After a power outage my rca 36 inch pip changes channels
Sometimes it will function fine, and after a few min it changes from whatever channel it's on and goes up one channel at a time only staying on each channel for about one second. Ive tried auto programming it finds all channel, however after the search is done it continues changing. Is there anything I can do the pix is great but I'm growing short on patience
  • 117 Answers
The manual buttons on ur tv set seems to be stuck, take a look for any damage or corrosion or for anything
Posted on May 10, 2009
RCA P56950 Powers on then 10 mins later powers off, repeats cycle. Then channel display in TV changes by itself
may be some thing is stuct on the controt pannel power button or others check. try this it may work
Jun 04, 2012 | RCA P56950 56" Rear Projection Television
Keep changing channel without any input
Most of the time it is the front contact switches Dirty clean them with contact cleaner or replace contact buttons on front panel board 29 cents each Call Mats 1-800-628-1118
Nov 19, 2009 | RCA F36673ET 36" TV
Vizio remote
The remotes for the TV and Direct TV box are universal remotes that can operate very basic functions for whatever else they are programmed to control. If you can program the TVs remote to operate the Direct TV box it will basically only control power and channel. Maybe something else, but not much. The same goes for the Direct TV remote. It will control basic functions on the TV; power, channel & volume. Best bet would be to purchase a universal remote that can learn functions from the original or just keep both remotes available by the TV.
PIP (Picture In Picture) - Your television should have the capability because it has two built in tuners. It can show two channels at the same time or show one channel and one video source (whatever is connected to the audio/video inputs). However, because you are using DTV (Direct TV) you are very limited because you are not using the built in tuners on your television. You should be able to see one picture from the DTV channel and one from lets say your DVD player. If your DTV box has two tuners built in then you should have the PIP capabilities from your DTV and not your television. I'm guessing your DTV is a single tuner (one satellite cable to your box). If you want to watch two different channels you'll need to either upgrade your box or attach another box to your television.
Option: you could also connect an antenna to your television this way you can use the PIP function. Obviously you'll only be able to view whatever local stations you can get with the antenna. Depending on where you live you might or might not have a lot of channels to choose from.
Apr 19, 2009 | Vizio L32 32 in. LCD HDTV
PIP on old panasonic tv only shows the channel you are watching
Determine your exact model - there should be a sticker on the back.
Similar to: CT32HX40B, CT32HC43G, CT32S20U, etc, etc.
Go to below link and download the appropriate PDF for your model.
(Tip: Set page to " Show All Rows" for ease of use.
http://service.us.panasonic.com/operman/findmanual.aspx?cat=DTV
Depending on your source input (Cable, Antenna, both) - the PIP instructions will vary.
Note: The PIP is not all it is cracked up to be anyway, so you may be wasting your time, also if you get the PIP in a stuck mode... See the link to fix it: http://www.fixya.com/support/t664989-turn_off_panasonic_pip
Jan 03, 2009 | Panasonic CT-36HL43 36" TV
RCA 36 inch ---channels keep changing
Mine did this and I took the back off of it to remove the button panel on top of the tv. It un- snaps from the inside and pulls straight out. My channel down button was messed up but it lookd fine. It has three prongs on one side of it and two on the other. I clipped the two prong side of the switch and put it back together. Works fine now with remote. Be careful as the set picture tube holds high voltage for a long time when unpluged. Unplug overnight and then work on it.
Jul 21, 2008 | RCA F36674ET 36" TV
Suddenly, can't get all the tv channels!
Try resoldering where the tuner mounts. Rca has had some problems with solder connections
Oct 16, 2007 | RCA F36649 36" TV
Intermittent snowy pictures under Channel 51
Probably needs a new tuner or something associated with the tuner.
May 31, 2007 | RCA F36673ET 36" TV
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
