Question about GE 25GT240 25" TV
GE tv 25GT240 Vertical keeps bouncing and won t stay fixed how do I stablize picture Is there a vertical knob or a way to fix this problem?
  • 700 Answers
Is it like its vertical is folding over to the center of your screen? If this is it, vertical IC is loosing its connection to its board. Better to resolder it, or some component is going faulty within vertical circuit or the IC itself.
Posted on May 10, 2009
GE 25GT270 TV had a jumpy picture for a short time, then TV shut down. Afterward, smelled a burning smell. What happened and can I fix it?
Check its vertical output section circuit for damaged component/s. Check the vertical output IC.
Feb 19, 2013 | GE 25GT270 TV
Hi, I have a Tedelex EC29187 Television it have only a horizontal line in the middle of the screen, I opened it and looked for physical damage around the vertical defflection IC, but it show nothing so...
Ur tv it is taken aparts wright now?Yes.Plug in ur tv to see the problems and take the hard end handle of the screw driver and taps around the vertical deflection ic for cold soldering joints,will require resoldering the ic,if the vertical hold flickers or bounced back to normal.No bounce back vertical hold check all the sorrouding capacitors transistors resistors for dead components parts to be replaced,if all the sorrouding parts are good,than that vertical deflection ic it self it is dead and require replacing.
May 09, 2011 | Televison & Video
The vertical hold keeps going out. Fixes itself for a short time and goes out again. The volume stays fine. When you turn off the tv and turn it back on the vertical hold goes out. Hopefully there...
you either have a bad vertical ic or just bad solder connection around the vertical ic and stage. When the TV is fine, if you slightly tap the set and the problem presents itself, then it is bad solder at the ic and stage.
Jan 15, 2011 | Televison & Video
The picture on My Zenith TV is not centered. How can I fix it?
there are adjustment knobs located on the pcb for the horizonal and vertical holds. try adjusting these to fix your problem.
Aug 08, 2010 | Zenith C36V23 36" TV
I have heard a popping sound with tv going off a couple of times This time I cannot turn the tv back on. Is it worth fixing?
well that all depends on the cost of the replacement part vs that of a new tv.
It sounds as if the flyback (tansformer) part of the power supply circuit is shot. replacing the flyback can fix the problem, but there are still other things that could have blown such as a few capicators / resistors and diodes on the power supply circuit. and then they might have a few cracked solders as well.
Simply put you wont know if its worth it or not until u have it looked it, or attempt repairs yourself and get the cost of the replacement parts.
Mar 01, 2010 | Mitsubishi WS-55511 55" Rear Projection...
GE 25GT240
the problem of your tv is lose connection, if you know how to used soldering iron, solder your tv specially in vertical section. and check also the supply of heater.
Oct 31, 2008 | GE 25GT240 25" TV
Vertical Alignment ProblemHitachi 50"
resolder the vertical ic. you have bad connections on the bottom
Jun 12, 2008 | Hitachi Televison & Video
try resoldering the vertical output. Its located on a aluminum heatsink.
Apr 14, 2008 | GE 46GW947 46" Rear Projection Television
Vertical rolling
Does you set have PIP (picture in picture)? If it does then the PIP module has a bunch of capacitors that have gone bad (dried out and leaked) causing you to loose vertical sync. Vertical synchronization is what locks your picture keeping it from rolling. Even if you don't have PIP then still you have a vertical sync problem. The set would have to be checked by a tech to find exactly what's happening. Stargazer
Mar 04, 2007 | Mitsubishi WS-55807 TV
Disney princess tv
your receiver's vertical sync is out of control, i suggest you bring it to a technician
Jan 07, 2007 | Disney DT1350-P 13" TV
GE 25GT240 25" TV Logo
93 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
