bass boost and crossovers to on and type (highpass for front/rear full range or lowpass for subs).
Apr 26, 2008 | Jl Audio 12W3 Car Subwoofer
Amp voltage
Well this is interesting, Let me start by saying if you have a 2 ohm load and your system is set for 4 ohms you are going to overdrive your load and burn up your amplifier, maybe not right away, but sooner or later it will fail due to electrical and thermal stress bought on by power dissipation issues.
Yes you can get 2000 watts out of your amps, but the correct way is to bridge your amplifiers if you can, and terminate them into the proper load.
Thank you,
Apr 21, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Jl Audio 1000/1 Car Audio Amplifier Logo
186 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
