Programming a key fob is all about timing. You are most likely doing everything correctly, just not in the correct time sequence. Keep at it, it might take you a dozen times, but you can get it. A tip is to do it as quickly as possible.
Here are the programming instructions:
*** THERE ARE 2 POSSIBLE PROGRAMMING PROCEDURES. ***Procedure #1Note: Obtain all remote transmitters for this vehicle.
Note: Do not depress the brake pedal during procedure.
- Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in RUN. Door locks will cycle to confirm programming mode. (Off is the position where you can remove your key, RUN is the position just shy of starting your car.)
- Within 20 seconds press any button on the first keyless remote to be programmed. Door locks will cycle to confirm programming. If you only have one remote then skip to step 4.
- Within 20 seconds, press any button on the second keyless remote. Door locks will cycle again to confirm programming. Repeat step 3. For all other remotes.
- Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
Procedure #2Note: Obtain all remote transmitters for this vehicle.
- Fasten seat belts and close all doors.
- Turn ignition from OFF to RUN 4 times within 6 seconds, with the 4th time ending in RUN. (Off is the position where you can remove your key, RUN is the position just shy of starting your car.)
- Turn ignition to OFF. Acoustic signal will sound and system warning lamp will illuminate to confirm programming mode.
- Within 10 seconds, press and hold any button on the first keyless remote. Wait for acoustic sound and warning lamp to flash (confirming programming) then release button on remote. Wait 2 seconds but within 10 seconds repeat step 4. For all other remotes. If you only have one remote then continue to step 5.
- Turn ignition to Crank or wait 10 seconds to end programming mode.
Bonus Tip: You can save time and money purchasing a
Ford Explorer Key Fob online from Keyless Entry Remote Inc.
